  3. Cannot Read Meter Via HDLC With Multi Reference
Cannot read meter via HDLC with multi reference
By lah , 9 September, 2024
Gurux.Net
I have an issue with reading Landis E650 meter, when I try to read it with multi ref (Client.ReadList method) it does not work but if I read the same thing with single ref (Client.Read) it works as expected. Meter is connected via hdlc.
I was able to reproduce the issue in GXDLMSDirector with following steps:
- Connect to meter via HDLC
- Reading of objects goes through normally as expected
- Try to read any received objects, for example "CosemLogicalDeviceName"
- When "Read" is used it works as expected, when "ReadObject" is used it fails, logs below:
GXDLMSDirector 9.0.2405.2803
Log created 10:34:26
10:34:31 Read object type Data index: 2
7E A0 14 00 02 A0 75 41 32 21 64 E6 E6 00 05 01 02 FD 08 10 D3 7E
10:34:31
7E A0 24 41 00 02 A0 75 52 24 3D E6 E7 00 0C 01 00 09 10 4C 47 5A 35 31 32 35 39 32 39 38 00 00 00 00 00 20 EF 7E
10:34:34
7E A0 14 00 02 A0 75 41 54 11 62 E6 E6 00 05 01 02 FD 08 10 D3 7E
10:34:34
7E A0 24 41 00 02 A0 75 74 10 79 E6 E7 00 0C 01 00 09 10 4C 47 5A 35 31 32 35 39 32 39 38 00 00 00 00 00 20 EF 7E
System.Exception: Invalid reply. Read items count do not match.
at GXDLMSDirector.GXDLMSCommunicator.ReadList(List`1 list)
at GXDLMSDirector.MainForm.Read(Object sender, GXAsyncWork work, Object[] parameters)
I have the same issue in my software, I am using latest available version of gurux.net. Am I doing something wrong or is there an issue in the gurux library?
I can provide more information if needed.
2 years 1 month ago
Hi, Your data looks correct…
Your data looks correct. We'll check what might cause this.
2 years 1 month ago
Hi, You are reading only one…
You are reading only one value with ReadList and that is causing this. This is fixed for the next version.
2 years 1 month ago
Hi, This is fixed and the…
This is fixed and the new version is released today.
