  3. Transport Endpoint Is Not Connected
Transport endpoint is not connected
By Mahaveer , 28 June, 2024
Gurux.Net
Hi Team,
I have used gurux libararies for read meter data and everything is working fine in my local machine (Windows OS). The same code I have deployed on server where we are using docker container on linux os. On linux meter is not connecting and getting error as below.
SocketException: at Gurux.Net.GXNet.ClientConnect(EndPoint ep)
at Gurux.Net.GXNet.Open()
at CorrelationEngineMS.GuruxDlms.GuruxDLMS.InitDlms(MeterRequest meterRequest)
Can you please suggest me some point, why getting this kind of error.
From server where I deployed same code, I checked telnet of meter IP and port and working fine. But the issue is with .net code it's not connecting.
2 years 4 months ago
Hi, Check that there is no…
Check that there is no firewall, etc that might block the connection. Transport endpoint is not connected is TCP/IP error and TCP/IP connection fails for some reason.
