  3. Gurux.Python, Attribute2 Is Not Readable, L+G E650
Gurux.Python, Attribute2 is not readable, L+G E650
By simeon , 20 March, 2024
Gurux.Serial
I have a problem with reading L+G E650 over RS485.
I received some strange errors:
- Err! Failed to read columns:Access Error : Device reports Read-Write denied.
- Attribute2 is not readable.
I tried to read object without password. These OBIS codes was red with .MAP110 without issues, but with Gurux.DLMS.Client.Example there are a issues.
Also i tried with -a Low -P xxxxxxxx - again with .MAP110 is OK, but cannot read with gurux.python.
Command: python3 main.py -S /dev/ttyUSB0 -s 1 -c 16 -r sn -t Verbose
Output:
gurux_dlms version: 1.0.149
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
Authentication: 0
ClientAddress: 0x10
Standard: 0
TX: 11:30:07 7E A0 07 03 21 93 0F 01 7E
RX: 11:30:07 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 11:30:07 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
RX: 11:30:08 7E A0 37 21 03 30 6C 7C E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 0A A8 7E
TX: 11:30:08 7E A0 11 03 21 32 B7 3D E6 E6 00 05 01 02 FA 08 18 9E 7E
RX: 11:30:08 7E A8 5B 21 03 52 88 68 E6 E7 00 0C 01 00 01 82 01 41 02 04 10 00 10 12 27 30 11 01 09 06 00 00 F0 0D 00 FF 02 04 10 01 18 12 27 12 11 08 09 06 00 00 F0 00 00 FF 02 04 10 01 88 12 27 60 11 04 09 06 00 00 F0 0F FF FF 02 04 10 04 48 12 00 03 11 00 09 06 00 00 61 61 00 FF 06 90 7E
TX: 11:30:08 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:08 7E A8 51 21 03 54 10 D1 02 04 10 48 A0 12 00 03 11 00 09 06 00 00 60 F0 0C FF 02 04 10 2B C0 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 04 10 04 E8 12 00 01 11 00 09 06 01 00 00 02 08 FF 02 04 10 C7 38 12 00 14 11 00 09 06 00 00 0D 00 00 FF C8 CD 7E
TX: 11:30:08 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:08 7E A8 51 21 03 56 02 F2 02 04 10 C8 00 12 00 0B 11 00 09 06 00 00 0B 00 00 FF 02 04 10 05 58 12 00 03 11 00 09 06 01 00 00 02 07 FF 02 04 10 05 C0 12 00 03 11 00 09 06 00 00 60 02 07 FF 02 04 10 06 28 12 00 01 11 00 09 06 00 00 F0 13 01 FF 27 65 7E
TX: 11:30:08 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:08 7E A8 51 21 03 58 7C 1B 02 04 10 06 58 12 00 13 11 00 09 06 00 00 14 00 00 FF 02 04 10 06 D8 12 00 13 11 00 09 06 00 00 14 00 01 FF 02 04 10 07 58 12 00 17 11 00 09 06 00 00 16 00 00 FF 02 04 10 07 C0 12 00 17 11 00 09 06 00 01 16 00 00 FF 38 1C 7E
TX: 11:30:08 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:09 7E A8 51 21 03 5A 6E 38 02 04 10 08 28 12 27 1E 11 01 09 06 00 00 60 06 03 FF 02 04 10 FA 00 12 00 0C 11 00 09 06 00 00 28 00 00 FF 02 04 10 08 70 12 27 21 11 0A 09 06 00 00 F0 0A 00 FF 02 04 10 09 10 12 27 24 11 03 09 06 00 00 F0 0C 00 FF D7 0E 7E
TX: 11:30:09 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:09 7E A8 51 21 03 5C 58 5D 02 04 10 09 30 12 27 22 11 00 09 06 00 00 F0 03 00 FF 02 04 10 67 20 12 27 74 11 07 09 06 00 00 F0 01 00 FF 02 04 10 FC 00 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 04 10 09 50 12 27 38 11 06 09 06 00 00 F0 07 00 FF FB BE 7E
TX: 11:30:09 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:09 7E A8 51 21 03 5E 4A 7E 02 04 10 C6 70 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 04 10 09 78 12 00 03 11 00 09 06 00 00 60 5A 02 FF 02 04 10 09 E0 12 00 03 11 00 09 06 00 01 60 F0 08 FF 02 04 10 C0 F8 12 00 03 11 00 09 06 00 02 60 F0 09 FF 6B 16 7E
TX: 11:30:09 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:09 7E A8 51 21 03 50 34 97 02 04 10 C1 C0 12 00 03 11 00 09 06 00 02 60 F0 08 FF 02 04 10 0A 48 12 29 A4 11 01 09 06 00 00 60 32 00 FF 02 04 10 60 E0 12 00 07 11 01 09 06 01 00 63 62 00 FF 02 04 10 62 70 12 00 07 11 01 09 06 01 00 63 01 00 FF ED C5 7E
TX: 11:30:09 7E A0 07 03 21 31 17 87 7E
RX: 11:30:09 7E A8 51 21 03 52 26 B4 02 04 10 64 00 12 00 07 11 01 09 06 00 00 62 01 00 7E 02 04 10 0A A8 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 04 10 0B B0 12 00 03 11 00 09 06 01 01 01 08 01 FF 02 04 10 0C 58 12 00 03 11 00 09 06 01 01 01 08 02 FF CF DC 7E
TX: 11:30:09 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:10 7E A8 51 21 03 54 10 D1 02 04 10 0D 00 12 00 03 11 00 09 06 01 01 01 08 03 FF 02 04 10 0D A8 12 00 03 11 00 09 06 01 01 02 08 01 FF 02 04 10 0E 50 12 00 03 11 00 09 06 01 01 02 08 02 FF 02 04 10 0E F8 12 00 03 11 00 09 06 01 01 02 08 03 FF 2C 08 7E
TX: 11:30:10 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:10 7E A8 51 21 03 56 02 F2 02 04 10 0F A0 12 00 03 11 00 09 06 01 01 03 08 01 FF 02 04 10 10 48 12 00 03 11 00 09 06 01 01 03 08 02 FF 02 04 10 10 F0 12 00 03 11 00 09 06 01 01 03 08 03 FF 02 04 10 11 98 12 00 03 11 00 09 06 01 01 04 08 01 FF 2D 58 7E
TX: 11:30:10 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:10 7E A8 51 21 03 58 7C 1B 02 04 10 12 40 12 00 03 11 00 09 06 01 01 04 08 02 FF 02 04 10 12 E8 12 00 03 11 00 09 06 01 01 04 08 03 FF 02 04 10 13 90 12 00 03 11 00 09 06 01 01 05 08 01 FF 02 04 10 14 38 12 00 03 11 00 09 06 01 01 05 08 02 FF 87 17 7E
TX: 11:30:10 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:10 7E A8 51 21 03 5A 6E 38 02 04 10 14 E0 12 00 03 11 00 09 06 01 01 05 08 03 FF 02 04 10 15 88 12 00 03 11 00 09 06 01 01 06 08 01 FF 02 04 10 16 30 12 00 03 11 00 09 06 01 01 06 08 02 FF 02 04 10 16 D8 12 00 03 11 00 09 06 01 01 06 08 03 FF A0 4E 7E
TX: 11:30:10 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:10 7E A8 51 21 03 5C 58 5D 02 04 10 17 80 12 00 03 11 00 09 06 01 01 07 08 01 FF 02 04 10 18 28 12 00 03 11 00 09 06 01 01 07 08 02 FF 02 04 10 18 D0 12 00 03 11 00 09 06 01 01 07 08 03 FF 02 04 10 19 78 12 00 03 11 00 09 06 01 01 08 08 01 FF 5F B4 7E
TX: 11:30:10 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:10 7E A8 51 21 03 5E 4A 7E 02 04 10 1A 20 12 00 03 11 00 09 06 01 01 08 08 02 FF 02 04 10 1A C8 12 00 03 11 00 09 06 01 01 08 08 03 FF 02 04 10 1B 70 12 00 03 11 00 09 06 01 01 01 1D 00 FF 02 04 10 1C 18 12 00 03 11 00 09 06 01 01 02 1D 00 FF 16 0F 7E
TX: 11:30:10 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:11 7E A8 51 21 03 50 34 97 02 04 10 1F A0 12 00 03 11 00 09 06 01 01 03 1D 00 FF 02 04 10 20 48 12 00 03 11 00 09 06 01 01 04 1D 00 FF 02 04 10 20 F0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 21 98 12 00 03 11 00 09 06 00 00 7F 00 00 00 C3 92 7E
TX: 11:30:11 7E A0 07 03 21 31 17 87 7E
RX: 11:30:11 7E A8 51 21 03 52 26 B4 02 04 10 22 40 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 22 E8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 1C E0 12 00 03 11 00 09 06 01 01 01 08 00 FF 02 04 10 1D 98 12 00 03 11 00 09 06 01 01 02 08 00 FF 81 F3 7E
TX: 11:30:11 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:11 7E A8 51 21 03 54 10 D1 02 04 10 1E 40 12 00 03 11 00 09 06 01 01 03 08 00 FF 02 04 10 1E F8 12 00 03 11 00 09 06 01 01 04 08 00 FF 02 04 10 23 90 12 00 03 11 00 09 06 01 01 05 08 00 FF 02 04 10 24 38 12 00 03 11 00 09 06 01 01 06 08 00 FF 4A 90 7E
TX: 11:30:11 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:11 7E A8 51 21 03 56 02 F2 02 04 10 24 E0 12 00 03 11 00 09 06 01 01 07 08 00 FF 02 04 10 25 88 12 00 03 11 00 09 06 01 01 08 08 00 FF 02 04 10 26 30 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 26 D8 12 00 03 11 00 09 06 00 00 7F 00 00 00 8B 42 7E
TX: 11:30:11 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:11 7E A8 51 21 03 58 7C 1B 02 04 10 27 80 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 28 28 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 28 D0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 29 78 12 00 03 11 00 09 06 00 00 7F 00 00 00 98 93 7E
TX: 11:30:11 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:11 7E A8 51 21 03 5A 6E 38 02 04 10 2A 20 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2A C8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2C B0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2D 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 74 B3 7E
TX: 11:30:11 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:12 7E A8 51 21 03 5C 58 5D 02 04 10 2E 00 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2E A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2F 50 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2F F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 4F 3B 7E
TX: 11:30:12 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:12 7E A8 51 21 03 5E 4A 7E 02 04 10 30 A0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 31 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 31 F0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 32 98 12 00 03 11 00 09 06 00 00 7F 00 00 00 BA E0 7E
TX: 11:30:12 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:12 7E A8 51 21 03 50 34 97 02 04 10 33 40 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 33 E8 12 00 05 11 00 09 06 01 01 01 04 00 FF 02 04 10 34 80 12 00 05 11 00 09 06 01 01 02 04 00 FF 02 04 10 35 18 12 00 05 11 00 09 06 01 01 03 04 00 FF 94 1E 7E
TX: 11:30:12 7E A0 07 03 21 31 17 87 7E
RX: 11:30:12 7E A8 51 21 03 52 26 B4 02 04 10 35 B0 12 00 05 11 00 09 06 01 01 04 04 00 FF 02 04 10 36 48 12 00 05 11 00 09 06 01 01 05 04 00 FF 02 04 10 36 E0 12 00 05 11 00 09 06 01 01 06 04 00 FF 02 04 10 38 78 12 00 05 11 00 09 06 01 01 07 04 00 FF 21 6D 7E
TX: 11:30:12 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:12 7E A8 51 21 03 54 10 D1 02 04 10 39 10 12 00 05 11 00 09 06 01 01 08 04 00 FF 02 04 10 3A 08 12 00 05 11 00 09 06 00 00 7F 00 00 00 02 04 10 3A A0 12 00 05 11 00 09 06 00 00 7F 00 00 00 02 04 10 3C 78 12 00 04 11 00 09 06 01 01 01 06 01 FF 98 69 7E
TX: 11:30:12 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:12 7E A8 51 21 03 56 02 F2 02 04 10 3D 00 12 00 04 11 00 09 06 01 01 01 06 02 FF 02 04 10 3D 88 12 00 04 11 00 09 06 01 01 01 06 03 FF 02 04 10 3E 10 12 00 04 11 00 09 06 01 01 02 06 01 FF 02 04 10 3E 98 12 00 04 11 00 09 06 01 01 02 06 02 FF C2 88 7E
TX: 11:30:12 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:13 7E A8 51 21 03 58 7C 1B 02 04 10 3F 20 12 00 04 11 00 09 06 01 01 02 06 03 FF 02 04 10 3F A8 12 00 04 11 00 09 06 01 01 05 06 01 FF 02 04 10 40 30 12 00 04 11 00 09 06 01 01 05 06 02 FF 02 04 10 40 B8 12 00 04 11 00 09 06 01 01 05 06 03 FF 8D A4 7E
TX: 11:30:13 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:13 7E A8 51 21 03 5A 6E 38 02 04 10 41 D8 12 00 04 11 00 09 06 01 01 06 06 01 FF 02 04 10 42 60 12 00 04 11 00 09 06 01 01 06 06 02 FF 02 04 10 42 E8 12 00 04 11 00 09 06 01 01 06 06 03 FF 02 04 10 43 70 12 00 04 11 00 09 06 01 01 07 06 01 FF D0 8F 7E
TX: 11:30:13 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:13 7E A8 51 21 03 5C 58 5D 02 04 10 43 F8 12 00 04 11 00 09 06 01 01 07 06 02 FF 02 04 10 44 80 12 00 04 11 00 09 06 01 01 07 06 03 FF 02 04 10 45 C0 12 00 04 11 00 09 06 01 01 08 06 01 FF 02 04 10 46 48 12 00 04 11 00 09 06 01 01 08 06 02 FF 04 45 7E
TX: 11:30:13 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:13 7E A8 51 21 03 5E 4A 7E 02 04 10 46 D0 12 00 04 11 00 09 06 01 01 08 06 03 FF 02 04 10 47 58 12 00 04 11 00 09 06 01 01 01 06 00 FF 02 04 10 47 E0 12 00 04 11 00 09 06 01 01 02 06 00 FF 02 04 10 49 80 12 00 04 11 00 09 06 01 01 05 06 00 FF 0D 84 7E
TX: 11:30:13 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:13 7E A8 51 21 03 50 34 97 02 04 10 4A 08 12 00 04 11 00 09 06 01 01 06 06 00 FF 02 04 10 4A 90 12 00 04 11 00 09 06 01 01 07 06 00 FF 02 04 10 4B 18 12 00 04 11 00 09 06 01 01 08 06 00 FF 02 04 10 4B A0 12 00 03 11 00 09 06 01 01 01 02 01 FF E8 3B 7E
TX: 11:30:13 7E A0 07 03 21 31 17 87 7E
RX: 11:30:14 7E A8 51 21 03 52 26 B4 02 04 10 4C 08 12 00 03 11 00 09 06 01 01 01 02 02 FF 02 04 10 4C 70 12 00 03 11 00 09 06 01 01 01 02 03 FF 02 04 10 4C D8 12 00 03 11 00 09 06 01 01 02 02 01 FF 02 04 10 4D 40 12 00 03 11 00 09 06 01 01 02 02 02 FF D9 4B 7E
TX: 11:30:14 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:14 7E A8 51 21 03 54 10 D1 02 04 10 4D A8 12 00 03 11 00 09 06 01 01 02 02 03 FF 02 04 10 52 50 12 00 03 11 00 09 06 01 01 05 02 01 FF 02 04 10 52 B8 12 00 03 11 00 09 06 01 01 05 02 02 FF 02 04 10 53 20 12 00 03 11 00 09 06 01 01 05 02 03 FF 9E CC 7E
TX: 11:30:14 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:14 7E A8 51 21 03 56 02 F2 02 04 10 53 88 12 00 03 11 00 09 06 01 01 06 02 01 FF 02 04 10 53 F0 12 00 03 11 00 09 06 01 01 06 02 02 FF 02 04 10 54 58 12 00 03 11 00 09 06 01 01 06 02 03 FF 02 04 10 54 C0 12 00 03 11 00 09 06 01 01 07 02 01 FF 18 C4 7E
TX: 11:30:14 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:14 7E A8 51 21 03 58 7C 1B 02 04 10 55 28 12 00 03 11 00 09 06 01 01 07 02 02 FF 02 04 10 55 90 12 00 03 11 00 09 06 01 01 07 02 03 FF 02 04 10 55 F8 12 00 03 11 00 09 06 01 01 08 02 01 FF 02 04 10 56 60 12 00 03 11 00 09 06 01 01 08 02 02 FF D4 BD 7E
