  3. Sample Example Code To IP Data Read
Sample example code to IP Data Read
By krunal.chauhan.637 , 13 August, 2024
Hi Team,
We are using latest GuruxDLMS.c with Version 20240813.1
Can you please share Sample example code to read IP Data using MR profile ?
Which include all sequence and all user application API.
Thank You !!!
Best Regards,
Krunal Chauhan
krunal.chauhan.637
2 years 2 months ago
Notify Enable
Notify Enable
Hi, Connect to the meter and…
Connect to the meter and then you can read the IP.
Send SNRM if you are using serial port connection.
Send AARQ.
Read IP.
Close connection.
krunal.chauhan.637
Can you please share sample…
Can you please share sample C code to read IP Data using DLMS C language library ?
I need to port this library on RTOS base Controller
I am new to this library. It will help me lot
Hi, Check this example. It…
Check this example. It will do what you want to do. Just change logical name.
https://github.com/Gurux/GuruxDLMS.c/blob/92959cbd3ce88576d48a056c39431…
Note! Instant Profile might need a lot of heap if you parse them to the memory.
krunal.chauhan.637
As I can see two example…
As I can see two example given in git folder.
Arduino_IDE or GuruxDLMSClientExample
Which example code is appropriate for controller from below ?
Hi, If you are using MCU,…
If you are using MCU, check Arduino_IDE.
