  2. DLMS Data Gateway Communication With Meters
DLMS Data gateway communication with meters
By Harshi_554 , 3 July, 2025
Gurux DLMS for ANSI C
Hiii
As per the dlms datagateway source , the gateway will communicate with the smart meter using serial port (HDLC) communication. Is it possible to communicate with the smart meters using TCP/IP (Wrapper) communication using ethernet?
1 year ago
Hi, Yes, it's possible. You…
Yes, it's possible. You need just change interface type from HDLC to WRAPPER and establish the TCP/IP connection to the meter.
Harshi_554
1 year ago
Hi , Thank you for the reply…
Hi ,
Thank you for the reply.
Where I need to do the required changes? Can you share the changes?
1 year ago
Hi, You need to establish…
You need to establish the TCP/IP connection to the meter in com_open.
Now it's using serial port. Then change
cl_init(&clientCon.settings, 1, 16, 1, DLMS_AUTHENTICATION_NONE, NULL, DLMS_INTERFACE_TYPE_HDLC);
to this:
cl_init(&clientCon.settings, 1, 16, 1, DLMS_AUTHENTICATION_NONE, NULL, DLMS_INTERFACE_TYPE_WRAPPER);
The used settings depend on your meter.
Harshi_554
1 year ago
Thank you for the response…
Thank you for the response. It helped me a lot.