TX: 11:30:14 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:14 7E A8 51 21 03 5A 6E 38 02 04 10 56 C8 12 00 03 11 00 09 06 01 01 08 02 03 FF 02 04 10 57 30 12 00 03 11 00 09 06 01 01 01 02 00 FF 02 04 10 57 98 12 00 03 11 00 09 06 01 01 02 02 00 FF 02 04 10 58 00 12 00 03 11 00 09 06 01 01 05 02 00 FF 76 94 7E
TX: 11:30:14 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:14 7E A8 51 21 03 5C 58 5D 02 04 10 58 68 12 00 03 11 00 09 06 01 01 06 02 00 FF 02 04 10 58 D0 12 00 03 11 00 09 06 01 01 07 02 00 FF 02 04 10 59 38 12 00 03 11 00 09 06 01 01 08 02 00 FF 02 04 10 59 A0 12 00 01 11 00 09 06 01 00 00 00 00 FF 3A EB 7E
TX: 11:30:14 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:15 7E A8 51 21 03 5E 4A 7E 02 04 10 59 D8 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 04 10 5A 10 12 00 01 11 00 09 06 01 00 00 00 02 FF 02 04 10 5A 48 12 00 01 11 00 09 06 01 00 00 00 03 FF 02 04 10 5A 80 12 00 01 11 00 09 06 00 00 60 01 00 FF 27 1B 7E
TX: 11:30:15 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:15 7E A8 51 21 03 50 34 97 02 04 10 5A B8 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 04 10 5A F0 12 00 03 11 00 09 06 00 00 60 02 01 FF 02 04 10 5B 58 12 00 03 11 00 09 06 00 01 60 02 05 FF 02 04 10 5B C0 12 00 03 11 00 09 06 00 00 60 02 02 FF 9D 9B 7E
TX: 11:30:15 7E A0 07 03 21 31 17 87 7E
RX: 11:30:15 7E A8 51 21 03 52 26 B4 02 04 10 5C 28 12 00 01 11 00 09 06 00 00 60 F0 00 FF 02 04 10 FF 00 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 04 10 39 D0 12 00 01 11 00 09 06 01 00 00 02 01 FF 02 04 10 38 40 12 00 01 11 00 09 06 00 00 60 5A FF FF 86 7F 7E
TX: 11:30:15 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:15 7E A8 51 21 03 54 10 D1 02 04 10 FD 00 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 04 10 5C 98 12 00 01 11 00 09 06 00 00 60 63 08 FF 02 04 10 5C D0 12 00 01 11 00 09 06 01 00 00 02 04 FF 02 04 10 5D 08 12 00 01 11 00 09 06 00 00 60 5A 01 FF 6D 2E 7E
TX: 11:30:15 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:15 7E A8 51 21 03 56 02 F2 02 04 10 5D 40 12 00 01 11 00 09 06 01 00 00 01 02 FF 02 04 10 5D 78 12 00 03 11 00 09 06 01 01 00 03 00 FF 02 04 10 5D E0 12 00 03 11 00 09 06 01 01 00 03 01 FF 02 04 10 5E 48 12 00 03 11 00 09 06 01 01 00 04 00 FF 42 24 7E
TX: 11:30:15 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:16 7E A8 51 21 03 58 7C 1B 02 04 10 5E B0 12 00 03 11 00 09 06 01 01 00 04 01 FF 02 04 10 5F 18 12 00 03 11 00 09 06 01 01 00 04 02 FF 02 04 10 5F 80 12 00 03 11 00 09 06 01 01 00 04 03 FF 02 04 10 5F E8 12 00 03 11 00 09 06 01 00 00 03 06 FF 3F 29 7E
TX: 11:30:16 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:16 7E A8 51 21 03 5A 6E 38 02 04 10 60 50 12 00 03 11 00 09 06 01 00 00 03 07 FF 02 04 10 67 B0 12 00 03 11 00 09 06 01 01 48 05 00 FF 02 04 10 68 18 12 00 03 11 00 09 06 01 01 34 05 00 FF 02 04 10 68 80 12 00 03 11 00 09 06 01 01 20 05 00 FF 56 26 7E
TX: 11:30:16 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:16 7E A8 51 21 03 5C 58 5D 02 04 10 68 E8 12 00 15 11 00 09 06 01 01 20 23 00 FF 02 04 10 69 68 12 00 15 11 00 09 06 01 01 34 23 00 FF 02 04 10 69 E8 12 00 15 11 00 09 06 01 01 48 23 00 FF 02 04 10 6A 68 12 00 15 11 00 09 06 01 01 20 1F 00 FF 43 62 7E
TX: 11:30:16 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:16 7E A8 51 21 03 5E 4A 7E 02 04 10 6A E8 12 00 15 11 00 09 06 01 01 34 1F 00 FF 02 04 10 6B 68 12 00 15 11 00 09 06 01 01 48 1F 00 FF 02 04 10 6B E8 12 00 15 11 00 09 06 01 01 1F 23 00 FF 02 04 10 6C 68 12 00 15 11 00 09 06 01 01 33 23 00 FF 6B E6 7E
TX: 11:30:16 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:16 7E A8 51 21 03 50 34 97 02 04 10 6C E8 12 00 15 11 00 09 06 01 01 47 23 00 FF 02 04 10 6D 68 12 00 15 11 00 09 06 01 01 5B 23 00 FF 02 04 10 7D E8 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 7E 78 12 00 04 11 00 09 06 00 00 7F 00 00 00 C4 14 7E
TX: 11:30:16 7E A0 07 03 21 31 17 87 7E
RX: 11:30:16 7E A8 51 21 03 52 26 B4 02 04 10 7F 08 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 7F 98 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 80 28 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 80 B8 12 00 04 11 00 09 06 00 00 7F 00 00 00 6E 4A 7E
TX: 11:30:16 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:17 7E A8 51 21 03 54 10 D1 02 04 10 81 48 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 81 D8 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 82 68 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 82 F8 12 00 04 11 00 09 06 00 00 7F 00 00 00 23 7F 7E
TX: 11:30:17 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:17 7E A8 51 21 03 56 02 F2 02 04 10 83 88 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 84 18 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 84 A8 12 00 03 11 00 09 06 00 00 60 08 01 FF 02 04 10 85 10 12 00 03 11 00 09 06 00 00 60 08 02 FF AA 11 7E
TX: 11:30:17 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:17 7E A8 51 21 03 58 7C 1B 02 04 10 85 78 12 00 03 11 00 09 06 00 00 60 08 03 FF 02 04 10 85 E0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 86 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 86 B0 12 00 03 11 00 09 06 00 00 7F 00 00 00 29 85 7E
TX: 11:30:17 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:17 7E A8 51 21 03 5A 6E 38 02 04 10 87 18 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 87 80 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 87 E8 12 00 03 11 00 09 06 00 00 60 08 00 FF 02 04 10 FE 00 12 00 03 11 00 09 06 00 00 60 02 00 FF 8B 1E 7E
TX: 11:30:17 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:17 7E A8 51 21 03 5C 58 5D 02 04 10 88 B8 12 00 03 11 00 09 06 01 00 00 01 00 FF 02 04 10 89 F0 12 00 03 11 00 09 06 00 00 60 07 01 FF 02 04 10 8A 58 12 00 03 11 00 09 06 00 00 60 07 02 FF 02 04 10 8A C0 12 00 03 11 00 09 06 00 00 60 07 03 FF 2C 1D 7E
TX: 11:30:17 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:17 7E A8 51 21 03 5E 4A 7E 02 04 10 8B 28 12 00 03 11 00 09 06 00 00 60 07 00 FF 02 04 10 8B 90 12 00 03 11 00 09 06 00 00 60 06 00 FF 02 04 10 8B F8 12 27 1A 11 02 09 06 00 00 F0 0E 00 FF 02 04 10 8C 30 12 27 1A 11 02 09 06 00 00 F0 0E 10 FF 71 47 7E
TX: 11:30:17 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:18 7E A8 51 21 03 50 34 97 02 04 10 8C 68 12 27 1A 11 02 09 06 00 00 F0 0E 20 FF 02 04 10 8C A0 12 27 1A 11 02 09 06 00 00 F0 0E 21 FF 02 04 10 8C D8 12 27 1A 11 02 09 06 00 00 F0 0E 22 FF 02 04 10 8D 10 12 27 1A 11 02 09 06 00 00 F0 0E 23 FF 88 07 7E
TX: 11:30:18 7E A0 07 03 21 31 17 87 7E
RX: 11:30:18 7E A8 51 21 03 52 26 B4 02 04 10 8D 48 12 27 1A 11 02 09 06 00 00 F0 0E 24 FF 02 04 10 8D 80 12 27 1A 11 02 09 06 00 00 F0 0E 30 FF 02 04 10 8D B8 12 27 1B 11 02 09 06 00 00 F0 0E 31 FF 02 04 10 8D F0 12 27 43 11 02 09 06 00 00 F0 0E 32 FF 89 F1 7E
TX: 11:30:18 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:18 7E A8 51 21 03 54 10 D1 02 04 10 8E 28 12 27 42 11 02 09 06 00 00 F0 0E 33 FF 02 04 10 8E 60 12 27 1A 11 02 09 06 00 00 F0 0E 25 FF 02 04 10 8E 98 12 27 1A 11 02 09 06 00 00 7F 00 00 00 02 04 10 8E D0 12 27 20 11 02 09 06 00 00 F0 0E 60 FF CB E3 7E
TX: 11:30:18 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:18 7E A8 51 21 03 56 02 F2 02 04 10 8F 80 12 00 03 11 00 09 06 00 00 60 04 00 FF 02 04 10 8F E8 12 00 03 11 00 09 06 00 00 60 05 00 FF 02 04 10 90 50 12 27 27 11 03 09 06 00 00 F0 05 01 FF 02 04 10 90 D0 12 27 27 11 03 09 06 00 00 F0 05 02 FF B2 20 7E
TX: 11:30:18 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:18 7E A8 51 21 03 58 7C 1B 02 04 10 92 50 12 27 27 11 03 09 06 00 00 F0 05 05 FF 02 04 10 92 D0 12 27 27 11 03 09 06 00 00 F0 05 06 FF 02 04 10 93 50 12 27 27 11 03 09 06 00 00 F0 05 07 FF 02 04 10 93 D0 12 27 27 11 03 09 06 00 00 F0 05 08 FF F6 69 7E
TX: 11:30:18 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:19 7E A8 51 21 03 5A 6E 38 02 04 10 94 50 12 00 03 11 00 09 06 01 01 20 07 00 FF 02 04 10 94 E8 12 00 03 11 00 09 06 01 01 34 07 00 FF 02 04 10 95 80 12 00 03 11 00 09 06 01 01 48 07 00 FF 02 04 10 96 18 12 00 03 11 00 09 06 01 01 1F 07 00 FF CF B8 7E
TX: 11:30:19 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:19 7E A8 51 21 03 5C 58 5D 02 04 10 96 B0 12 00 03 11 00 09 06 01 01 33 07 00 FF 02 04 10 97 48 12 00 03 11 00 09 06 01 01 47 07 00 FF 02 04 10 97 E0 12 00 03 11 00 09 06 01 01 5B 07 00 FF 02 04 10 98 78 12 00 03 11 00 09 06 01 01 0E 07 00 FF 3D A6 7E
TX: 11:30:19 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:19 7E A8 51 21 03 5E 4A 7E 02 04 10 99 10 12 00 03 11 00 09 06 01 01 10 07 00 FF 02 04 10 99 A8 12 00 03 11 00 09 06 01 01 83 07 00 FF 02 04 10 9A 40 12 00 03 11 00 09 06 01 01 51 07 00 FF 02 04 10 9A D8 12 00 03 11 00 09 06 01 01 51 07 01 FF A9 9F 7E
TX: 11:30:19 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:19 7E A8 51 21 03 50 34 97 02 04 10 9B 70 12 00 03 11 00 09 06 01 01 51 07 02 FF 02 04 10 9C 08 12 00 03 11 00 09 06 01 01 51 07 04 FF 02 04 10 9C A0 12 00 03 11 00 09 06 01 01 51 07 0F FF 02 04 10 9D 38 12 00 03 11 00 09 06 01 01 51 07 1A FF 89 76 7E
TX: 11:30:19 7E A0 07 03 21 31 17 87 7E
RX: 11:30:19 7E A8 51 21 03 52 26 B4 02 04 10 9D D0 12 00 03 11 00 09 06 01 01 0D 07 00 FF 02 04 10 9E 68 12 00 03 11 00 09 06 01 01 21 07 00 FF 02 04 10 9F 00 12 00 03 11 00 09 06 01 01 35 07 00 FF 02 04 10 9F 98 12 00 03 11 00 09 06 01 01 49 07 00 FF BD 5D 7E
TX: 11:30:19 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:19 7E A8 51 21 03 54 10 D1 02 04 10 A0 30 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A0 C8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A1 60 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A1 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 2E B7 7E
TX: 11:30:19 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:20 7E A8 51 21 03 56 02 F2 02 04 10 A2 90 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A3 28 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A3 C0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A4 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 36 8C 7E
TX: 11:30:20 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:20 7E A8 51 21 03 58 7C 1B 02 04 10 A4 F0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 B5 90 12 00 03 11 00 09 06 01 01 24 07 00 FF 02 04 10 B6 28 12 00 03 11 00 09 06 01 01 38 07 00 FF 02 04 10 B6 C0 12 00 03 11 00 09 06 01 01 4C 07 00 FF C0 5C 7E
TX: 11:30:20 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:20 7E A8 51 21 03 5A 6E 38 02 04 10 B7 58 12 00 03 11 00 09 06 01 01 97 07 00 FF 02 04 10 B7 F0 12 00 03 11 00 09 06 01 01 AB 07 00 FF 02 04 10 B8 88 12 00 03 11 00 09 06 01 01 BF 07 00 FF 02 04 10 BB 30 12 27 29 11 02 09 06 00 00 60 03 01 FF D5 26 7E
TX: 11:30:20 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:20 7E A8 51 21 03 5C 58 5D 02 04 10 BB 78 12 27 29 11 02 09 06 00 00 60 03 02 FF 02 04 10 BB C0 12 27 29 11 02 09 06 00 00 7F 00 00 00 02 04 10 BC 08 12 27 29 11 02 09 06 00 01 60 03 04 FF 02 04 10 BC 50 12 27 29 11 02 09 06 00 00 7F 00 00 00 F6 77 7E
TX: 11:30:20 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:20 7E A8 51 21 03 5E 4A 7E 02 04 10 BC 98 12 27 29 11 02 09 06 01 00 60 0A 02 FF 02 04 10 BC E0 12 27 29 11 02 09 06 01 00 60 0A 03 FF 02 04 10 4E 20 12 27 25 11 02 09 06 00 00 F0 09 00 FF 02 04 10 BD 28 12 27 26 11 01 09 06 00 00 F0 08 00 FF C0 B3 7E
TX: 11:30:20 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:20 7E A8 51 21 03 50 34 97 02 04 10 BD 68 12 27 26 11 01 09 06 00 00 F0 08 01 FF 02 04 10 BD A8 12 27 26 11 01 09 06 00 00 F0 08 02 FF 02 04 10 BD E8 12 27 26 11 01 09 06 00 00 F0 08 03 FF 02 04 10 BE 28 12 27 26 11 01 09 06 00 00 F0 08 04 FF C9 A4 7E
TX: 11:30:20 7E A0 07 03 21 31 17 87 7E
RX: 11:30:21 7E A8 51 21 03 52 26 B4 02 04 10 BE 68 12 27 26 11 01 09 06 00 00 F0 08 05 FF 02 04 10 BE A8 12 27 26 11 01 09 06 00 00 F0 08 06 FF 02 04 10 BE E8 12 27 26 11 01 09 06 00 00 F0 08 07 FF 02 04 10 BF 28 12 27 26 11 01 09 06 00 00 F0 08 08 FF 23 17 7E
TX: 11:30:21 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:21 7E A8 51 21 03 54 10 D1 02 04 10 BF 68 12 27 26 11 01 09 06 00 00 F0 08 09 FF 02 04 10 BF A8 12 27 26 11 01 09 06 00 00 F0 08 0A FF 02 04 10 BF E8 12 27 26 11 01 09 06 00 00 F0 08 0B FF 02 04 10 C0 28 12 27 26 11 01 09 06 00 00 F0 08 0C FF F7 79 7E
TX: 11:30:21 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:21 7E A8 51 21 03 56 02 F2 02 04 10 C0 68 12 27 26 11 01 09 06 00 00 F0 08 0D FF 02 04 10 C0 A8 12 27 26 11 01 09 06 00 00 F0 08 0E FF 02 04 10 C1 60 12 27 26 11 01 09 06 00 00 F0 08 0F FF 02 04 10 C8 58 12 00 07 11 01 09 06 00 00 7F 00 00 00 EF 17 7E
