  3. Confarmance Test Failed
By MikeAtson , 24 April, 2025
Gurux DLMS for ANSI C
I'm trying to stm example but there is a lot failed errors.
Test Report: Stmkit
Gurux Conformance Tests
Ran for 00:21:28.1573439
Start Time: 24.04.2025 12:44:14
HDLC Setup default inactivity timeout value is 120 seconds.
Testing using Logical Name referencing.
Authentication level: Low
Proposed services:
GeneralProtection, GeneralBlockTransfer, DeltaValueEncoding, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, BlockTransferWithAction, MultipleReferences, Access, Get, Set, SelectiveAccess, Action
Supported services:
BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, BlockTransferWithAction, MultipleReferences, Get, Set, SelectiveAccess, Action
Total amount of objects: 29
Logical Device Name is: GRX0000048352806.
Meter time: 1.01.1970 02:00:00.
Errors
Receiver Ready failed.
Test #1 failed.
Test #2 failed. Response is not RR.
Test #2 failed.
Test #3 failed.
Timeout.
Test #7 failed.
Test #15 failed.
Test #16 failed.
Test #17 failed.
Disconnect request failed. Media is closed.
Test #101 failed.
T_APPL_DATA_LN_N6 test failed.. The input string was not in a correct format.
T_APPL_OPEN_7 test failed.. Connection is permanently rejected. Authentication mechanism name is required.
T_APPL_OPEN_7 failed.
T_APPL_OPEN_11 failed.
T_APPL_OPEN_12 failed.
T_APPL_OPEN_14 test failed.
T_APPL_DATA_LN_N1 failed.
Invalid OBIS code 1.0.99.1.0.255 for Register.
Invalid OBIS code 1.0.99.2.0.255 for Register.
AssociationLogicalName 0.0.40.0.0.255Get Index 5 failed:The specified argument was out of the range of valid values.
AssociationLogicalName 0.0.40.0.1.255Get Index 5 failed:The specified argument was out of the range of valid values.
No warnings occurred.
Info
SNRM request succeeded. MaxInfoLengthTransmit: 128 MaxInfoLengthReceive: 128 WindowSizeTransmit: 1 WindowSizeReceive: 1
Meter returns DisconnectMode.
Disconect SNRM request succeeded. MaxInfoLengthTransmit: 128 MaxInfoLengthReceive: 128 WindowSizeTransmit: 1 WindowSizeReceive: 1
HDLC Test #4. Meter returns DisconnectMode.
HDLC Test #4. Opening flag missing succeeded.
HDLC Test #4. Closing flag missing succeeded.
HDLC Test #4. Both flags missing succeeded.
Illegal frame succeeded.
Unknown command succeeded. Unacceptable frame.
Unknown command succeeded (timeout).
Invalid frame succeeded..
Invalid CRC succeeded (timeout).
Invalid destination succeeded (timeout).
T_APPL_IDLE_N1 test passed.
T_APPL_OPEN_1 test. Meter returns DisconnectMode.
T_APPL_OPEN_1 test passed.
T_APPL_IDLE_N1 test. Meter returns DisconnectMode.
APPL_OPEN_4 test. Subtest 2 Invalid Protocol-version succeeded. Connection is permanently rejected. No Common AcseVersion.
APPL_OPEN_4 passed.
T_APPL_OPEN_5 test. Meter returns DisconnectMode.
T_APPL_OPEN_5 test UNKNOWN ApplicationContextName succeeded. Connection is permanently rejected. The application context name is not supported.
T_APPL_OPEN_5 test passed.
T_APPL_OPEN_6 test. Meter returns DisconnectMode.
T_APPL_OPEN_6 test passed.
T_APPL_OPEN_7 test. Meter returns DisconnectMode.
COSEM Application T_APPL_OPEN_9 passed.
T_APPL_OPEN_11 test. Meter returns DisconnectMode.
T_APPL_OPEN_12 test. Meter returns DisconnectMode.
T_APPL_OPEN_14 test. Meter returns DisconnectMode.
T_APPL_OPEN_14 test. succeeded with PDU size 11.
T_APPL_DATA_LN_N1 subtest 1. Invalid Get request succeeded.
