  3. DLMS Communication Issue When Routing Through VPN On Android
DLMS communication issue when routing through VPN on Android
By auroralane7754 , 17 July, 2025
I'm currently testing DLMS communication over Android devices, and I've noticed that some VPNs cause the connection to drop or timeout intermittently when trying to read meter data remotely.
After several trials, I found that using Stag VPN actually resolves the issue. The communication remains stable and meter responses are consistent, even when routed through the VPN. I’m curious—has anyone else here tried DLMS/GXDLMS communication over a VPN? What’s your experience?
Any insights or alternative setups that work reliably would be appreciated.
Thanks!
1 year 4 months ago
Hi, There is an inactivity…
There is an inactivity timeout on the meter. This means that if you don't read anything from the meter within the given time, the meter closes the connection.
https://gurux.fi/Gurux.DLMS.Objects.GXDLMSTcpUdpSetup