TX: 11:30:21 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:21 7E A8 51 21 03 58 7C 1B 02 04 10 C9 60 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CA 68 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CB 70 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CC 78 12 00 07 11 01 09 06 00 00 7F 00 00 00 66 08 7E
TX: 11:30:21 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:21 7E A8 51 21 03 5A 6E 38 02 04 10 CD 80 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CE 88 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CF 90 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D0 98 12 00 07 11 01 09 06 00 00 7F 00 00 00 CB B7 7E
TX: 11:30:21 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:22 7E A8 51 21 03 5C 58 5D 02 04 10 D1 A0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D2 A8 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D3 B0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D4 B8 12 00 07 11 01 09 06 00 00 7F 00 00 00 EC 50 7E
TX: 11:30:22 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:22 7E A8 51 21 03 5E 4A 7E 02 04 10 D5 C0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D6 C8 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D7 D0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D8 D8 12 00 07 11 01 09 06 00 00 7F 00 00 00 F5 28 7E
TX: 11:30:22 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:22 7E A8 51 21 03 50 34 97 02 04 10 D9 E0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 DB 30 12 27 35 11 00 09 06 00 00 7F 00 00 00 02 04 10 DB 78 12 27 35 11 00 09 06 00 00 7F 00 00 00 02 04 10 DB C0 12 27 36 11 00 09 06 00 00 7F 00 00 00 7C F1 7E
TX: 11:30:22 7E A0 07 03 21 31 17 87 7E
RX: 11:30:22 7E A0 1B 21 03 52 1F 24 02 04 10 DB F8 12 27 36 11 00 09 06 00 00 7F 00 00 00 73 50 7E
Unknown object : 10032 16
Unknown object : 10002 280
Unknown object : 10080 392
Unknown object : 10014 2088
Unknown object : 10017 2160
Unknown object : 10020 2320
Unknown object : 10018 2352
Unknown object : 10100 26400
Unknown object : 10040 2384
Unknown object : 10660 2632
Unknown object : 10010 35832
Unknown object : 10010 35888
Unknown object : 10010 35944
Unknown object : 10010 36000
Unknown object : 10010 36056
Unknown object : 10010 36112
Unknown object : 10010 36168
Unknown object : 10010 36224
Unknown object : 10011 36280
Unknown object : 10051 36336
Unknown object : 10050 36392
Unknown object : 10010 36448
Unknown object : 10010 36504
Unknown object : 10016 36560
Unknown object : 10023 36944
Unknown object : 10023 37072
Unknown object : 10023 37456
Unknown object : 10023 37584
Unknown object : 10023 37712
Unknown object : 10023 37840
Unknown object : 10025 47920
Unknown object : 10025 47992
Unknown object : 10025 48064
Unknown object : 10025 48136
Unknown object : 10025 48208
Unknown object : 10025 48280
Unknown object : 10025 48352
Unknown object : 10021 20000
Unknown object : 10022 48424
Unknown object : 10022 48488
Unknown object : 10022 48552
Unknown object : 10022 48616
Unknown object : 10022 48680
Unknown object : 10022 48744
Unknown object : 10022 48808
Unknown object : 10022 48872
Unknown object : 10022 48936
Unknown object : 10022 49000
Unknown object : 10022 49064
Unknown object : 10022 49128
Unknown object : 10022 49192
Unknown object : 10022 49256
Unknown object : 10022 49320
Unknown object : 10022 49504
Unknown object : 10037 56112
Unknown object : 10037 56184
Unknown object : 10038 56256
Unknown object : 10038 56312
TX: 11:30:22 7E A8 44 03 21 54 E6 DA E6 E6 00 05 81 CC 02 04 58 02 48 B0 02 05 68 02 05 D0 02 09 88 02 09 F0 02 C1 08 02 C1 D0 02 0B C0 02 0C 68 02 0D 10 02 0D B8 02 0E 60 02 0F 08 02 0F B0 02 10 58 02 11 00 02 11 1E 45 7E
RX: 11:30:22 7E A0 07 21 03 71 13 63 7E
TX: 11:30:22 7E A8 47 03 21 56 39 DC A8 02 12 50 02 12 F8 02 13 A0 02 14 48 02 14 F0 02 15 98 02 16 40 02 16 E8 02 17 90 02 18 38 02 18 E0 02 19 88 02 1A 30 02 1A D8 02 1B 80 02 1C 28 02 1F B0 02 20 58 02 21 00 02 21 A8 02 FE F3 7E
RX: 11:30:23 7E A0 07 21 03 91 1D 84 7E
TX: 11:30:23 7E A8 47 03 21 58 47 35 22 50 02 22 F8 02 1C F0 02 1D A8 02 1E 50 02 1F 08 02 23 A0 02 24 48 02 24 F0 02 25 98 02 26 40 02 26 E8 02 27 90 02 28 38 02 28 E0 02 29 88 02 2A 30 02 2A D8 02 2C C0 02 2D 68 02 2E 10 AD 59 7E
RX: 11:30:23 7E A0 07 21 03 B1 1F A5 7E
TX: 11:30:23 7E A8 47 03 21 5A 55 16 02 2E B8 02 2F 60 02 30 08 02 30 B0 02 31 58 02 32 00 02 32 A8 02 33 50 02 34 00 02 34 98 02 35 30 02 35 C8 02 36 60 02 36 F8 02 38 90 02 39 28 02 3A 20 02 3A B8 02 3C 88 02 3D 10 02 3D 8D 92 7E
RX: 11:30:23 7E A0 07 21 03 D1 19 C6 7E
TX: 11:30:23 7E A8 47 03 21 5C 63 73 98 02 3E 20 02 3E A8 02 3F 30 02 3F B8 02 40 40 02 40 C8 02 41 E8 02 42 70 02 42 F8 02 43 80 02 44 08 02 44 90 02 45 D0 02 46 58 02 46 E0 02 47 68 02 47 F0 02 49 90 02 4A 18 02 4A A0 02 05 98 7E
RX: 11:30:23 7E A0 07 21 03 F1 1B E7 7E
TX: 11:30:23 7E A8 47 03 21 5E 71 50 4B 28 02 4B B0 02 4C 18 02 4C 80 02 4C E8 02 4D 50 02 4D B8 02 52 60 02 52 C8 02 53 30 02 53 98 02 54 00 02 54 68 02 54 D0 02 55 38 02 55 A0 02 56 08 02 56 70 02 56 D8 02 57 40 02 57 A8 87 6D 7E
RX: 11:30:23 7E A0 07 21 03 11 15 00 7E
TX: 11:30:23 7E A8 47 03 21 50 0F B9 02 58 10 02 58 78 02 58 E0 02 59 48 02 5B 00 02 5B 68 02 5B D0 02 5D 88 02 5D F0 02 5E 58 02 5E C0 02 5F 28 02 5F 90 02 5F F8 02 60 60 02 67 C0 02 68 28 02 68 90 02 7D F8 02 7E 88 02 7F 57 02 7E
RX: 11:30:23 7E A0 07 21 03 31 17 21 7E
TX: 11:30:23 7E A8 47 03 21 52 1D 9A 18 02 7F A8 02 80 38 02 80 C8 02 81 58 02 81 E8 02 82 78 02 83 08 02 83 98 02 84 28 02 84 B8 02 85 20 02 85 88 02 85 F0 02 86 58 02 86 C0 02 87 28 02 87 90 02 87 F8 02 FE 10 02 88 C8 02 7F 3C 7E
RX: 11:30:23 7E A0 07 21 03 51 11 42 7E
TX: 11:30:23 7E A8 47 03 21 54 2B FF 8A 00 02 8A 68 02 8A D0 02 8B 38 02 8B A0 02 8F 90 02 8F F8 02 94 60 02 94 F8 02 95 90 02 96 28 02 96 C0 02 97 58 02 97 F0 02 98 88 02 99 20 02 99 B8 02 9A 50 02 9A E8 02 9B 80 02 9C 18 7F 2E 7E
RX: 11:30:23 7E A0 07 21 03 71 13 63 7E
TX: 11:30:23 7E A8 47 03 21 56 39 DC 02 9C B0 02 9D 48 02 9D E0 02 9E 78 02 9F 10 02 9F A8 02 A0 40 02 A0 D8 02 A1 70 02 A2 08 02 A2 A0 02 A3 38 02 A3 D0 02 A4 68 02 A5 00 02 B5 A0 02 B6 38 02 B6 D0 02 B7 68 02 B8 00 02 B8 1B 7D 7E
TX: 11:30:23 7E A0 0A 03 21 58 5F F2 98 0D DE 7E
RX: 11:30:24 7E A8 4E 21 03 B4 46 47 E6 E7 00 0C 81 CC 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F FF 16 1E 9B 91 7E
TX: 11:30:24 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:24 7E A8 4F 21 03 B6 EF 78 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 8B B9 7E
TX: 11:30:24 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:24 7E A8 4F 21 03 B8 91 91 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 46 46 7E
TX: 11:30:24 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:24 7E A8 4F 21 03 BA 83 B2 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF D1 D6 7E
TX: 11:30:24 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:24 7E A8 4F 21 03 BC B5 D7 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 1E 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FF 16 20 00 02 02 0F FC 16 00 BE 87 7E
TX: 11:30:24 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:25 7E A8 4F 21 03 BE A7 F4 00 02 02 0F FC 16 00 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 87 A5 7E
TX: 11:30:25 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:25 7E A8 4F 21 03 B0 D9 1D 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B A9 65 7E
TX: 11:30:25 7E A0 07 03 21 31 17 87 7E
RX: 11:30:25 7E A8 4F 21 03 B2 CB 3E 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 FF 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B D9 DC 7E
TX: 11:30:25 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:25 7E A8 4F 21 03 B4 FD 5B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 60 82 7E
TX: 11:30:25 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:25 7E A8 4F 21 03 B6 EF 78 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 27 44 7E
TX: 11:30:25 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:25 7E A8 4F 21 03 B8 91 91 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 76 BA 7E
TX: 11:30:25 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:26 7E A8 4F 21 03 BA 83 B2 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 37 13 7E
TX: 11:30:26 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:26 7E A8 4F 21 03 BC B5 D7 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1B 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F FF 16 1D 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F FD 16 2D CD 48 7E
TX: 11:30:26 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:26 7E A8 4F 21 03 BE A7 F4 00 02 02 0F FD 16 2E 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F FD 16 2D 00 02 02 0F FD 16 2D 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 52 9C 7E
TX: 11:30:26 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:26 7E A8 4F 21 03 B0 D9 1D 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 4A 34 7E
TX: 11:30:26 7E A0 07 03 21 31 17 87 7E
RX: 11:30:26 7E A8 4F 21 03 B2 CB 3E 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 00 02 02 0F 00 16 06 7B 88 7E
TX: 11:30:26 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:26 7E A8 4F 21 03 B4 FD 5B 00 02 02 0F 00 16 06 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 06 00 02 02 0F 00 16 FF 00 02 02 0F 00 16 FF 5E 9E 7E
TX: 11:30:26 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:27 7E A8 4F 21 03 B6 EF 78 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 00 02 02 0F FE 16 21 00 02 02 0F FE 16 21 00 02 02 0F FE 16 21 00 02 02 0F FE 16 21 00 02 02 0F FE 16 2C 00 02 02 0F 00 16 1B 00 02 02 0F 00 16 1D 57 32 7E
TX: 11:30:27 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:27 7E A8 4F 21 03 B8 91 91 00 02 02 0F FE 16 08 00 02 02 0F FE 16 08 00 02 02 0F FE 16 08 00 02 02 0F FE 16 08 00 02 02 0F FE 16 08 00 02 02 0F FE 16 08 00 02 02 0F FE 16 FF 00 02 02 0F FE 16 FF 00 02 02 0F FE 16 FF 00 02 02 0F FE 16 FF AD 15 7E
TX: 11:30:27 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:27 7E A8 4F 21 03 BA 83 B2 00 02 02 0F FD 16 FF 00 02 02 0F FD 16 23 00 02 02 0F FD 16 23 00 02 02 0F FD 16 23 00 02 02 0F FD 16 FF 00 02 02 0F FD 16 21 00 02 02 0F FD 16 21 00 02 02 0F FD 16 21 00 02 02 0F FD 16 FF 00 02 02 0F 00 16 1B 66 AF 7E
TX: 11:30:27 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:27 7E A0 2C 21 03 BC BC 31 00 02 02 0F 00 16 1B 00 02 02 0F 00 16 1B 00 02 02 0F 00 16 1D 00 02 02 0F 00 16 1D 00 02 02 0F 00 16 1D 55 54 7E
Profile Generic 24800Columns:
TX: 11:30:27 7E A0 11 03 21 FA F3 77 E6 E6 00 05 01 02 60 F0 F2 01 7E
RX: 11:30:27 7E A8 59 21 03 DE 9A 1F E6 E7 00 0C 01 00 01 0A 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 00 00 60 F0 0C FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 08 00 FF 0F 02 12 00 00 E0 E8 7E
TX: 11:30:27 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:27 7E A8 51 21 03 D0 3C 13 02 04 12 00 03 09 06 01 01 03 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 04 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 05 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 06 08 00 FF 0F 02 12 00 00 10 41 7E
TX: 11:30:27 7E A0 07 03 21 31 17 87 7E
RX: 11:30:28 7E A0 2D 21 03 D2 7F A7 02 04 12 00 03 09 06 01 01 07 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 08 08 00 FF 0F 02 12 00 00 1D 60 7E
11200 Ch. 0 Clock object #1 | 18592 Manufacturer specific | 7392 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 7576 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 7744 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 0 (0 is total) | 7928 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 0 (0 is total) | 9104 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 0 (0 is total) | 9272 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 0 (0 is total) | 9440 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 0 (0 is total) | 9608 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 0 (0 is total)
Profile Generic 25200Columns:
TX: 11:30:28 7E A0 11 03 21 5C CF B7 E6 E6 00 05 01 02 62 80 C5 41 7E
RX: 11:30:28 7E A8 59 21 03 F4 C2 91 E6 E7 00 0C 01 00 01 0E 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 00 00 60 F0 0C FF 0F 12 12 00 00 02 04 12 00 03 09 06 01 01 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 08 00 FF 0F 02 12 00 00 29 87 7E
TX: 11:30:28 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:28 7E A8 51 21 03 F6 08 57 02 04 12 00 03 09 06 01 01 03 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 04 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 05 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 06 08 00 FF 0F 02 12 00 00 10 41 7E
