  3. How To Use Object Methods?
How to use object methods?
Profile picture for user Frank
By Frank , 10 March, 2025
I have been exploring the library and I am wondering how to use the object methods.
Using a GXDLMSRegister object as am example, it has a Reset method that takes a gxdlmsclient input. i tried to pass a secure client to it and nothing happened. I tried reading after running the method but it throws unacceptable frame error.
I can also see that it returns a byte[][]. Do I have to write this bytes to the meter? but the write method in the communicator class takes an gxdlmsobject and attribute index as an input.
i tried to follow the director code but its a little hard to find the button binding because the selectedview is dynamically generated by which i meant that the ui is not created in the designer so its a bit hard to follow the ui bindings.
Lastly, to the dev team, I've been learning a lot about coding just from reviewing your library/products. Thanks for being FOSS as well as for being responsive!!
Frank
1 year 7 months ago
Hi So, i've tried debugging…
So, i've tried running the director in debug mode and was able to somewhat get how it is done??
GXDLMSSecureClient client = dev.Comm.client;
GXActionArgs ve = new GXActionArgs(RegisterObject, 1);
ve.Client = client;
dev.KeepAliveStop();
ve.Action = ActionType.Action;
ve.Value = (sbyte)0;
if (ve.Index < 0 || ve.Client.CanInvoke(ve.Target, ve.Index))
dev.Comm.MethodRequest(ve.Target, ve.Index, ve.Value, ve.Text, reply);
object data = dev.Comm.ReadValue(ve.Target, ve.Index);
im wondering how i can utilize the built in methods in the objects tho since it is already there
object ob = RegisterObject.Reset(client);
Edit:
so far this is the implementation that i have mocked up
GXDLMSSecureClient client = GXDevice.Comm.client;
GXDevice.KeepAliveStop();
byte[][] ob = RegisterObject.Reset(client);
string str = string.Format("Method object {0}, interface {1}", RegisterObject.LogicalName, RegisterObject.ObjectType);
foreach (byte[] it in ob)
reply.Clear();
GXDevice.Comm.ReadDataBlock(it, str, 1, reply);
//GXDevice.Comm.ReadValue(RegisterObject, 2);
GXDevice.Comm.Read(null, RegisterObject, false);
RefreshData();
GXDevice.KeepAliveStart();
maybe there is a more straightforward way for this?
1 year 7 months ago
Hi, the method generates the…
the method generates the bytes and you need to send the generated bytes to the meter like this:
GXDLMSRegister r = new GXDLMSRegister();
byte[][] data = r.Reset(client);
ReadDataBlock(data, reply);
Frank
1 year 7 months ago
hi mikko thanks for the…
hi mikko
thanks for the reply^^
that is what i do now, thank you!
