  2. Need Support For Android 7 Version.
Need support for Android 7 version.
By Vadiraj , 2 June, 2025
Gurux DLMS for Android
In exsisting Android 2.0.15 project we are not getting support for android 7 version devices were getting an exception GXSerial registerReceiver() method.
Couldn't able to modifiy that file because its read only, but we have tried to convert "gurux.serial.android-2.0.11-sources.jar" into source code after changing source code we are not able to convert it again into .jar file. Can you please support for that. Otherwise if you have any suggestion please let us know.
1 year 1 month ago
Hi, Google ended support for…
Google ended support for Android 7 in August 2019. If you want to support Android 7 devices, you can modify the source code to meet your needs.
It's recommended that you update the version seven to newer versions.
You can try with version 2.0.12.