TX: 11:30:28 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:28 7E A8 51 21 03 F8 76 BE 02 04 12 00 03 09 06 01 01 07 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 08 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 1D 00 FF 0F 02 12 00 00 ED 84 7E
TX: 11:30:28 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:28 7E A0 2D 21 03 FA 35 0A 02 04 12 00 03 09 06 01 01 03 1D 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 04 1D 00 FF 0F 02 12 00 00 F5 F8 7E
11200 Ch. 0 Clock object #1 | 18592 Manufacturer specific | 7392 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 7576 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 7744 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 0 (0 is total) | 7928 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 0 (0 is total) | 9104 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 0 (0 is total) | 9272 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 0 (0 is total) | 9440 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 0 (0 is total) | 9608 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 0 (0 is total) | 7024 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 5 | 7192 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 5 | 8096 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 5 | 8264 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 5
Profile Generic 25600Columns:
TX: 11:30:28 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 64 10 9C 81 7E
RX: 11:30:28 7E A8 59 21 03 1C 84 FA E6 E7 00 0C 01 00 01 16 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 00 00 01 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 08 01 FF 0F 02 12 00 00 F4 BB 7E
TX: 11:30:28 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:29 7E A8 51 21 03 1E 4E 3C 02 04 12 00 03 09 06 01 01 01 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 01 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 08 01 FF 0F 02 12 00 00 D7 C6 7E
TX: 11:30:29 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:29 7E A8 51 21 03 10 30 D5 02 04 12 00 03 09 06 01 01 02 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 02 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 03 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 03 08 01 FF 0F 02 12 00 00 24 36 7E
TX: 11:30:29 7E A0 07 03 21 31 17 87 7E
RX: 11:30:29 7E A8 51 21 03 12 22 F6 02 04 12 00 03 09 06 01 01 03 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 03 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 04 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 04 08 01 FF 0F 02 12 00 00 E2 CA 7E
TX: 11:30:29 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:29 7E A8 51 21 03 14 14 93 02 04 12 00 03 09 06 01 01 04 08 02 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 04 08 03 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 05 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 06 08 00 FF 0F 02 12 00 00 D5 E8 7E
TX: 11:30:29 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:29 7E A0 2D 21 03 16 57 27 02 04 12 00 03 09 06 01 01 07 08 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 01 01 08 08 00 FF 0F 02 12 00 00 1D 60 7E
11200 Ch. 0 Clock object #1 | 35000 Ch. 0 Billing period counter (1) #255 | 7392 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total) | 2992 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 1 (0 is total) | 3160 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 2 (0 is total) | 3328 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 3 (0 is total) | 7576 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total) | 3496 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 1 (0 is total) | 3664 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 2 (0 is total) | 3832 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 3 (0 is total) | 7744 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 0 (0 is total) | 4000 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 1 (0 is total) | 4168 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 2 (0 is total) | 4336 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 3 (0 is total) | 7928 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 0 (0 is total) | 4504 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 1 (0 is total) | 4672 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 2 (0 is total) | 4840 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 3 (0 is total) | 9104 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 0 (0 is total) | 9272 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 0 (0 is total) | 9440 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 0 (0 is total) | 9608 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 0 (0 is total)
Profile Generic 2728Columns:
TX: 11:30:29 7E A0 11 03 21 90 AF BB E6 E6 00 05 01 02 0A B8 9B 57 7E
RX: 11:30:29 7E A8 59 21 03 38 A2 9D E6 E7 00 0C 01 00 01 0B 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 02 04 12 00 03 09 06 00 00 60 F0 0C FF 0F 14 12 00 00 02 04 12 00 03 09 06 01 01 20 07 00 FF 0F 0B 12 00 00 02 04 12 00 03 09 06 01 01 34 07 00 FF 0F 0B 12 00 00 D7 02 7E
TX: 11:30:29 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:30 7E A8 51 21 03 3A 68 5B 02 04 12 00 03 09 06 01 01 48 07 00 FF 0F 0B 12 00 00 02 04 12 00 03 09 06 01 01 1F 07 00 FF 0F 0B 12 00 00 02 04 12 00 03 09 06 01 01 33 07 00 FF 0F 0B 12 00 00 02 04 12 00 03 09 06 01 01 47 07 00 FF 0F 0B 12 00 00 46 35 7E
TX: 11:30:30 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:30 7E A0 3F 21 03 3C D8 53 02 04 12 00 03 09 06 01 01 24 07 00 FF 0F 0B 12 00 00 02 04 12 00 03 09 06 01 01 38 07 00 FF 0F 0B 12 00 00 02 04 12 00 03 09 06 01 01 4C 07 00 FF 0F 0B 12 00 00 35 09 7E
11200 Ch. 0 Clock object #1 | 18592 Manufacturer specific | 37968 Ch. 1 L1 Voltage Inst. value | 38120 Ch. 1 L2 Voltage Inst. value | 38272 Ch. 1 L3 Voltage Inst. value | 38424 Ch. 1 L1 Current Inst. value | 38576 Ch. 1 L2 Current Inst. value | 38728 Ch. 1 L3 Current Inst. value | 46480 Ch. 1 L1 Active power (abs(QI+QIV)-abs(QII+QIII)) Inst. value | 46632 Ch. 1 L2 Active power (abs(QI+QIV)-abs(QI+QIII)) Inst. value | 46784 Ch. 1 L3 Active power (abs(QI+QIV)-abs(QI+QIII)) Inst. value
Profile Generic 51288Columns:
TX: 11:30:30 7E A0 11 03 21 F2 BB FB E6 E6 00 05 01 02 C8 68 0C 78 7E
RX: 11:30:30 7E A0 10 21 03 5E 66 2E E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 51552Columns:
TX: 11:30:30 7E A0 11 03 21 14 83 79 E6 E6 00 05 01 02 C9 70 1D FD 7E
RX: 11:30:30 7E A0 10 21 03 70 1A E6 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 51816Columns:
TX: 11:30:30 7E A0 11 03 21 36 93 7B E6 E6 00 05 01 02 CA 78 3D 5B 7E
RX: 11:30:30 7E A0 10 21 03 92 06 22 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 52080Columns:
TX: 11:30:30 7E A0 11 03 21 58 EB F1 E6 E6 00 05 01 02 CB 80 22 39 7E
RX: 11:30:30 7E A0 10 21 03 B4 32 66 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 52344Columns:
TX: 11:30:30 7E A0 11 03 21 7A FB F3 E6 E6 00 05 01 02 CC 88 62 F8 7E
RX: 11:30:30 7E A0 10 21 03 D6 26 26 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 52608Columns:
TX: 11:30:30 7E A0 11 03 21 9C C3 71 E6 E6 00 05 01 02 CD 90 73 7D 7E
RX: 11:30:30 7E A0 10 21 03 F8 5A EE E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 52872Columns:
TX: 11:30:30 7E A0 11 03 21 BE D3 73 E6 E6 00 05 01 02 CE 98 53 DB 7E
RX: 11:30:30 7E A0 10 21 03 1A 46 2A E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 53136Columns:
TX: 11:30:30 7E A0 11 03 21 D0 AB F9 E6 E6 00 05 01 02 CF A0 40 7F 7E
RX: 11:30:31 7E A0 10 21 03 3C 72 6E E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 53400Columns:
TX: 11:30:31 7E A0 11 03 21 F2 BB FB E6 E6 00 05 01 02 D0 A8 51 E5 7E
RX: 11:30:31 7E A0 10 21 03 5E 66 2E E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 53664Columns:
TX: 11:30:31 7E A0 11 03 21 14 83 79 E6 E6 00 05 01 02 D1 B0 40 60 7E
RX: 11:30:31 7E A0 10 21 03 70 1A E6 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 53928Columns:
TX: 11:30:31 7E A0 11 03 21 36 93 7B E6 E6 00 05 01 02 D2 B8 60 C6 7E
RX: 11:30:31 7E A0 10 21 03 92 06 22 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 54192Columns:
TX: 11:30:31 7E A0 11 03 21 58 EB F1 E6 E6 00 05 01 02 D3 C0 77 20 7E
RX: 11:30:31 7E A0 10 21 03 B4 32 66 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 54456Columns:
TX: 11:30:31 7E A0 11 03 21 7A FB F3 E6 E6 00 05 01 02 D4 C8 37 E1 7E
RX: 11:30:31 7E A0 10 21 03 D6 26 26 E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 54720Columns:
TX: 11:30:31 7E A0 11 03 21 9C C3 71 E6 E6 00 05 01 02 D5 D0 26 64 7E
RX: 11:30:31 7E A0 10 21 03 F8 5A EE E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 54984Columns:
TX: 11:30:31 7E A0 11 03 21 BE D3 73 E6 E6 00 05 01 02 D6 D8 06 C2 7E
RX: 11:30:31 7E A0 10 21 03 1A 46 2A E6 E7 00 0C 01 01 03 DB B3 7E
Profile Generic 55248Columns:
TX: 11:30:31 7E A0 11 03 21 D0 AB F9 E6 E6 00 05 01 02 D7 E0 15 66 7E
Profile Generic 55512Columns:
TX: 11:30:31 7E A0 11 03 21 F2 BB FB E6 E6 00 05 01 02 D8 E8 95 69 7E
Profile Generic 55776Columns:
TX: 11:30:31 7E A0 11 03 21 14 83 79 E6 E6 00 05 01 02 D9 F0 84 EC 7E
RX: 11:30:32 7E A0 10 21 03 70 1A E6 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 1096 Ch. 0 Error object #1
TX: 11:30:32 7E A0 11 03 21 36 93 7B E6 E6 00 05 01 02 04 48 04 3A 7E
RX: 11:30:32 7E A0 17 21 03 92 27 75 E6 E7 00 0C 01 00 09 06 00 00 61 61 00 FF 7A 26 7E
Index: 1 Value: 0.0.97.97.0.255
TX: 11:30:32 7E A0 11 03 21 58 EB F1 E6 E6 00 05 01 02 04 58 85 2A 7E
RX: 11:30:32 7E A0 15 21 03 B4 65 08 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
Index: 3 Value: 1.0, 255
TX: 11:30:32 7E A0 11 03 21 7A FB F3 E6 E6 00 05 01 02 04 50 CD A6 7E
RX: 11:30:32 7E A0 10 21 03 D6 26 26 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 2 Access Error : Device reports Read-Write denied.
-------- Reading 3 18592 Manufacturer specific
TX: 11:30:32 7E A0 11 03 21 9C C3 71 E6 E6 00 05 01 02 48 A0 84 BE 7E
RX: 11:30:32 7E A0 17 21 03 F8 7B B9 E6 E7 00 0C 01 00 09 06 00 00 60 F0 0C FF C4 40 7E
Index: 1 Value: 0.0.96.240.12.255
TX: 11:30:32 7E A0 11 03 21 BE D3 73 E6 E6 00 05 01 02 48 B0 05 AE 7E
RX: 11:30:32 7E A0 15 21 03 1A 11 44 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:30:32 7E A0 11 03 21 D0 AB F9 E6 E6 00 05 01 02 48 A8 CC 32 7E
RX: 11:30:32 7E A0 11 21 03 3C C9 72 E6 E7 00 0C 01 00 11 61 E7 16 7E
Index: 2 Value: 97
-------- Reading 8 11200 Ch. 0 Clock object #1
TX: 11:30:32 7E A0 11 03 21 F2 BB FB E6 E6 00 05 01 02 2B C0 BF 92 7E
RX: 11:30:32 7E A0 17 21 03 5E 47 79 E6 E7 00 0C 01 00 09 06 00 00 01 00 00 FF 0F E0 7E
Index: 1 Value: 0.0.1.0.0.255
TX: 11:30:32 7E A0 11 03 21 14 83 79 E6 E6 00 05 01 02 2B C8 F7 1E 7E
TX: 11:30:32 7E A0 11 03 21 36 93 7B E6 E6 00 05 01 02 2B D0 3E 82 7E
RX: 11:30:32 7E A0 10 21 03 92 06 22 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 3 Access Error : Device reports Read-Write denied.
TX: 11:30:32 7E A0 11 03 21 58 EB F1 E6 E6 00 05 01 02 2B D8 76 0E 7E
RX: 11:30:33 7E A0 11 21 03 B4 89 7A E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:30:33 7E A0 11 03 21 7A FB F3 E6 E6 00 05 01 02 2B E0 BD B3 7E
RX: 11:30:33 7E A0 1D 21 03 D6 A9 AD E6 E7 00 0C 01 00 09 0C FF FF 03 19 07 03 00 FF FF 80 00 FF C7 44 7E
Index: 5 Value: 03/25 03:00 PM
TX: 11:30:33 7E A0 11 03 21 9C C3 71 E6 E6 00 05 01 02 2B E8 F5 3F 7E
RX: 11:30:33 7E A0 1D 21 03 F8 D5 65 E6 E7 00 0C 01 00 09 0C FF FF 0A 19 07 04 00 FF FF 80 00 FF D1 C6 7E
Index: 6 Value: 10/25 04:00 PM
TX: 11:30:33 7E A0 11 03 21 BE D3 73 E6 E6 00 05 01 02 2B F0 3C A3 7E
RX: 11:30:33 7E A0 11 21 03 1A FD 36 E6 E7 00 0C 01 00 0F 3C 06 90 7E
Index: 7 Value: 60
TX: 11:30:33 7E A0 11 03 21 D0 AB F9 E6 E6 00 05 01 02 2B F8 74 2F 7E
RX: 11:30:33 7E A0 11 21 03 3C C9 72 E6 E7 00 0C 01 00 03 01 C0 D3 7E
Index: 8 Value: True
TX: 11:30:33 7E A0 11 03 21 F2 BB FB E6 E6 00 05 01 02 2C 00 BB 19 7E
RX: 11:30:33 7E A0 11 21 03 5E DD 32 E6 E7 00 0C 01 00 16 01 E9 38 7E
Index: 9 Value: 1
-------- Reading 1 1256 Ch. 0 Active firmware signature
TX: 11:30:33 7E A0 11 03 21 14 83 79 E6 E6 00 05 01 02 04 E8 0E 9F 7E
RX: 11:30:33 7E A0 17 21 03 70 3B B1 E6 E7 00 0C 01 00 09 06 01 00 00 02 08 FF E7 83 7E
Index: 1 Value: 1.0.0.2.8.255
-------- Reading 20 51000 Ch. 0 Activity calendar #1
TX: 11:30:33 7E A0 11 03 21 36 93 7B E6 E6 00 05 01 02 C7 38 41 A9 7E
RX: 11:30:33 7E A0 17 21 03 92 27 75 E6 E7 00 0C 01 00 09 06 00 00 0D 00 00 FF 3B 77 7E
Index: 1 Value: 0.0.13.0.0.255
TX: 11:30:33 7E A0 11 03 21 58 EB F1 E6 E6 00 05 01 02 C7 40 8E 56 7E
RX: 11:30:33 7E A0 13 21 03 B4 FF 43 E6 E7 00 0C 01 00 09 02 33 54 5A 9A 7E
Index: 2 Value: 3T
