  3. DLMS Server Connection Using Serial Port
DLMS server connection using serial port
By Harshi_554 , 5 June, 2025
Gurux DLMS for ANSI C
Is it possible to communicate with the dlms server (which I'm using as virtual smart meter using PC) using serial port connection from dlms client?
1 year 5 months ago
Hi, ANSI C example meter…
ANSI C example meter uses only TCP/IP ports. Client supports serial port and TCP/IP connections.