T_APPL_DATA_LN_N1 subtest 2 succeeded. Invalid Get request succeeded.
T_APPL_DATA_LN_N1 subtest 3 failed for Short Name referencing. Exception response. "Service not allowed"-exception. Service not supported
T_APPL_DATA_LN_N3 test. Invalid Set request succeeded.
T_APPL_DATA_LN_N3 passed.
T_APPL_DATA_LN_N4 test. Meter returns DisconnectMode.
T_APPL_DATA_LN_N4 passed.
APPL_REL_P1 test. Meter returns DisconnectMode.
APPL_REL_P1 passed.
Firmware version is not available.
0.0.40.0.0.255
Ch. 0 Current association AssociationLogicalName.
0.0.40.0.1.255
Ch. 0 Association #1 AssociationLogicalName.
0.0.1.0.0.255
Ch. 0 Clock object #1 Clock.
0.0.42.0.0.255
Ch. 0 COSEM Logical device name Data.
0.0.96.1.0.255
Ch. 0 Device ID 1, manufacturing number Data.
1.0.1.7.0.255
Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value Register.
1.0.3.7.0.255
Ch. 0 Sum Li Reactive power+ (QI+QII) Inst. value Register.
1.0.9.7.0.255
Ch. 0 Sum Li Apparent power+ (QI+QIV) Inst. value Register.
1.0.14.7.0.255
Ch. 0 Supply frequency Inst. value Register.
1.0.13.7.0.255
Ch. 0 Sum Li Power factor Inst. value Register.
1.1.21.7.0.255
Ch. 1 L1 Active power+ (QI+QIV) Inst. value Register.
1.2.21.7.0.255
Ch. 2 L1 Active power+ (QI+QIV) Inst. value Register.
1.3.21.7.0.255
Ch. 3 L1 Active power+ (QI+QIV) Inst. value Register.
1.1.23.7.0.255
Ch. 1 L1 Reactive power+ (QI+QII) Inst. value Register.
1.2.23.7.0.255
Ch. 2 L1 Reactive power+ (QI+QII) Inst. value Register.
1.3.23.7.0.255
Ch. 3 L1 Reactive power+ (QI+QII) Inst. value Register.
1.0.1.8.0.255
Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) Register.
1.0.2.8.0.255
Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) Register.
1.0.3.8.0.255
Ch. 0 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 0 (0 is total) Register.
1.0.4.8.0.255
Ch. 0 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 0 (0 is total) Register.
1.0.31.7.0.255
Ch. 0 L1 Current Inst. value Register.
1.0.51.7.0.255
Ch. 0 L2 Current Inst. value Register.
1.0.71.7.0.255
Ch. 0 L3 Current Inst. value Register.
1.0.32.7.0.255
Ch. 0 L1 Voltage Inst. value Register.
1.0.52.7.0.255
Ch. 0 L2 Voltage Inst. value Register.
1.0.72.7.0.255
Ch. 0 L3 Voltage Inst. value Register.
1.0.99.1.0.255
Invalid Register.
1.0.99.2.0.255
Invalid Register.
0.0.22.0.0.255
Ch. 0 IEC HDLC setup IecHdlcSetup.
Testing multiple references support using 2 data object(s).
Multiple references support succeeded.
1 year 6 months ago
Hi, You haven't implemented…
You haven't implemented the clock. If there is no RTC clock, the inactivity timeout tests fail.
MikeAtson
1 year 6 months ago
I already implement clock…
I already implement clock but still there is error.
Test Report: stmkit
Ran for 00:04:17.0916636
Start Time: 25.04.2025 11:07:26
HDLC Setup default inactivity timeout value is 0 seconds.
Authentication level: High
Proposed services:
Supported services:
Total amount of objects: 69
Logical Device Name is: GRX0000121212120 .
Meter time: 25.04.2025 11:11:29.
Errors
Test #1 failed.
Test #2 failed.
Timeout.
Test #7 failed.
Test #15 failed.
Test #16 failed.
Test #17 failed.
Empty service test failed. Invalid conformance.
BlockTransferWithGetOrRead service failed.
Warnings
Info
Meter returns Unacceptable Frame.
APPL_OPEN_4 passed.