TX: 11:30:33 7E A0 11 03 21 7A FB F3 E6 E6 00 05 01 02 C7 48 C6 DA 7E
RX: 11:30:34 7E A0 53 21 03 D6 5C 15 E6 E7 00 0C 01 00 01 03 02 03 09 01 41 09 0C FF FF 01 01 FF FF FF FF FF 80 00 FF 09 01 00 02 03 09 01 41 09 0C FF FF 04 01 FF FF FF FF FF 80 00 FF 09 01 01 02 03 09 01 41 09 0C FF FF 0B 01 FF FF FF FF FF 80 00 FF 09 01 02 7A 71 7E
Index: 3 Value: A 01/01 12 PM, A 04/01 12 PM, A 11/01 12 PM
TX: 11:30:34 7E A0 11 03 21 9C C3 71 E6 E6 00 05 01 02 C7 50 0F 46 7E
RX: 11:30:34 7E A0 4A 21 03 F8 E2 E7 E6 E7 00 0C 01 00 01 03 02 08 09 01 00 11 01 11 01 11 01 11 01 11 01 11 01 11 01 02 08 09 01 01 11 02 11 02 11 02 11 02 11 02 11 02 11 02 02 08 09 01 02 11 01 11 01 11 01 11 01 11 01 11 01 11 01 CE 00 7E
Index: 4 Value: 00, 01, 02
TX: 11:30:34 7E A0 11 03 21 BE D3 73 E6 E6 00 05 01 02 C7 58 47 CA 7E
RX: 11:30:34 7E A8 76 21 03 1A 18 A2 E6 E7 00 0C 01 00 01 02 02 02 11 01 01 07 02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04 02 03 09 04 06 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 08 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 0B 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 12 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 0F 6E 7E
TX: 11:30:34 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:34 7E A8 6E 21 03 1C 57 E1 02 03 09 04 15 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 16 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04 02 02 11 02 01 07 02 03 09 04 00 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04 02 03 09 04 07 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 08 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 D7 DC 7E
TX: 11:30:34 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:34 7E A0 55 21 03 1E 82 14 02 03 09 04 0C 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 14 00 00 00 09 06 00 00 0A 00 64 FF 12 00 01 02 03 09 04 16 00 00 00 09 06 00 00 0A 00 64 FF 12 00 02 02 03 09 04 17 00 00 00 09 06 00 00 0A 00 64 FF 12 00 04 E0 DD 7E
Index: 5 Value: 1 12:00:00:000000 PM 0.0.10.0.100.255 06:00:00:000000 PM 0.0.10.0.100.255 08:00:00:000000 PM 0.0.10.0.100.255 11:00:00:000000 PM 0.0.10.0.100.255 06:00:00:000000 PM 0.0.10.0.100.255 09:00:00:000000 PM 0.0.10.0.100.255 10:00:00:000000 PM 0.0.10.0.100.255, 2 12:00:00:000000 PM 0.0.10.0.100.255 07:00:00:000000 PM 0.0.10.0.100.255 08:00:00:000000 PM 0.0.10.0.100.255 12:00:00:000000 PM 0.0.10.0.100.255 08:00:00:000000 PM 0.0.10.0.100.255 10:00:00:000000 PM 0.0.10.0.100.255 11:00:00:000000 PM 0.0.10.0.100.255
TX: 11:30:34 7E A0 11 03 21 10 A7 3F E6 E6 00 05 01 02 C7 60 8C 77 7E
RX: 11:30:34 7E A0 11 21 03 30 A5 B8 E6 E7 00 0C 01 00 09 00 39 3F 7E
Index: 6 Value:
TX: 11:30:34 7E A0 11 03 21 32 B7 3D E6 E6 00 05 01 02 C7 68 C4 FB 7E
RX: 11:30:35 7E A0 11 21 03 52 B1 F8 E6 E7 00 0C 01 00 01 00 F9 F1 7E
Index: 7 Value:
TX: 11:30:35 7E A0 11 03 21 54 87 3B E6 E6 00 05 01 02 C7 70 0D 67 7E
RX: 11:30:35 7E A0 11 21 03 74 85 BC E6 E7 00 0C 01 00 01 00 F9 F1 7E
Index: 8 Value:
TX: 11:30:35 7E A0 11 03 21 76 97 39 E6 E6 00 05 01 02 C7 78 45 EB 7E
RX: 11:30:35 7E A0 11 21 03 96 99 78 E6 E7 00 0C 01 00 01 00 F9 F1 7E
Index: 9 Value:
TX: 11:30:35 7E A0 11 03 21 98 E7 37 E6 E6 00 05 01 02 C7 80 82 90 7E
RX: 11:30:35 7E A0 1D 21 03 B8 D1 27 E6 E7 00 0C 01 00 09 0C FF FF FF FF FF FF FF FF FF 80 00 FF 4C D4 7E
Index: 10 Value: 12 PM
-------- Reading 11 51200 Ch. 0 Special days table #1
TX: 11:30:35 7E A0 11 03 21 BA F7 35 E6 E6 00 05 01 02 C8 00 42 97 7E
RX: 11:30:35 7E A0 17 21 03 DA 6B BB E6 E7 00 0C 01 00 09 06 00 00 0B 00 00 FF A1 3C 7E
Index: 1 Value: 0.0.11.0.0.255
TX: 11:30:35 7E A0 11 03 21 DC C7 33 E6 E6 00 05 01 02 C8 08 0A 1B 7E
RX: 11:30:35 7E A8 57 21 03 FC C8 B3 E6 E7 00 0C 01 00 01 4D 02 03 12 00 00 09 05 07 DF 03 1D FF 11 02 02 03 12 00 00 09 05 07 DF 03 1E FF 11 02 02 03 12 00 00 09 05 07 DF 03 1F FF 11 02 02 03 12 00 00 09 05 07 DF 0A 19 FF 11 01 02 03 12 00 00 09 05 07 DF 0A 1A FF 11 01 E2 8D 7E
TX: 11:30:35 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:35 7E A8 4F 21 03 FE A3 B6 02 03 12 00 00 09 05 07 DF 0A 1B FF 11 01 02 03 12 00 00 09 05 07 DF 0A 1C FF 11 01 02 03 12 00 00 09 05 07 DF 0A 1D FF 11 01 02 03 12 00 00 09 05 07 DF 0A 1E FF 11 01 02 03 12 00 00 09 05 07 DF 0A 1F FF 11 01 C0 8B 7E
TX: 11:30:35 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:35 7E A8 4F 21 03 F0 DD 5F 02 03 12 00 00 09 05 07 E0 03 1B FF 11 02 02 03 12 00 00 09 05 07 E0 03 1C FF 11 02 02 03 12 00 00 09 05 07 E0 03 1D FF 11 02 02 03 12 00 00 09 05 07 E0 03 1E FF 11 02 02 03 12 00 00 09 05 07 E0 03 1F FF 11 02 E0 D9 7E
TX: 11:30:35 7E A0 07 03 21 31 17 87 7E
RX: 11:30:36 7E A8 4F 21 03 F2 CF 7C 02 03 12 00 00 09 05 07 E0 0A 1E FF 11 01 02 03 12 00 00 09 05 07 E0 0A 1F FF 11 01 02 03 12 00 00 09 05 07 E1 03 1A FF 11 02 02 03 12 00 00 09 05 07 E1 03 1B FF 11 02 02 03 12 00 00 09 05 07 E1 03 1C FF 11 02 A6 F0 7E
TX: 11:30:36 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:36 7E A8 4F 21 03 F4 F9 19 02 03 12 00 00 09 05 07 E1 03 1D FF 11 02 02 03 12 00 00 09 05 07 E1 03 1E FF 11 02 02 03 12 00 00 09 05 07 E1 03 1F FF 11 02 02 03 12 00 00 09 05 07 E1 0A 1D FF 11 01 02 03 12 00 00 09 05 07 E1 0A 1E FF 11 01 4C 4C 7E
TX: 11:30:36 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:36 7E A8 4F 21 03 F6 EB 3A 02 03 12 00 00 09 05 07 E1 0A 1F FF 11 01 02 03 12 00 00 09 05 07 E2 0A 1C FF 11 01 02 03 12 00 00 09 05 07 E2 0A 1D FF 11 01 02 03 12 00 00 09 05 07 E2 0A 1E FF 11 01 02 03 12 00 00 09 05 07 E2 0A 1F FF 11 01 D9 A8 7E
TX: 11:30:36 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:36 7E A8 4F 21 03 F8 95 D3 02 03 12 00 00 09 05 07 E3 03 1F FF 11 02 02 03 12 00 00 09 05 07 E3 0A 1B FF 11 01 02 03 12 00 00 09 05 07 E3 0A 1C FF 11 01 02 03 12 00 00 09 05 07 E3 0A 1D FF 11 01 02 03 12 00 00 09 05 07 E3 0A 1E FF 11 01 CB EA 7E
TX: 11:30:36 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:36 7E A8 4F 21 03 FA 87 F0 02 03 12 00 00 09 05 07 E3 0A 1F FF 11 01 02 03 12 00 00 09 05 07 E4 03 1D FF 11 02 02 03 12 00 00 09 05 07 E4 03 1E FF 11 02 02 03 12 00 00 09 05 07 E4 03 1F FF 11 02 02 03 12 00 00 09 05 07 E5 03 1C FF 11 02 12 59 7E
TX: 11:30:36 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:36 7E A8 4F 21 03 FC B1 95 02 03 12 00 00 09 05 07 E5 03 1D FF 11 02 02 03 12 00 00 09 05 07 E5 03 1E FF 11 02 02 03 12 00 00 09 05 07 E5 03 1F FF 11 02 02 03 12 00 00 09 05 07 E5 0A 1F FF 11 01 02 03 12 00 00 09 05 07 E6 03 1B FF 11 02 4C 45 7E
TX: 11:30:36 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:36 7E A8 4F 21 03 FE A3 B6 02 03 12 00 00 09 05 07 E6 03 1C FF 11 02 02 03 12 00 00 09 05 07 E6 03 1D FF 11 02 02 03 12 00 00 09 05 07 E6 03 1E FF 11 02 02 03 12 00 00 09 05 07 E6 03 1F FF 11 02 02 03 12 00 00 09 05 07 E6 0A 1E FF 11 01 80 80 7E
TX: 11:30:36 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:37 7E A8 4F 21 03 F0 DD 5F 02 03 12 00 00 09 05 07 E6 0A 1F FF 11 01 02 03 12 00 00 09 05 07 E7 03 1A FF 11 02 02 03 12 00 00 09 05 07 E7 03 1B FF 11 02 02 03 12 00 00 09 05 07 E7 03 1C FF 11 02 02 03 12 00 00 09 05 07 E7 03 1D FF 11 02 FE 9F 7E
TX: 11:30:37 7E A0 07 03 21 31 17 87 7E
RX: 11:30:37 7E A8 4F 21 03 F2 CF 7C 02 03 12 00 00 09 05 07 E7 03 1E FF 11 02 02 03 12 00 00 09 05 07 E7 03 1F FF 11 02 02 03 12 00 00 09 05 07 E7 0A 1D FF 11 01 02 03 12 00 00 09 05 07 E7 0A 1E FF 11 01 02 03 12 00 00 09 05 07 E7 0A 1F FF 11 01 A5 C4 7E
TX: 11:30:37 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:37 7E A8 4F 21 03 F4 F9 19 02 03 12 00 00 09 05 07 E8 03 1F FF 11 02 02 03 12 00 00 09 05 07 E8 0A 1B FF 11 01 02 03 12 00 00 09 05 07 E8 0A 1C FF 11 01 02 03 12 00 00 09 05 07 E8 0A 1D FF 11 01 02 03 12 00 00 09 05 07 E8 0A 1E FF 11 01 01 C0 7E
TX: 11:30:37 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:37 7E A8 4F 21 03 F6 EB 3A 02 03 12 00 00 09 05 07 E8 0A 1F FF 11 01 02 03 12 00 00 09 05 07 E9 03 1E FF 11 02 02 03 12 00 00 09 05 07 E9 03 1F FF 11 02 02 03 12 00 00 09 05 07 E9 0A 1A FF 11 01 02 03 12 00 00 09 05 07 E9 0A 1B FF 11 01 79 DF 7E
TX: 11:30:37 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:37 7E A8 4F 21 03 F8 95 D3 02 03 12 00 00 09 05 07 E9 0A 1C FF 11 01 02 03 12 00 00 09 05 07 E9 0A 1D FF 11 01 02 03 12 00 00 09 05 07 E9 0A 1E FF 11 01 02 03 12 00 00 09 05 07 E9 0A 1F FF 11 01 02 03 12 00 00 09 05 07 EA 03 1D FF 11 02 2C 97 7E
TX: 11:30:37 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:37 7E A0 25 21 03 FA ED EF 02 03 12 00 00 09 05 07 EA 03 1E FF 11 02 02 03 12 00 00 09 05 07 EA 03 1F FF 11 02 F0 2F 7E
Index: 2 Value: 0 03/29/2015 PM 2, 0 03/30/2015 PM 2, 0 03/31/2015 PM 2, 0 10/25/2015 PM 1, 0 10/26/2015 PM 1, 0 10/27/2015 PM 1, 0 10/28/2015 PM 1, 0 10/29/2015 PM 1, 0 10/30/2015 PM 1, 0 10/31/2015 PM 1, 0 03/27/2016 PM 2, 0 03/28/2016 PM 2, 0 03/29/2016 PM 2, 0 03/30/2016 PM 2, 0 03/31/2016 PM 2, 0 10/30/2016 PM 1, 0 10/31/2016 PM 1, 0 03/26/2017 PM 2, 0 03/27/2017 PM 2, 0 03/28/2017 PM 2, 0 03/29/2017 PM 2, 0 03/30/2017 PM 2, 0 03/31/2017 PM 2, 0 10/29/2017 PM 1, 0 10/30/2017 PM 1, 0 10/31/2017 PM 1, 0 10/28/2018 PM 1, 0 10/29/2018 PM 1, 0 10/30/2018 PM 1, 0 10/31/2018 PM 1, 0 03/31/2019 PM 2, 0 10/27/2019 PM 1, 0 10/28/2019 PM 1, 0 10/29/2019 PM 1, 0 10/30/2019 PM 1, 0 10/31/2019 PM 1, 0 03/29/2020 PM 2, 0 03/30/2020 PM 2, 0 03/31/2020 PM 2, 0 03/28/2021 PM 2, 0 03/29/2021 PM 2, 0 03/30/2021 PM 2, 0 03/31/2021 PM 2, 0 10/31/2021 PM 1, 0 03/27/2022 PM 2, 0 03/28/2022 PM 2, 0 03/29/2022 PM 2, 0 03/30/2022 PM 2, 0 03/31/2022 PM 2, 0 10/30/2022 PM 1, 0 10/31/2022 PM 1, 0 03/26/2023 PM 2, 0 03/27/2023 PM 2, 0 03/28/2023 PM 2, 0 03/29/2023 PM 2, 0 03/30/2023 PM 2, 0 03/31/2023 PM 2, 0 10/29/2023 PM 1, 0 10/30/2023 PM 1, 0 10/31/2023 PM 1, 0 03/31/2024 PM 2, 0 10/27/2024 PM 1, 0 10/28/2024 PM 1, 0 10/29/2024 PM 1, 0 10/30/2024 PM 1, 0 10/31/2024 PM 1, 0 03/30/2025 PM 2, 0 03/31/2025 PM 2, 0 10/26/2025 PM 1, 0 10/27/2025 PM 1, 0 10/28/2025 PM 1, 0 10/29/2025 PM 1, 0 10/30/2025 PM 1, 0 10/31/2025 PM 1, 0 03/29/2026 PM 2, 0 03/30/2026 PM 2, 0 03/31/2026 PM 2
-------- Reading 3 1368 Ch. 0 Passive calendar name
TX: 11:30:37 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 05 58 5D 33 7E
RX: 11:30:37 7E A0 17 21 03 1C 51 18 E6 E7 00 0C 01 00 09 06 01 00 00 02 07 FF 2F 00 7E
Index: 1 Value: 1.0.0.2.7.255
TX: 11:30:37 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 05 68 DE 02 7E
RX: 11:30:37 7E A0 15 21 03 3E 37 23 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
Attribute2 is not readable.
-------- Reading 3 1472 Ch. 0 Date of activation of the passive calendar
TX: 11:30:37 7E A0 11 03 21 12 B5 1C E6 E6 00 05 01 02 05 C0 9C 2B 7E
RX: 11:30:38 7E A0 17 21 03 50 39 90 E6 E7 00 0C 01 00 09 06 00 00 60 02 07 FF E0 9D 7E
Index: 1 Value: 0.0.96.2.7.255
TX: 11:30:38 7E A0 11 03 21 34 81 58 E6 E6 00 05 01 02 05 D0 1D 3B 7E
RX: 11:30:38 7E A0 15 21 03 72 5F AB E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 1 1576 Manufacturer specific
TX: 11:30:38 7E A0 11 03 21 56 95 18 E6 E6 00 05 01 02 06 28 B2 6A 7E
RX: 11:30:38 7E A0 17 21 03 94 11 10 E6 E7 00 0C 01 00 09 06 00 00 F0 13 01 FF B6 F8 7E
Index: 1 Value: 0.0.240.19.1.255
TX: 11:30:38 7E A0 11 03 21 78 E9 D0 E6 E6 00 05 01 02 06 30 7B F6 7E
RX: 11:30:38 7E A0 45 21 03 B6 61 FE E6 E7 00 0C 01 00 01 04 02 02 10 00 17 09 06 00 00 16 00 00 FF 02 02 10 00 01 09 06 00 00 F0 13 01 FF 02 02 10 00 00 09 06 FF FF FF FF FF FF 02 02 10 00 00 09 06 FF FF FF FF FF FF 2F 9E 7E
Index: 2 Value: [23, bytearray(b'\x00\x00\x16\x00\x00\xff')], [1, bytearray(b'\x00\x00\xf0\x13\x01\xff')], [0, bytearray(b'\xff\xff\xff\xff\xff\xff')], [0, bytearray(b'\xff\xff\xff\xff\xff\xff')]
-------- Reading 19 1624 Ch. 0 IEC optical port setup
TX: 11:30:38 7E A0 11 03 21 9A F5 14 E6 E6 00 05 01 02 06 58 35 19 7E
RX: 11:30:38 7E A0 17 21 03 D8 79 98 E6 E7 00 0C 01 00 09 06 00 00 14 00 00 FF F9 4D 7E
Index: 1 Value: 0.0.20.0.0.255
TX: 11:30:38 7E A0 11 03 21 BC C1 50 E6 E6 00 05 01 02 06 60 FE A4 7E
RX: 11:30:38 7E A0 11 21 03 FA F3 D1 E6 E7 00 0C 01 00 16 01 E9 38 7E
Index: 2 Value: 1
TX: 11:30:38 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 06 68 B6 28 7E
RX: 11:30:38 7E A0 11 21 03 1C CB 53 E6 E7 00 0C 01 00 16 05 CD 7E 7E
Index: 3 Value: 5
TX: 11:30:38 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 06 70 7F B4 7E
RX: 11:30:38 7E A0 11 21 03 3E DB 51 E6 E7 00 0C 01 00 16 05 CD 7E 7E
Index: 4 Value: 5
TX: 11:30:38 7E A0 11 03 21 12 B5 1C E6 E6 00 05 01 02 06 78 37 38 7E
RX: 11:30:38 7E A0 11 21 03 50 A3 DB E6 E7 00 0C 01 00 16 01 E9 38 7E
Index: 5 Value: 1
TX: 11:30:38 7E A0 11 03 21 34 81 58 E6 E6 00 05 01 02 06 80 F0 43 7E
RX: 11:30:39 7E A0 10 21 03 72 08 C5 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 6 Access Error : Device reports Read-Write denied.
