  2. Read All The Rows For Billing Profile
Read All the Rows for Billing Profile
By SmartMeterAndroid , 27 August, 2024
Gurux DLMS for Android
Currently we are using readrowbyrange() is getting single row value.
We need to read all the row values. What api can i use for this?
Kindly help here.
Your response is much appreciated.
1 year 11 months ago
Hi, You can use normal read…
You can use normal read to that.
GXDLMSProfileGeneric pg = new GXDLMSProfileGeneric();
Read(pg, 2);
Check also this:
SmartMeterAndroid
We are getting still single…
We are getting still single row object only.
var cells: Array<Any?>? = arrayOf(read(obj, 2)); //Object[1]
for (rows: Any? in cells!!) {
Hi, Access rows using Buffer…
Access rows using Buffer:
obj.getBuffer();
The meter returns all rows when you are calling the read.
