  3. Facing Issue After Windows 11 Installation While Reading The Profile (Serial Interface) Using Python
Facing Issue after windows 11 installation while reading the profile (Serial Interface) using Python
By Thangalakshmi , 5 July, 2024
Gurux.Serial
windows 10 its running fine but after windows 11 installation not able to read profiles
Thangalakshmi
2 years 4 months ago
gurux_dlms version: 1.0.155…
i tried but its disconnected. But same script its running Windows 10.
gurux_net version: 1.0.21
gurux_serial version: 1.0.20
Authentication: 2
ClientAddress: 0x30
Standard: 1
Security: 48
System title: 71 77 65 72 74 79 75 69
Authentication key: 41 45 57 5F 50 57 52 5F 41 4B 5F 45 4B 5F 32 34
Block cipher key: 41 45 57 5F 50 57 52 5F 41 4B 5F 45 4B 5F 32 34
Kindly help me.
Thangalakshmi
Hello Mikko, Help me
2 years 3 months ago
Hi, One of your settings is…
One of your settings is different, or there are new rows on the meter that cause this. There is nothing that might affect for profile generic reading.
Check if you can read the profile generic with GXDLMSDirector.
Thangalakshmi
After window 11 installation…
After window 11 installation I am facing GXDLMSDirector also.
I checked all the keys but its showing error like: connection is permanently rejected. No reason is given
Thangalakshmi
Hi Miko, pls help me
Hi Miko, help me
One of your settings is different than the meter expects. Can you connect with authentication level None?
Thangalakshmi
Hi Mikko, Yes, I tried but…
Yes, I tried but same thing happen.Its showing error like: connection is permanently rejected. No reason is given
Hi, You must use the client…
You must use the client address 0x10 when connecting without an authentication level. Are you using it? If you are, try to reboot the meter.
Thangalakshmi
Hello Mikko, Tried but still…
Hello Mikko,
Tried but still same issue.
Hi, Did you change the…
Did you change the client address to 10 when connecting without authentication?
Thangalakshmi
Hi Mikko, Yes, Without…
Yes, Without authentication its working but US(Utility Setting) mode its not working.
Hi, Have you set the…
Have you set the authentication key and block cipher key?