TX: 11:30:39 7E A0 11 03 21 56 95 18 E6 E6 00 05 01 02 06 88 B8 CF 7E
RX: 11:30:39 7E A0 10 21 03 94 30 47 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 7 Access Error : Device reports Read-Write denied.
TX: 11:30:39 7E A0 11 03 21 78 E9 D0 E6 E6 00 05 01 02 06 90 71 53 7E
RX: 11:30:39 7E A0 10 21 03 B6 20 45 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 8 Access Error : Device reports Read-Write denied.
TX: 11:30:39 7E A0 11 03 21 9A F5 14 E6 E6 00 05 01 02 06 98 39 DF 7E
RX: 11:30:39 7E A0 10 21 03 D8 58 CF E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 9 Access Error : Device reports Read-Write denied.
-------- Reading 19 1752 Ch. 0 IEC electrical port setup
TX: 11:30:39 7E A0 11 03 21 BC C1 50 E6 E6 00 05 01 02 06 D8 3D 9D 7E
RX: 11:30:39 7E A0 17 21 03 FA 69 9A E6 E7 00 0C 01 00 09 06 00 00 14 00 01 FF 21 54 7E
Index: 1 Value: 0.0.20.0.1.255
TX: 11:30:39 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 06 E0 F6 20 7E
RX: 11:30:39 7E A0 11 21 03 1C CB 53 E6 E7 00 0C 01 00 16 00 60 29 7E
Index: 2 Value: 0
TX: 11:30:39 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 06 E8 BE AC 7E
RX: 11:30:39 7E A0 11 21 03 3E DB 51 E6 E7 00 0C 01 00 16 00 60 29 7E
Index: 3 Value: 0
TX: 11:30:39 7E A0 11 03 21 12 B5 1C E6 E6 00 05 01 02 06 F0 77 30 7E
RX: 11:30:39 7E A0 11 21 03 50 A3 DB E6 E7 00 0C 01 00 16 03 FB 1B 7E
Index: 4 Value: 3
TX: 11:30:39 7E A0 11 03 21 34 81 58 E6 E6 00 05 01 02 06 F8 3F BC 7E
RX: 11:30:39 7E A0 11 21 03 72 B3 D9 E6 E7 00 0C 01 00 16 01 E9 38 7E
Index: 5 Value: 1
TX: 11:30:39 7E A0 11 03 21 56 95 18 E6 E6 00 05 01 02 07 00 20 DE 7E
TX: 11:30:39 7E A0 11 03 21 78 E9 D0 E6 E6 00 05 01 02 07 08 68 52 7E
RX: 11:30:40 7E A0 10 21 03 B6 20 45 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:30:40 7E A0 11 03 21 9A F5 14 E6 E6 00 05 01 02 07 10 A1 CE 7E
RX: 11:30:40 7E A0 10 21 03 D8 58 CF E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:30:40 7E A0 11 03 21 BC C1 50 E6 E6 00 05 01 02 07 18 E9 42 7E
RX: 11:30:40 7E A0 10 21 03 FA 48 CD E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 23 1880 Ch. 0 IEC HDLC setup
TX: 11:30:40 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 07 58 ED 00 7E
RX: 11:30:40 7E A0 17 21 03 1C 51 18 E6 E7 00 0C 01 00 09 06 00 00 16 00 00 FF 8F 74 7E
Index: 1 Value: 0.0.22.0.0.255
TX: 11:30:40 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 07 60 26 BD 7E
RX: 11:30:40 7E A0 11 21 03 3E DB 51 E6 E7 00 0C 01 00 16 05 CD 7E 7E
Index: 2 Value: 5
TX: 11:30:40 7E A0 11 03 21 12 B5 1C E6 E6 00 05 01 02 07 68 6E 31 7E
RX: 11:30:40 7E A0 11 21 03 50 A3 DB E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 3 Value: 1
TX: 11:30:40 7E A0 11 03 21 34 81 58 E6 E6 00 05 01 02 07 70 A7 AD 7E
RX: 11:30:40 7E A0 11 21 03 72 B3 D9 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:30:40 7E A0 11 03 21 56 95 18 E6 E6 00 05 01 02 07 78 EF 21 7E
RX: 11:30:40 7E A0 11 21 03 94 8B 5B E6 E7 00 0C 01 00 11 F8 AF 1F 7E
Index: 5 Value: 248
TX: 11:30:40 7E A0 11 03 21 78 E9 D0 E6 E6 00 05 01 02 07 80 28 5A 7E
RX: 11:30:40 7E A0 11 21 03 B6 9B 59 E6 E7 00 0C 01 00 11 3E 95 BC 7E
Index: 6 Value: 62
TX: 11:30:40 7E A0 11 03 21 9A F5 14 E6 E6 00 05 01 02 07 88 60 D6 7E
RX: 11:30:40 7E A0 12 21 03 D8 2E F6 E6 E7 00 0C 01 00 12 03 E8 18 B1 7E
Index: 7 Value: 1000
TX: 11:30:40 7E A0 11 03 21 BC C1 50 E6 E6 00 05 01 02 07 90 A9 4A 7E
RX: 11:30:41 7E A0 12 21 03 FA 3E F4 E6 E7 00 0C 01 00 12 00 78 F9 0F 7E
Index: 8 Value: 120
TX: 11:30:41 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 07 98 E1 C6 7E
RX: 11:30:41 7E A0 10 21 03 1C 70 4F E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 23 1984 Ch. 1 IEC HDLC setup
TX: 11:30:41 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 07 C0 2C 18 7E
RX: 11:30:41 7E A0 17 21 03 3E 41 1A E6 E7 00 0C 01 00 09 06 00 01 16 00 00 FF CB 7F 7E
Index: 1 Value: 0.1.22.0.0.255
TX: 11:30:41 7E A0 11 03 21 12 B5 1C E6 E6 00 05 01 02 07 C8 64 94 7E
RX: 11:30:41 7E A0 11 21 03 50 A3 DB E6 E7 00 0C 01 00 16 03 FB 1B 7E
Index: 2 Value: 3
TX: 11:30:41 7E A0 11 03 21 34 81 58 E6 E6 00 05 01 02 07 D0 AD 08 7E
RX: 11:30:41 7E A0 11 21 03 72 B3 D9 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 3 Value: 1
TX: 11:30:41 7E A0 11 03 21 56 95 18 E6 E6 00 05 01 02 07 D8 E5 84 7E
RX: 11:30:41 7E A0 11 21 03 94 8B 5B E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:30:41 7E A0 11 03 21 78 E9 D0 E6 E6 00 05 01 02 07 E0 2E 39 7E
RX: 11:30:41 7E A0 11 21 03 B6 9B 59 E6 E7 00 0C 01 00 11 F8 AF 1F 7E
Index: 5 Value: 248
TX: 11:30:41 7E A0 11 03 21 9A F5 14 E6 E6 00 05 01 02 07 E8 66 B5 7E
RX: 11:30:41 7E A0 11 21 03 D8 E3 D3 E6 E7 00 0C 01 00 11 3E 95 BC 7E
Index: 6 Value: 62
TX: 11:30:41 7E A0 11 03 21 BC C1 50 E6 E6 00 05 01 02 07 F0 AF 29 7E
RX: 11:30:41 7E A0 12 21 03 FA 3E F4 E6 E7 00 0C 01 00 12 03 E8 18 B1 7E
TX: 11:30:41 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 07 F8 E7 A5 7E
RX: 11:30:41 7E A0 12 21 03 1C 06 76 E6 E7 00 0C 01 00 12 00 78 F9 0F 7E
Index: 8 Value: 120
TX: 11:30:41 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 08 00 E8 5D 7E
RX: 11:30:42 7E A0 10 21 03 3E 60 4D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 12 64000 Ch. 0 Current association
TX: 11:30:42 7E A0 11 03 21 12 B5 1C E6 E6 00 05 01 02 FA 00 50 12 7E
RX: 11:30:42 7E A0 17 21 03 50 39 90 E6 E7 00 0C 01 00 09 06 00 00 28 00 00 FF 3F 96 7E
Index: 1 Value: 0.0.40.0.0.255
TX: 11:30:42 7E A0 11 03 21 34 81 58 E6 E6 00 05 01 02 FA 08 18 9E 7E
RX: 11:30:42 7E A8 5B 21 03 72 8A 49 E6 E7 00 0C 01 00 01 82 01 41 02 04 10 00 10 12 27 30 11 01 09 06 00 00 F0 0D 00 FF 02 04 10 01 18 12 27 12 11 08 09 06 00 00 F0 00 00 FF 02 04 10 01 88 12 27 60 11 04 09 06 00 00 F0 0F FF FF 02 04 10 04 48 12 00 03 11 00 09 06 00 00 61 61 00 FF 06 90 7E
TX: 11:30:42 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:42 7E A8 51 21 03 74 12 F0 02 04 10 48 A0 12 00 03 11 00 09 06 00 00 60 F0 0C FF 02 04 10 2B C0 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 04 10 04 E8 12 00 01 11 00 09 06 01 00 00 02 08 FF 02 04 10 C7 38 12 00 14 11 00 09 06 00 00 0D 00 00 FF C8 CD 7E
TX: 11:30:42 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:42 7E A8 51 21 03 76 00 D3 02 04 10 C8 00 12 00 0B 11 00 09 06 00 00 0B 00 00 FF 02 04 10 05 58 12 00 03 11 00 09 06 01 00 00 02 07 FF 02 04 10 05 C0 12 00 03 11 00 09 06 00 00 60 02 07 FF 02 04 10 06 28 12 00 01 11 00 09 06 00 00 F0 13 01 FF 27 65 7E
TX: 11:30:42 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:43 7E A8 51 21 03 78 7E 3A 02 04 10 06 58 12 00 13 11 00 09 06 00 00 14 00 00 FF 02 04 10 06 D8 12 00 13 11 00 09 06 00 00 14 00 01 FF 02 04 10 07 58 12 00 17 11 00 09 06 00 00 16 00 00 FF 02 04 10 07 C0 12 00 17 11 00 09 06 00 01 16 00 00 FF 38 1C 7E
TX: 11:30:43 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:43 7E A8 51 21 03 7A 6C 19 02 04 10 08 28 12 27 1E 11 01 09 06 00 00 60 06 03 FF 02 04 10 FA 00 12 00 0C 11 00 09 06 00 00 28 00 00 FF 02 04 10 08 70 12 27 21 11 0A 09 06 00 00 F0 0A 00 FF 02 04 10 09 10 12 27 24 11 03 09 06 00 00 F0 0C 00 FF D7 0E 7E
TX: 11:30:43 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:43 7E A8 51 21 03 7C 5A 7C 02 04 10 09 30 12 27 22 11 00 09 06 00 00 F0 03 00 FF 02 04 10 67 20 12 27 74 11 07 09 06 00 00 F0 01 00 FF 02 04 10 FC 00 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 04 10 09 50 12 27 38 11 06 09 06 00 00 F0 07 00 FF FB BE 7E
TX: 11:30:43 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:43 7E A8 51 21 03 7E 48 5F 02 04 10 C6 70 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 04 10 09 78 12 00 03 11 00 09 06 00 00 60 5A 02 FF 02 04 10 09 E0 12 00 03 11 00 09 06 00 01 60 F0 08 FF 02 04 10 C0 F8 12 00 03 11 00 09 06 00 02 60 F0 09 FF 6B 16 7E
TX: 11:30:43 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:43 7E A8 51 21 03 70 36 B6 02 04 10 C1 C0 12 00 03 11 00 09 06 00 02 60 F0 08 FF 02 04 10 0A 48 12 29 A4 11 01 09 06 00 00 60 32 00 FF 02 04 10 60 E0 12 00 07 11 01 09 06 01 00 63 62 00 FF 02 04 10 62 70 12 00 07 11 01 09 06 01 00 63 01 00 FF ED C5 7E
TX: 11:30:43 7E A0 07 03 21 31 17 87 7E
RX: 11:30:43 7E A8 51 21 03 72 24 95 02 04 10 64 00 12 00 07 11 01 09 06 00 00 62 01 00 7E 02 04 10 0A A8 12 00 07 11 01 09 06 01 00 63 02 00 FF 02 04 10 0B B0 12 00 03 11 00 09 06 01 01 01 08 01 FF 02 04 10 0C 58 12 00 03 11 00 09 06 01 01 01 08 02 FF CF DC 7E
TX: 11:30:43 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:44 7E A8 51 21 03 74 12 F0 02 04 10 0D 00 12 00 03 11 00 09 06 01 01 01 08 03 FF 02 04 10 0D A8 12 00 03 11 00 09 06 01 01 02 08 01 FF 02 04 10 0E 50 12 00 03 11 00 09 06 01 01 02 08 02 FF 02 04 10 0E F8 12 00 03 11 00 09 06 01 01 02 08 03 FF 2C 08 7E
TX: 11:30:44 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:44 7E A8 51 21 03 76 00 D3 02 04 10 0F A0 12 00 03 11 00 09 06 01 01 03 08 01 FF 02 04 10 10 48 12 00 03 11 00 09 06 01 01 03 08 02 FF 02 04 10 10 F0 12 00 03 11 00 09 06 01 01 03 08 03 FF 02 04 10 11 98 12 00 03 11 00 09 06 01 01 04 08 01 FF 2D 58 7E
TX: 11:30:44 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:44 7E A8 51 21 03 78 7E 3A 02 04 10 12 40 12 00 03 11 00 09 06 01 01 04 08 02 FF 02 04 10 12 E8 12 00 03 11 00 09 06 01 01 04 08 03 FF 02 04 10 13 90 12 00 03 11 00 09 06 01 01 05 08 01 FF 02 04 10 14 38 12 00 03 11 00 09 06 01 01 05 08 02 FF 87 17 7E
TX: 11:30:44 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:44 7E A8 51 21 03 7A 6C 19 02 04 10 14 E0 12 00 03 11 00 09 06 01 01 05 08 03 FF 02 04 10 15 88 12 00 03 11 00 09 06 01 01 06 08 01 FF 02 04 10 16 30 12 00 03 11 00 09 06 01 01 06 08 02 FF 02 04 10 16 D8 12 00 03 11 00 09 06 01 01 06 08 03 FF A0 4E 7E
TX: 11:30:44 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:44 7E A8 51 21 03 7C 5A 7C 02 04 10 17 80 12 00 03 11 00 09 06 01 01 07 08 01 FF 02 04 10 18 28 12 00 03 11 00 09 06 01 01 07 08 02 FF 02 04 10 18 D0 12 00 03 11 00 09 06 01 01 07 08 03 FF 02 04 10 19 78 12 00 03 11 00 09 06 01 01 08 08 01 FF 5F B4 7E
TX: 11:30:44 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:44 7E A8 51 21 03 7E 48 5F 02 04 10 1A 20 12 00 03 11 00 09 06 01 01 08 08 02 FF 02 04 10 1A C8 12 00 03 11 00 09 06 01 01 08 08 03 FF 02 04 10 1B 70 12 00 03 11 00 09 06 01 01 01 1D 00 FF 02 04 10 1C 18 12 00 03 11 00 09 06 01 01 02 1D 00 FF 16 0F 7E
TX: 11:30:44 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:45 7E A8 51 21 03 70 36 B6 02 04 10 1F A0 12 00 03 11 00 09 06 01 01 03 1D 00 FF 02 04 10 20 48 12 00 03 11 00 09 06 01 01 04 1D 00 FF 02 04 10 20 F0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 21 98 12 00 03 11 00 09 06 00 00 7F 00 00 00 C3 92 7E
TX: 11:30:45 7E A0 07 03 21 31 17 87 7E
RX: 11:30:45 7E A8 51 21 03 72 24 95 02 04 10 22 40 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 22 E8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 1C E0 12 00 03 11 00 09 06 01 01 01 08 00 FF 02 04 10 1D 98 12 00 03 11 00 09 06 01 01 02 08 00 FF 81 F3 7E
TX: 11:30:45 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:45 7E A8 51 21 03 74 12 F0 02 04 10 1E 40 12 00 03 11 00 09 06 01 01 03 08 00 FF 02 04 10 1E F8 12 00 03 11 00 09 06 01 01 04 08 00 FF 02 04 10 23 90 12 00 03 11 00 09 06 01 01 05 08 00 FF 02 04 10 24 38 12 00 03 11 00 09 06 01 01 06 08 00 FF 4A 90 7E
TX: 11:30:45 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:45 7E A8 51 21 03 76 00 D3 02 04 10 24 E0 12 00 03 11 00 09 06 01 01 07 08 00 FF 02 04 10 25 88 12 00 03 11 00 09 06 01 01 08 08 00 FF 02 04 10 26 30 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 26 D8 12 00 03 11 00 09 06 00 00 7F 00 00 00 8B 42 7E
TX: 11:30:45 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:45 7E A8 51 21 03 78 7E 3A 02 04 10 27 80 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 28 28 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 28 D0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 29 78 12 00 03 11 00 09 06 00 00 7F 00 00 00 98 93 7E
TX: 11:30:45 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:45 7E A8 51 21 03 7A 6C 19 02 04 10 2A 20 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2A C8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2C B0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2D 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 74 B3 7E
