  2. I Am Making Disconnection Request But Facing This Issue
i am making disconnection request but facing this issue
By Akash , 16 April, 2024
Gurux DLMS for Android
Some times disconnection request is working
but some times i am getting this issue
Tx: 7E A0 1F 03 61 93 10 61 81 80 13 05 01 80 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 B4 F9 7E
System.out gurux.dlms.android Disjava.lang.IllegalArgumentException: Data send failed.
2 years 1 month ago
Hi, I believe that you are…
I believe that you are using a serial port connection. This error might happen if the data send failed for some reason. What USB to serial port model you are using?
Akash
2 years 1 month ago
i am using BSC12X1 - Optical…
i am using
BSC12X1 - Optical Probe
and FT232R Serical (UART) IC MODEL
2 years 1 month ago
Hi, FTDI buffer size is 64…
FTDI buffer size is 64 bytes and your data should be without problems to the buffer. How often this is happening? This is now tried with FTDI chipset and it works without any problems. What is your Android version?
