  3. Gx Serial In Python
gx Serial in Python
By Farith , 8 July, 2024
Gurux.Serial
Good day, i need help with the python code to read data to a hexing meter using an optical eye
i have tried the GXSerial python library but i cant get to be able to read any data from the meter
2 years 2 months ago
Hi, Try to read the meter…
Try to read the meter with GXDLMSDirecto first. It will show the correct command line arguments. One of your settings is different than the meter expects.
Farith
thanks for the quick…
thanks for the quick response,
can you kindly show me with an example on how to find the correct meter arguments and where to inside it on the GX python scrip cause on GXDLMSDirector its able to read