T_APPL_OPEN_7 passed.
T_APPL_OPEN_9 test. Meter returns DisconnectMode.
T_APPL_OPEN_14 test passed.
T_APPL_DATA_LN_N1 subtest 2 succeeded. Invalid Get request non-existing object succeeded.
T_APPL_DATA_LN_N1 passed.
APPL_REL_P1 passed.
0.0.40.0.0.255
0.0.40.0.1.255
0.0.1.0.0.255
0.0.42.0.0.255
0.0.96.1.0.255
1.0.0.8.4.255
Ch. 0 Recording interval 1, for load profile Data.
1.0.0.8.0.255
Ch. 0 Measurement period 1, for averaging scheme 1 Data.
1.0.1.4.0.255
Ch. 0 Sum Li Active power+ (QI+QIV) Current avg. 1 Rate 0 (0 is total) DemandRegister.
1.0.2.4.0.255
Ch. 0 Sum Li Active power- (QII+QIII) Current avg. 1 Rate 0 (0 is total) DemandRegister.
1.0.1.6.0.255
Ch. 0 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total) ExtendedRegister.
1.0.2.6.0.255
Ch. 0 Sum Li Active power- (QII+QIII) Max. 1 Rate 0 (0 is total) ExtendedRegister.
1.0.99.1.0.255
Ch. 0 Load profile with recording period 1 #1 ProfileGeneric.
1.0.41.7.0.255
Ch. 0 L2 Active power+ (QI+QIV) Inst. value Register.
1.0.61.7.0.255
Ch. 0 L3 Active power+ (QI+QIV) Inst. value Register.
1.0.1.7.0.255
1.0.22.7.0.255
Ch. 0 L1 Active power- (QII+QIII) Inst. value Register.
1.0.42.7.0.255
Ch. 0 L2 Active power- (QII+QIII) Inst. value Register.
1.0.62.7.0.255
Ch. 0 L3 Active power- (QII+QIII) Inst. value Register.
1.0.2.7.0.255
Ch. 0 Sum Li Active power- (QII+QIII) Inst. value Register.
1.0.23.7.0.255
Ch. 0 L1 Reactive power+ (QI+QII) Inst. value Register.
1.0.43.7.0.255
Ch. 0 L2 Reactive power+ (QI+QII) Inst. value Register.
1.0.63.7.0.255
Ch. 0 L3 Reactive power+ (QI+QII) Inst. value Register.
1.0.3.7.0.255
1.0.24.7.0.255
Ch. 0 L1 Reactive power- (QIII+QIV) Inst. value Register.
1.0.44.7.0.255
Ch. 0 L2 Reactive power- (QIII+QIV) Inst. value Register.
1.0.64.7.0.255
Ch. 0 L3 Reactive power- (QIII+QIV) Inst. value Register.
1.0.4.7.0.255
Ch. 0 Sum Li Reactive power- (QIII+QIV) Inst. value Register.
1.0.9.7.0.255
1.0.10.7.0.255
Ch. 0 Sum Li Apparent power- (QII+QIII) Inst. value Register.
1.0.32.7.0.255
1.0.52.7.0.255
1.0.72.7.0.255
1.0.31.7.0.255
1.0.51.7.0.255
1.0.71.7.0.255
1.0.14.7.0.255
1.0.33.7.0.255
Ch. 0 L1 Power factor Inst. value Register.
1.0.53.7.0.255
Ch. 0 L2 Power factor Inst. value Register.
1.0.73.7.0.255
Ch. 0 L3 Power factor Inst. value Register.
1.0.13.7.0.255
1.0.84.7.0.255
Ch. 0 Sum Li Power factor- Inst. value Register.
1.0.1.8.0.255
1.0.2.8.0.255
1.0.6.8.0.255
Ch. 0 Sum Li Reactive power QII Time integral 1 Rate 0 (0 is total) Register.
1.0.8.8.0.255
Ch. 0 Sum Li Reactive power QIV Time integral 1 Rate 0 (0 is total) Register.
1.0.5.8.0.255
Ch. 0 Sum Li Reactive power QI Time integral 1 Rate 0 (0 is total) Register.