TX: 11:30:45 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:46 7E A8 51 21 03 7C 5A 7C 02 04 10 2E 00 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2E A8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2F 50 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 2F F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 4F 3B 7E
TX: 11:30:46 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:46 7E A8 51 21 03 7E 48 5F 02 04 10 30 A0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 31 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 31 F0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 32 98 12 00 03 11 00 09 06 00 00 7F 00 00 00 BA E0 7E
TX: 11:30:46 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:46 7E A8 51 21 03 70 36 B6 02 04 10 33 40 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 33 E8 12 00 05 11 00 09 06 01 01 01 04 00 FF 02 04 10 34 80 12 00 05 11 00 09 06 01 01 02 04 00 FF 02 04 10 35 18 12 00 05 11 00 09 06 01 01 03 04 00 FF 94 1E 7E
TX: 11:30:46 7E A0 07 03 21 31 17 87 7E
RX: 11:30:46 7E A8 51 21 03 72 24 95 02 04 10 35 B0 12 00 05 11 00 09 06 01 01 04 04 00 FF 02 04 10 36 48 12 00 05 11 00 09 06 01 01 05 04 00 FF 02 04 10 36 E0 12 00 05 11 00 09 06 01 01 06 04 00 FF 02 04 10 38 78 12 00 05 11 00 09 06 01 01 07 04 00 FF 21 6D 7E
TX: 11:30:46 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:46 7E A8 51 21 03 74 12 F0 02 04 10 39 10 12 00 05 11 00 09 06 01 01 08 04 00 FF 02 04 10 3A 08 12 00 05 11 00 09 06 00 00 7F 00 00 00 02 04 10 3A A0 12 00 05 11 00 09 06 00 00 7F 00 00 00 02 04 10 3C 78 12 00 04 11 00 09 06 01 01 01 06 01 FF 98 69 7E
TX: 11:30:46 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:46 7E A8 51 21 03 76 00 D3 02 04 10 3D 00 12 00 04 11 00 09 06 01 01 01 06 02 FF 02 04 10 3D 88 12 00 04 11 00 09 06 01 01 01 06 03 FF 02 04 10 3E 10 12 00 04 11 00 09 06 01 01 02 06 01 FF 02 04 10 3E 98 12 00 04 11 00 09 06 01 01 02 06 02 FF C2 88 7E
TX: 11:30:46 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:46 7E A8 51 21 03 78 7E 3A 02 04 10 3F 20 12 00 04 11 00 09 06 01 01 02 06 03 FF 02 04 10 3F A8 12 00 04 11 00 09 06 01 01 05 06 01 FF 02 04 10 40 30 12 00 04 11 00 09 06 01 01 05 06 02 FF 02 04 10 40 B8 12 00 04 11 00 09 06 01 01 05 06 03 FF 8D A4 7E
TX: 11:30:46 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:47 7E A8 51 21 03 7A 6C 19 02 04 10 41 D8 12 00 04 11 00 09 06 01 01 06 06 01 FF 02 04 10 42 60 12 00 04 11 00 09 06 01 01 06 06 02 FF 02 04 10 42 E8 12 00 04 11 00 09 06 01 01 06 06 03 FF 02 04 10 43 70 12 00 04 11 00 09 06 01 01 07 06 01 FF D0 8F 7E
TX: 11:30:47 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:47 7E A8 51 21 03 7C 5A 7C 02 04 10 43 F8 12 00 04 11 00 09 06 01 01 07 06 02 FF 02 04 10 44 80 12 00 04 11 00 09 06 01 01 07 06 03 FF 02 04 10 45 C0 12 00 04 11 00 09 06 01 01 08 06 01 FF 02 04 10 46 48 12 00 04 11 00 09 06 01 01 08 06 02 FF 04 45 7E
TX: 11:30:47 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:47 7E A8 51 21 03 7E 48 5F 02 04 10 46 D0 12 00 04 11 00 09 06 01 01 08 06 03 FF 02 04 10 47 58 12 00 04 11 00 09 06 01 01 01 06 00 FF 02 04 10 47 E0 12 00 04 11 00 09 06 01 01 02 06 00 FF 02 04 10 49 80 12 00 04 11 00 09 06 01 01 05 06 00 FF 0D 84 7E
TX: 11:30:47 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:47 7E A8 51 21 03 70 36 B6 02 04 10 4A 08 12 00 04 11 00 09 06 01 01 06 06 00 FF 02 04 10 4A 90 12 00 04 11 00 09 06 01 01 07 06 00 FF 02 04 10 4B 18 12 00 04 11 00 09 06 01 01 08 06 00 FF 02 04 10 4B A0 12 00 03 11 00 09 06 01 01 01 02 01 FF E8 3B 7E
TX: 11:30:47 7E A0 07 03 21 31 17 87 7E
RX: 11:30:47 7E A8 51 21 03 72 24 95 02 04 10 4C 08 12 00 03 11 00 09 06 01 01 01 02 02 FF 02 04 10 4C 70 12 00 03 11 00 09 06 01 01 01 02 03 FF 02 04 10 4C D8 12 00 03 11 00 09 06 01 01 02 02 01 FF 02 04 10 4D 40 12 00 03 11 00 09 06 01 01 02 02 02 FF D9 4B 7E
TX: 11:30:47 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:47 7E A8 51 21 03 74 12 F0 02 04 10 4D A8 12 00 03 11 00 09 06 01 01 02 02 03 FF 02 04 10 52 50 12 00 03 11 00 09 06 01 01 05 02 01 FF 02 04 10 52 B8 12 00 03 11 00 09 06 01 01 05 02 02 FF 02 04 10 53 20 12 00 03 11 00 09 06 01 01 05 02 03 FF 9E CC 7E
TX: 11:30:47 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:48 7E A8 51 21 03 76 00 D3 02 04 10 53 88 12 00 03 11 00 09 06 01 01 06 02 01 FF 02 04 10 53 F0 12 00 03 11 00 09 06 01 01 06 02 02 FF 02 04 10 54 58 12 00 03 11 00 09 06 01 01 06 02 03 FF 02 04 10 54 C0 12 00 03 11 00 09 06 01 01 07 02 01 FF 18 C4 7E
TX: 11:30:48 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:48 7E A8 51 21 03 78 7E 3A 02 04 10 55 28 12 00 03 11 00 09 06 01 01 07 02 02 FF 02 04 10 55 90 12 00 03 11 00 09 06 01 01 07 02 03 FF 02 04 10 55 F8 12 00 03 11 00 09 06 01 01 08 02 01 FF 02 04 10 56 60 12 00 03 11 00 09 06 01 01 08 02 02 FF D4 BD 7E
TX: 11:30:48 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:48 7E A8 51 21 03 7A 6C 19 02 04 10 56 C8 12 00 03 11 00 09 06 01 01 08 02 03 FF 02 04 10 57 30 12 00 03 11 00 09 06 01 01 01 02 00 FF 02 04 10 57 98 12 00 03 11 00 09 06 01 01 02 02 00 FF 02 04 10 58 00 12 00 03 11 00 09 06 01 01 05 02 00 FF 76 94 7E
TX: 11:30:48 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:48 7E A8 51 21 03 7C 5A 7C 02 04 10 58 68 12 00 03 11 00 09 06 01 01 06 02 00 FF 02 04 10 58 D0 12 00 03 11 00 09 06 01 01 07 02 00 FF 02 04 10 59 38 12 00 03 11 00 09 06 01 01 08 02 00 FF 02 04 10 59 A0 12 00 01 11 00 09 06 01 00 00 00 00 FF 3A EB 7E
TX: 11:30:48 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:48 7E A8 51 21 03 7E 48 5F 02 04 10 59 D8 12 00 01 11 00 09 06 01 00 00 00 01 FF 02 04 10 5A 10 12 00 01 11 00 09 06 01 00 00 00 02 FF 02 04 10 5A 48 12 00 01 11 00 09 06 01 00 00 00 03 FF 02 04 10 5A 80 12 00 01 11 00 09 06 00 00 60 01 00 FF 27 1B 7E
TX: 11:30:48 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:49 7E A8 51 21 03 70 36 B6 02 04 10 5A B8 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 04 10 5A F0 12 00 03 11 00 09 06 00 00 60 02 01 FF 02 04 10 5B 58 12 00 03 11 00 09 06 00 01 60 02 05 FF 02 04 10 5B C0 12 00 03 11 00 09 06 00 00 60 02 02 FF 9D 9B 7E
TX: 11:30:49 7E A0 07 03 21 31 17 87 7E
RX: 11:30:49 7E A8 51 21 03 72 24 95 02 04 10 5C 28 12 00 01 11 00 09 06 00 00 60 F0 00 FF 02 04 10 FF 00 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 04 10 39 D0 12 00 01 11 00 09 06 01 00 00 02 01 FF 02 04 10 38 40 12 00 01 11 00 09 06 00 00 60 5A FF FF 86 7F 7E
TX: 11:30:49 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:49 7E A8 51 21 03 74 12 F0 02 04 10 FD 00 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 04 10 5C 98 12 00 01 11 00 09 06 00 00 60 63 08 FF 02 04 10 5C D0 12 00 01 11 00 09 06 01 00 00 02 04 FF 02 04 10 5D 08 12 00 01 11 00 09 06 00 00 60 5A 01 FF 6D 2E 7E
TX: 11:30:49 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:49 7E A8 51 21 03 76 00 D3 02 04 10 5D 40 12 00 01 11 00 09 06 01 00 00 01 02 FF 02 04 10 5D 78 12 00 03 11 00 09 06 01 01 00 03 00 FF 02 04 10 5D E0 12 00 03 11 00 09 06 01 01 00 03 01 FF 02 04 10 5E 48 12 00 03 11 00 09 06 01 01 00 04 00 FF 42 24 7E
TX: 11:30:49 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:49 7E A8 51 21 03 78 7E 3A 02 04 10 5E B0 12 00 03 11 00 09 06 01 01 00 04 01 FF 02 04 10 5F 18 12 00 03 11 00 09 06 01 01 00 04 02 FF 02 04 10 5F 80 12 00 03 11 00 09 06 01 01 00 04 03 FF 02 04 10 5F E8 12 00 03 11 00 09 06 01 00 00 03 06 FF 3F 29 7E
TX: 11:30:49 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:50 7E A8 51 21 03 7A 6C 19 02 04 10 60 50 12 00 03 11 00 09 06 01 00 00 03 07 FF 02 04 10 67 B0 12 00 03 11 00 09 06 01 01 48 05 00 FF 02 04 10 68 18 12 00 03 11 00 09 06 01 01 34 05 00 FF 02 04 10 68 80 12 00 03 11 00 09 06 01 01 20 05 00 FF 56 26 7E
TX: 11:30:50 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:50 7E A8 51 21 03 7C 5A 7C 02 04 10 68 E8 12 00 15 11 00 09 06 01 01 20 23 00 FF 02 04 10 69 68 12 00 15 11 00 09 06 01 01 34 23 00 FF 02 04 10 69 E8 12 00 15 11 00 09 06 01 01 48 23 00 FF 02 04 10 6A 68 12 00 15 11 00 09 06 01 01 20 1F 00 FF 43 62 7E
TX: 11:30:50 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:50 7E A8 51 21 03 7E 48 5F 02 04 10 6A E8 12 00 15 11 00 09 06 01 01 34 1F 00 FF 02 04 10 6B 68 12 00 15 11 00 09 06 01 01 48 1F 00 FF 02 04 10 6B E8 12 00 15 11 00 09 06 01 01 1F 23 00 FF 02 04 10 6C 68 12 00 15 11 00 09 06 01 01 33 23 00 FF 6B E6 7E
TX: 11:30:50 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:50 7E A8 51 21 03 70 36 B6 02 04 10 6C E8 12 00 15 11 00 09 06 01 01 47 23 00 FF 02 04 10 6D 68 12 00 15 11 00 09 06 01 01 5B 23 00 FF 02 04 10 7D E8 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 7E 78 12 00 04 11 00 09 06 00 00 7F 00 00 00 C4 14 7E
TX: 11:30:50 7E A0 07 03 21 31 17 87 7E
RX: 11:30:50 7E A8 51 21 03 72 24 95 02 04 10 7F 08 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 7F 98 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 80 28 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 80 B8 12 00 04 11 00 09 06 00 00 7F 00 00 00 6E 4A 7E
TX: 11:30:50 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:51 7E A8 51 21 03 74 12 F0 02 04 10 81 48 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 81 D8 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 82 68 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 82 F8 12 00 04 11 00 09 06 00 00 7F 00 00 00 23 7F 7E
TX: 11:30:51 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:51 7E A8 51 21 03 76 00 D3 02 04 10 83 88 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 84 18 12 00 04 11 00 09 06 00 00 7F 00 00 00 02 04 10 84 A8 12 00 03 11 00 09 06 00 00 60 08 01 FF 02 04 10 85 10 12 00 03 11 00 09 06 00 00 60 08 02 FF AA 11 7E
TX: 11:30:51 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:51 7E A8 51 21 03 78 7E 3A 02 04 10 85 78 12 00 03 11 00 09 06 00 00 60 08 03 FF 02 04 10 85 E0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 86 48 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 86 B0 12 00 03 11 00 09 06 00 00 7F 00 00 00 29 85 7E
TX: 11:30:51 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:51 7E A8 51 21 03 7A 6C 19 02 04 10 87 18 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 87 80 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 87 E8 12 00 03 11 00 09 06 00 00 60 08 00 FF 02 04 10 FE 00 12 00 03 11 00 09 06 00 00 60 02 00 FF 8B 1E 7E
TX: 11:30:51 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:51 7E A8 51 21 03 7C 5A 7C 02 04 10 88 B8 12 00 03 11 00 09 06 01 00 00 01 00 FF 02 04 10 89 F0 12 00 03 11 00 09 06 00 00 60 07 01 FF 02 04 10 8A 58 12 00 03 11 00 09 06 00 00 60 07 02 FF 02 04 10 8A C0 12 00 03 11 00 09 06 00 00 60 07 03 FF 2C 1D 7E
TX: 11:30:51 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:51 7E A8 51 21 03 7E 48 5F 02 04 10 8B 28 12 00 03 11 00 09 06 00 00 60 07 00 FF 02 04 10 8B 90 12 00 03 11 00 09 06 00 00 60 06 00 FF 02 04 10 8B F8 12 27 1A 11 02 09 06 00 00 F0 0E 00 FF 02 04 10 8C 30 12 27 1A 11 02 09 06 00 00 F0 0E 10 FF 71 47 7E
TX: 11:30:51 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:52 7E A8 51 21 03 70 36 B6 02 04 10 8C 68 12 27 1A 11 02 09 06 00 00 F0 0E 20 FF 02 04 10 8C A0 12 27 1A 11 02 09 06 00 00 F0 0E 21 FF 02 04 10 8C D8 12 27 1A 11 02 09 06 00 00 F0 0E 22 FF 02 04 10 8D 10 12 27 1A 11 02 09 06 00 00 F0 0E 23 FF 88 07 7E
TX: 11:30:52 7E A0 07 03 21 31 17 87 7E
RX: 11:30:52 7E A8 51 21 03 72 24 95 02 04 10 8D 48 12 27 1A 11 02 09 06 00 00 F0 0E 24 FF 02 04 10 8D 80 12 27 1A 11 02 09 06 00 00 F0 0E 30 FF 02 04 10 8D B8 12 27 1B 11 02 09 06 00 00 F0 0E 31 FF 02 04 10 8D F0 12 27 43 11 02 09 06 00 00 F0 0E 32 FF 89 F1 7E
TX: 11:30:52 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:52 7E A8 51 21 03 74 12 F0 02 04 10 8E 28 12 27 42 11 02 09 06 00 00 F0 0E 33 FF 02 04 10 8E 60 12 27 1A 11 02 09 06 00 00 F0 0E 25 FF 02 04 10 8E 98 12 27 1A 11 02 09 06 00 00 7F 00 00 00 02 04 10 8E D0 12 27 20 11 02 09 06 00 00 F0 0E 60 FF CB E3 7E
