  3. Unable To Connect Electric Smart Meter.(aarq Request Failed)
Unable to connect electric smart meter.(aarq request failed)
By jayaram , 23 August, 2024
Gurux.Net
GXDLMSSecureClient sclient = new GXDLMSSecureClient();
GXNet gXNet = new GXNet(NetworkType.Tcp, "ip address", 4059);
sclient.UseLogicalNameReferencing = true;
// Is used HDLC or COSEM transport layers for IPv4 networks (IEC 62056-47)
sclient.InterfaceType = InterfaceType.WRAPPER;
sclient.ClientAddress = 32;
sclient.ServerAddress = 1;
sclient.Authentication = Authentication.Low;
sclient.Password = ASCIIEncoding.ASCII.GetBytes("123456");
sclient.Ciphering.SecuritySuite = SecuritySuite.Suite0;
sclient.Ciphering.Security = Security.AuthenticationEncryption;
sclient.Ciphering.SystemTitle = GXCommon.HexToBytes("7177657274797569");
sclient.Ciphering.BlockCipherKey = GXCommon.HexToBytes("62626262626262626262626262626262");
sclient.Ciphering.AuthenticationKey = GXCommon.HexToBytes("62626262626262626262626262626262");
sclient.Ciphering.Signing = Signing.None;
Media = gXNet as IGXMedia;
Media.Open();
byte[] data;
data = sclient.SNRMRequest();
if (data != null)
ReadDLMSPacket(data, reply);
sclient.ParseUAResponse(reply.Data);
//Generate AARQ request.
//Split requests to multiple packets if needed.
//If password is used all data might not fit to one packet.
foreach (byte[] it in sclient.AARQRequest())
Console.WriteLine("Send AARQ request-{0}", GXCommon.ToHex(it, true));
reply.Clear();
reply = ReadDLMSPacket(it, reply);
//Parse reply.
sclient.ParseAAREResponse(reply.Data);
Console.WriteLine("Conformance: " + sclient.NegotiatedConformance);
Console.WriteLine(sclient.ConnectionState);
byte[][] obj = sclient.Read("0.0.42.0.0.255", ObjectType.Data, 2);
/// Read Association View from the meter.
reply = new GXReplyData();
ReadDataBlock(obj, reply);
public static GXReplyData ReadDLMSPacket(byte[] data, GXReplyData reply)
if (data == null)
return reply;
object eop = (byte)0x7E;
//In network connection terminator is not used.
int pos = 0;
bool succeeded = false;
ReceiveParameters<byte[]> p = new ReceiveParameters<byte[]>()
AllData = true,
Eop = eop,
Count = 5,
WaitTime = 5000,
lock (Media.Synchronous)
while (!succeeded && pos != 3)
Media.Send(data, null);
succeeded = Media.Receive(p);
Console.WriteLine("Response-{0}", GXCommon.ToHex(p.Reply, true));
if (!succeeded)
//If Eop is not set read one byte at time.
if (p.Eop == null)
p.Count = 1;
//Try to read again...
if (++pos != 3)
System.Diagnostics.Debug.WriteLine("Data send failed. Try to resend " + pos.ToString() + "/3");
continue;
throw new Exception("Failed to receive reply from the device in given time.");
//Loop until whole COSEM packet is received.
while (!client.GetData(p.Reply, reply))
if (p.Eop == null)
p.Count = 1;
if (!Media.Receive(p))
if (pos != 3)
continue;
if (reply.Error != 0)
throw new GXDLMSException(reply.Error);
return reply;
2 years ago
Hi, Please, don't copy the…
Please, don't copy the example code. It doesn't say anything about the problem.
Are you getting any reply from the meter?
I believe that one of your settings is different than the meter expects.
Try to connect with GXDLMSDirector to get the correct settings.
jayaram
2 years ago
I am connection with wrapper…
I am connection with wrapper interface type but its not working and i tried with gxdlmsdirector it is working
Send AARQ request-00 01 00 20 00 01 00 55 60 53 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 08 80 06 31 32 33 34 35 36 BE 23 04 21 21 1F 30 00 00 00 02 B9 C9 87 9D 5B 75 7F 27 5C 00 73 25 83 4B 71 A9 03 13 C6 2F 58 AC 36 10 5F 48
Response-00 01 00 01 00 20 00 0C 4E 45 58 45 52 52 4F 52 4E 4F 2D 31
2 years ago
Hi, Can you add the first…
Can you add the first message that GXDLMSDirector sends? I can get the correct settings for you.
I believe that you are reading the Innovation counter with GXDLMSDirector and that is causing the issue.
jayaram
2 years ago
Hi, Issue is resolved.I set …
Issue is resolved.I set object eop = null instead of object eop = (byte)0x7E;
but now meter is responding properly for the first time after that if i try to connect second time its showing serviceerror Initiate error exception.
If i turned off the meter and turned on again then its working.what may be the reason?
2 years ago
Hi, At first, ask if there…
At first, ask if there is a firmware update available for the meter.
Did you call close after you have read the values from the meter?
jayaram
2 years ago
Hi, Yes,after reading values…
Yes,after reading values from meter i am sending releaserequest and disconnection request.
2 years ago
Hi, Don't send the release…
Don't send the release message. Send just disconnect. That might help with some meters. Can you connect with GXDLMSDirector?
jayaram
2 years ago
Hi, Tried by sending only…
Tried by sending only disconnection request but still not working.
ReadDLMSPacket(Client.DisconnectRequest(), reply);
RX:7E A0 07 03 41 53 56 A2 7E
TX:
but if i try with guruxdlmsdirector UI its working.