1.0.7.8.0.255
Ch. 0 Sum Li Reactive power QIII Time integral 1 Rate 0 (0 is total) Register.
1.0.15.8.0.255
Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 0 (0 is total) Register.
1.0.21.8.0.255
Ch. 0 L1 Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) Register.
1.0.41.8.0.255
Ch. 0 L2 Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) Register.
1.0.61.8.0.255
Ch. 0 L3 Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) Register.
1.0.22.8.0.255
Ch. 0 L1 Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) Register.
1.0.42.8.0.255
Ch. 0 L2 Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) Register.
1.0.62.8.0.255
Ch. 0 L3 Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) Register.
1.0.1.8.1.255
Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 1 (0 is total) Register.
1.0.1.8.2.255
Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 2 (0 is total) Register.
1.0.1.8.3.255
Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 3 (0 is total) Register.
1.0.1.8.4.255
Ch. 0 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 4 (0 is total) Register.
1.0.2.8.1.255
Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 1 (0 is total) Register.
1.0.2.8.2.255
Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 2 (0 is total) Register.
1.0.2.8.3.255
Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 3 (0 is total) Register.
1.0.2.8.4.255
Ch. 0 Sum Li Active power- (QII+QIII) Time integral 1 Rate 4 (0 is total) Register.
1.0.15.8.1.255
Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 1 (0 is total) Register.
1.0.15.8.2.255
Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 2 (0 is total) Register.
1.0.15.8.3.255
Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 3 (0 is total) Register.
1.0.15.8.4.255
Ch. 0 Sum Li Active power (abs(QI+QIV)+abs(QII+QIII)) Time integral 1 Rate 4 (0 is total) Register.
0.0.43.0.1.255
Ch. 0 Security setup #1 SecuritySetup.
0.0.22.0.0.255
Testing multiple references support using 4 data object(s).
Clock time access for 0.0.1.0.0.255 is Read
Clock time zone access for 0.0.1.0.0.255 is Read
Read service test failed. ServiceNotSupported
Write service test succeeded. ServiceNotSupported
Attribute0SupportedWithGet service test succeeded. ServiceNotSupported
BlockTransferWithSetOrWrite service test succeeded. ServiceNotSupported
MultipleReferences service test succeeded. ServiceNotSupported
Set service test succeeded. ServiceNotSupported
SelectiveAccess service test succeeded. ServiceNotSupported
1 year 6 months ago
Hi, Are you using the Gurux…
Are you using the Gurux DLMS server, or is this your implementation?
Those are basic tests that fails. The only reason I can think is that your meter is not handling the UART correctly, or there is something else strange. Make sure that you don't overwrite buffers when you are reading UART.
MikeAtson1
1 year 6 months ago
Hi, This is Gurux Dlms…
This is Gurux Dlms Server Example. However, I already check my uart buffer size and this is ring buffer. However , i can not still find solution. Is there any suggestion about debugging ?
1 year 6 months ago
Hi, I tested Test #1 and it…
I tested Test #1 and it succeeded. Let's check this test at the time.
Can you get Test1 messages as a hex string?
MikeAtson1
1 year 6 months ago
Hi, 11:51:52 Initializing…
11:51:52 Initializing serial connection.
11:51:53 Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
11:51:53
7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
11:51:53 Parsing UA reply succeeded.
11:51:53 Send AARQ request.
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 62 1E 5D FF FF 88 55 7E
11:51:53
7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1E 1D 02 00 00 07 7A ED 7E
11:51:53 Parsing AARE reply succeeded.
11:51:53 Disconnect request
11:51:53 HDLC test #1. Disconnect request
7E A0 07 03 21 53 03 C7 7E
11:51:53
11:51:53 HDLC test #1. SNRM request
11:51:53
11:51:53 HDLC test #1. Receiver Ready
7E A0 07 03 21 11 15 A6 7E
11:52:18 Data send failed. Try to resend 1/3
11:52:18
7E A0 07 21 03 11 15 00 7E 7E A0 07 21 03 97 2B E1 7E
11:52:18 Disconnect request
11:52:18 HDLC test #1. Disconnect request
11:52:18
MikeAtson1
1 year 6 months ago
Hi, Is there any update ?
MikeAtson1
1 year 6 months ago
Hi, I still not found…
I still not found solution
