  3. DLMS Connection Issue With SI Controller(EFR32xG23B)
DLMS connection issue with SI controller(EFR32xG23B)
By supritha , 25 July, 2025
when I am trying to communicate with the meter, I am facing issue at 7th transmission I am getting error code response from the meter as read write denied.
could you assist with this issue.
Regards
Supritha K P
1 year 1 month ago
Hi, I believe the object you…
I believe the object you try to read does not exist on the meter. Check that the logical name and object type are correct.
