  2. Read Values From DLMS
Read values from DLMS
By akshy, 18 April, 2024
Gurux.Net
Hi, I need to read values properly in correct format, right now I'm getting below hexa values: I need a correct values like current;=10.5 and voltage:240, how i can convert hexa to human values please suggest it is very urgent
Current:
TX: 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 EA A9 34 80 04 CB 82 40 40 D4 90 15 CB 44 7A 51 31 7B E4 0C 1D E1 AB 10 05 FF
RX: 00 01 00 01 00 30 00 1D CC 1B 30 00 00 01 E6 B8 E1 5C 66 0E AA 21 0E 0C 13 DB 28 B4 E9 B7 92 F8 CC DD 5E 0A EE
Voltage:
TX: 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 EB 90 F6 38 A8 EB 78 24 82 44 33 22 1A B4 01 E4 D7 B1 72 C5 3F 5F 7F 43 7F 19
RX: 00 01 00 01 00 30 00 1D CC 1B 30 00 00 01 E7 27 EF E3 42 D5 DC C8 09 0F B6 8C 38 E2 A6 38 14 86 E4 1B 72 F2 CF
1 year 9 months ago
Hi, I propose that you use…
I propose that you use Gurux open source libraries. DLMS is not an easy protocol and you can't just convert received binary data to ASCII.
https://github.com/gurux
akshy
1 year 9 months ago
Is there any way I need to…
Is there any way I need to convert into real values above which i mentioned those are hexa string i tired to convert into real values which is showing in dlms director...
1 year 9 months ago
Hi, Data is not a hex string…
Data is not a hex string. DLMS is a binary protocol. You need to parse the data, then handle it and show it as a string.
akshy
1 year 9 months ago
Please provide me sample if…
Please provide me sample if you have to convert the protocol into string.
1 year 9 months ago
Hi, It's not so simple…
It's not so simple. There are hundreds of pages in the standard. Your meter is also using a ciphered connection which makes it more difficult.
  • Wed, 01/14/2026 - 14:29
    Gurux.DLMS.Python 1.0.196
  • Mon, 12/29/2025 - 10:38
    Gurux.Serial.Android 3.0.5
  • Mon, 12/15/2025 - 08:11
    Gurux.DLMS.Net 4.0.87
  • Fri, 12/12/2025 - 08:38
    Gurux.DLMS.Python 1.0.195
  • Thu, 12/11/2025 - 13:22
    Gurux.DLMS.Python 1.0.194
  • 6-digit field values from meter not fully received (only 5 digits shown)
  • Gurux DLMS Android App