TX: 11:30:52 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:52 7E A8 51 21 03 76 00 D3 02 04 10 8F 80 12 00 03 11 00 09 06 00 00 60 04 00 FF 02 04 10 8F E8 12 00 03 11 00 09 06 00 00 60 05 00 FF 02 04 10 90 50 12 27 27 11 03 09 06 00 00 F0 05 01 FF 02 04 10 90 D0 12 27 27 11 03 09 06 00 00 F0 05 02 FF B2 20 7E
TX: 11:30:52 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:52 7E A8 51 21 03 78 7E 3A 02 04 10 92 50 12 27 27 11 03 09 06 00 00 F0 05 05 FF 02 04 10 92 D0 12 27 27 11 03 09 06 00 00 F0 05 06 FF 02 04 10 93 50 12 27 27 11 03 09 06 00 00 F0 05 07 FF 02 04 10 93 D0 12 27 27 11 03 09 06 00 00 F0 05 08 FF F6 69 7E
TX: 11:30:52 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:52 7E A8 51 21 03 7A 6C 19 02 04 10 94 50 12 00 03 11 00 09 06 01 01 20 07 00 FF 02 04 10 94 E8 12 00 03 11 00 09 06 01 01 34 07 00 FF 02 04 10 95 80 12 00 03 11 00 09 06 01 01 48 07 00 FF 02 04 10 96 18 12 00 03 11 00 09 06 01 01 1F 07 00 FF CF B8 7E
TX: 11:30:52 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:53 7E A8 51 21 03 7C 5A 7C 02 04 10 96 B0 12 00 03 11 00 09 06 01 01 33 07 00 FF 02 04 10 97 48 12 00 03 11 00 09 06 01 01 47 07 00 FF 02 04 10 97 E0 12 00 03 11 00 09 06 01 01 5B 07 00 FF 02 04 10 98 78 12 00 03 11 00 09 06 01 01 0E 07 00 FF 3D A6 7E
TX: 11:30:53 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:53 7E A8 51 21 03 7E 48 5F 02 04 10 99 10 12 00 03 11 00 09 06 01 01 10 07 00 FF 02 04 10 99 A8 12 00 03 11 00 09 06 01 01 83 07 00 FF 02 04 10 9A 40 12 00 03 11 00 09 06 01 01 51 07 00 FF 02 04 10 9A D8 12 00 03 11 00 09 06 01 01 51 07 01 FF A9 9F 7E
TX: 11:30:53 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:53 7E A8 51 21 03 70 36 B6 02 04 10 9B 70 12 00 03 11 00 09 06 01 01 51 07 02 FF 02 04 10 9C 08 12 00 03 11 00 09 06 01 01 51 07 04 FF 02 04 10 9C A0 12 00 03 11 00 09 06 01 01 51 07 0F FF 02 04 10 9D 38 12 00 03 11 00 09 06 01 01 51 07 1A FF 89 76 7E
TX: 11:30:53 7E A0 07 03 21 31 17 87 7E
RX: 11:30:53 7E A8 51 21 03 72 24 95 02 04 10 9D D0 12 00 03 11 00 09 06 01 01 0D 07 00 FF 02 04 10 9E 68 12 00 03 11 00 09 06 01 01 21 07 00 FF 02 04 10 9F 00 12 00 03 11 00 09 06 01 01 35 07 00 FF 02 04 10 9F 98 12 00 03 11 00 09 06 01 01 49 07 00 FF BD 5D 7E
TX: 11:30:53 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:53 7E A8 51 21 03 74 12 F0 02 04 10 A0 30 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A0 C8 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A1 60 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A1 F8 12 00 03 11 00 09 06 00 00 7F 00 00 00 2E B7 7E
TX: 11:30:53 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:54 7E A8 51 21 03 76 00 D3 02 04 10 A2 90 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A3 28 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A3 C0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 A4 58 12 00 03 11 00 09 06 00 00 7F 00 00 00 36 8C 7E
TX: 11:30:54 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:54 7E A8 51 21 03 78 7E 3A 02 04 10 A4 F0 12 00 03 11 00 09 06 00 00 7F 00 00 00 02 04 10 B5 90 12 00 03 11 00 09 06 01 01 24 07 00 FF 02 04 10 B6 28 12 00 03 11 00 09 06 01 01 38 07 00 FF 02 04 10 B6 C0 12 00 03 11 00 09 06 01 01 4C 07 00 FF C0 5C 7E
TX: 11:30:54 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:54 7E A8 51 21 03 7A 6C 19 02 04 10 B7 58 12 00 03 11 00 09 06 01 01 97 07 00 FF 02 04 10 B7 F0 12 00 03 11 00 09 06 01 01 AB 07 00 FF 02 04 10 B8 88 12 00 03 11 00 09 06 01 01 BF 07 00 FF 02 04 10 BB 30 12 27 29 11 02 09 06 00 00 60 03 01 FF D5 26 7E
TX: 11:30:54 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:54 7E A8 51 21 03 7C 5A 7C 02 04 10 BB 78 12 27 29 11 02 09 06 00 00 60 03 02 FF 02 04 10 BB C0 12 27 29 11 02 09 06 00 00 7F 00 00 00 02 04 10 BC 08 12 27 29 11 02 09 06 00 01 60 03 04 FF 02 04 10 BC 50 12 27 29 11 02 09 06 00 00 7F 00 00 00 F6 77 7E
TX: 11:30:54 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:54 7E A8 51 21 03 7E 48 5F 02 04 10 BC 98 12 27 29 11 02 09 06 01 00 60 0A 02 FF 02 04 10 BC E0 12 27 29 11 02 09 06 01 00 60 0A 03 FF 02 04 10 4E 20 12 27 25 11 02 09 06 00 00 F0 09 00 FF 02 04 10 BD 28 12 27 26 11 01 09 06 00 00 F0 08 00 FF C0 B3 7E
TX: 11:30:54 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:54 7E A8 51 21 03 70 36 B6 02 04 10 BD 68 12 27 26 11 01 09 06 00 00 F0 08 01 FF 02 04 10 BD A8 12 27 26 11 01 09 06 00 00 F0 08 02 FF 02 04 10 BD E8 12 27 26 11 01 09 06 00 00 F0 08 03 FF 02 04 10 BE 28 12 27 26 11 01 09 06 00 00 F0 08 04 FF C9 A4 7E
TX: 11:30:54 7E A0 07 03 21 31 17 87 7E
RX: 11:30:55 7E A8 51 21 03 72 24 95 02 04 10 BE 68 12 27 26 11 01 09 06 00 00 F0 08 05 FF 02 04 10 BE A8 12 27 26 11 01 09 06 00 00 F0 08 06 FF 02 04 10 BE E8 12 27 26 11 01 09 06 00 00 F0 08 07 FF 02 04 10 BF 28 12 27 26 11 01 09 06 00 00 F0 08 08 FF 23 17 7E
TX: 11:30:55 7E A0 07 03 21 51 11 E4 7E
RX: 11:30:55 7E A8 51 21 03 74 12 F0 02 04 10 BF 68 12 27 26 11 01 09 06 00 00 F0 08 09 FF 02 04 10 BF A8 12 27 26 11 01 09 06 00 00 F0 08 0A FF 02 04 10 BF E8 12 27 26 11 01 09 06 00 00 F0 08 0B FF 02 04 10 C0 28 12 27 26 11 01 09 06 00 00 F0 08 0C FF F7 79 7E
TX: 11:30:55 7E A0 07 03 21 71 13 C5 7E
RX: 11:30:55 7E A8 51 21 03 76 00 D3 02 04 10 C0 68 12 27 26 11 01 09 06 00 00 F0 08 0D FF 02 04 10 C0 A8 12 27 26 11 01 09 06 00 00 F0 08 0E FF 02 04 10 C1 60 12 27 26 11 01 09 06 00 00 F0 08 0F FF 02 04 10 C8 58 12 00 07 11 01 09 06 00 00 7F 00 00 00 EF 17 7E
TX: 11:30:55 7E A0 07 03 21 91 1D 22 7E
RX: 11:30:55 7E A8 51 21 03 78 7E 3A 02 04 10 C9 60 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CA 68 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CB 70 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CC 78 12 00 07 11 01 09 06 00 00 7F 00 00 00 66 08 7E
TX: 11:30:55 7E A0 07 03 21 B1 1F 03 7E
RX: 11:30:55 7E A8 51 21 03 7A 6C 19 02 04 10 CD 80 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CE 88 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 CF 90 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D0 98 12 00 07 11 01 09 06 00 00 7F 00 00 00 CB B7 7E
TX: 11:30:55 7E A0 07 03 21 D1 19 60 7E
RX: 11:30:55 7E A8 51 21 03 7C 5A 7C 02 04 10 D1 A0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D2 A8 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D3 B0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D4 B8 12 00 07 11 01 09 06 00 00 7F 00 00 00 EC 50 7E
TX: 11:30:55 7E A0 07 03 21 F1 1B 41 7E
RX: 11:30:56 7E A8 51 21 03 7E 48 5F 02 04 10 D5 C0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D6 C8 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D7 D0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 D8 D8 12 00 07 11 01 09 06 00 00 7F 00 00 00 F5 28 7E
TX: 11:30:56 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:56 7E A8 51 21 03 70 36 B6 02 04 10 D9 E0 12 00 07 11 01 09 06 00 00 7F 00 00 00 02 04 10 DB 30 12 27 35 11 00 09 06 00 00 7F 00 00 00 02 04 10 DB 78 12 27 35 11 00 09 06 00 00 7F 00 00 00 02 04 10 DB C0 12 27 36 11 00 09 06 00 00 7F 00 00 00 7C F1 7E
TX: 11:30:56 7E A0 07 03 21 31 17 87 7E
RX: 11:30:56 7E A0 1B 21 03 72 1D 05 02 04 10 DB F8 12 27 36 11 00 09 06 00 00 7F 00 00 00 73 50 7E
Index: 2 Value: 16, 280, 392, 1096, 18592, 11200, 1256, -14536, -14336, 1368, 1472, 1576, 1624, 1752, 1880, 1984, 2088, -1536, 2160, 2320, 2352, 26400, -1024, 2384, -14736, 2424, 2528, -16136, -15936, 2632, 24800, 25200, 25600, 2728, 2992, 3160, 3328, 3496, 3664, 3832, 4000, 4168, 4336, 4504, 4672, 4840, 5008, 5176, 5344, 5512, 5680, 5848, 6016, 6184, 6352, 6520, 6688, 6856, 7024, 7192, 8096, 8264, 8432, 8600, 8768, 8936, 7392, 7576, 7744, 7928, 9104, 9272, 9440, 9608, 9776, 9944, 10112, 10280, 10448, 10616, 10784, 10952, 11440, 11608, 11776, 11944, 12112, 12280, 12448, 12616, 12784, 12952, 13120, 13288, 13440, 13592, 13744, 13896, 14048, 14456, 14608, 14856, 15008, 15480, 15616, 15752, 15888, 16024, 16160, 16296, 16432, 16568, 16856, 16992, 17128, 17264, 17400, 17536, 17856, 17992, 18128, 18264, 18400, 18816, 18952, 19088, 19224, 19360, 19464, 19568, 19672, 19776, 19880, 21072, 21176, 21280, 21384, 21488, 21592, 21696, 21800, 21904, 22008, 22112, 22216, 22320, 22424, 22528, 22632, 22736, 22840, 22944, 23000, 23056, 23112, 23168, 23224, 23280, 23384, 23488, 23592, -256, 14800, 14400, -768, 23704, 23760, 23816, 23872, 23928, 24032, 24136, 24240, 24344, 24448, 24552, 24656, 26544, 26648, 26752, 26856, 26984, 27112, 27240, 27368, 27496, 27624, 27752, 27880, 28008, 32232, 32376, 32520, 32664, -32728, -32584, -32440, -32296, -32152, -32008, -31864, -31720, -31576, -31472, -31368, -31264, -31160, -31056, -30952, -30848, -30744, -512, -30536, -30224, -30120, -30016, -29912, -29808, -29704, -29648, -29592, -29536, -29480, -29424, -29368, -29312, -29256, -29200, -29144, -29088, -29032, -28976, -28800, -28696, -28592, -28464, -28080, -27952, -27824, -27696, -27568, -27416, -27264, -27112, -26960, -26808, -26656, -26504, -26352, -26200, -26048, -25896, -25744, -25592, -25440, -25288, -25136, -24984, -24832, -24680, -24528, -24376, -24224, -24072, -23920, -23768, -23616, -23464, -23312, -19056, -18904, -18752, -18600, -18448, -18296, -17616, -17544, -17472, -17400, -17328, -17256, -17184, 20000, -17112, -17048, -16984, -16920, -16856, -16792, -16728, -16664, -16600, -16536, -16472, -16408, -16344, -16280, -16216, -16032, -14248, -13984, -13720, -13456, -13192, -12928, -12664, -12400, -12136, -11872, -11608, -11344, -11080, -10816, -10552, -10288, -10024, -9760, -9424, -9352, -9280, -9224
-------- Reading 17 64512 Ch. 0 SAP Assignment
TX: 11:30:56 7E A0 11 03 21 56 95 18 E6 E6 00 05 01 02 FC 00 80 46 7E
RX: 11:30:56 7E A0 17 21 03 94 11 10 E6 E7 00 0C 01 00 09 06 00 00 29 00 00 FF 84 8A 7E
Index: 1 Value: 0.0.41.0.0.255
TX: 11:30:56 7E A0 11 03 21 78 E9 D0 E6 E6 00 05 01 02 FC 08 C8 CA 7E
RX: 11:30:56 7E A0 3F 21 03 B6 8A 78 E6 E7 00 0C 01 00 01 02 02 02 12 00 01 09 10 4C 47 5A 33 37 35 36 36 35 31 35 00 00 00 00 00 02 02 12 00 11 09 10 4C 47 5A 39 35 35 39 31 31 37 39 2D 32 00 00 00 AB BD 7E
Index: 2 Value: (1, 'LGZ37566515'), (17, 'LGZ95591179-2')
-------- Reading 22 50800 Ch. 0 End of billing period
TX: 11:30:56 7E A0 11 03 21 9A F5 14 E6 E6 00 05 01 02 C6 70 D5 7E 7E
RX: 11:30:56 7E A0 17 21 03 D8 79 98 E6 E7 00 0C 01 00 09 06 00 00 0F 00 00 FF 4D 4E 7E
Index: 1 Value: 0.0.15.0.0.255
TX: 11:30:56 7E A0 11 03 21 BC C1 50 E6 E6 00 05 01 02 C6 78 9D F2 7E
RX: 11:30:56 7E A0 1C 21 03 FA 7C 5A E6 E7 00 0C 01 00 02 02 09 06 00 00 0A 00 01 FF 12 00 01 B3 80 7E
Index: 2 Value: 0.0.10.0.1.255, 1
TX: 11:30:56 7E A0 11 03 21 DE D5 10 E6 E6 00 05 01 02 C6 80 5A 89 7E
RX: 11:30:57 7E A0 11 21 03 1C CB 53 E6 E7 00 0C 01 00 16 03 FB 1B 7E
Index: 3 Value: 3
TX: 11:30:57 7E A0 11 03 21 F0 A9 D8 E6 E6 00 05 01 02 C6 88 12 05 7E
RX: 11:30:57 7E A8 4D 21 03 3E D9 49 E6 E7 00 0C 01 00 01 0C 02 02 09 04 00 00 00 00 09 05 FF FF FF FF FF 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 7E 23 7E
TX: 11:30:57 7E A0 07 03 21 11 15 A6 7E
RX: 11:30:57 7E A8 54 21 03 30 65 9A 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 FE CC 7E
TX: 11:30:57 7E A0 07 03 21 31 17 87 7E
RX: 11:30:57 7E A0 36 21 03 32 C5 43 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 02 02 09 04 00 00 00 00 09 05 00 00 00 00 00 11 15 7E
Index: 4 Value: 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM, 12:00:00:000000 PM
-------- Reading 3 2424 Ch. 0 Man. spec. abstract object
TX: 11:30:57 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 09 78 FF BB 7E
RX: 11:30:57 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 60 5A 02 FF 79 A6 7E
Index: 1 Value: 0.0.96.90.2.255
TX: 11:30:57 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 09 88 70 4C 7E
RX: 11:30:57 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:30:57 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 09 80 38 C0 7E
RX: 11:30:57 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 2528 Manufacturer specific
TX: 11:30:57 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 09 E0 3E A3 7E
RX: 11:30:57 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 01 60 F0 08 FF E0 2C 7E
Index: 1 Value: 0.1.96.240.8.255
TX: 11:30:57 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 09 F0 BF B3 7E
RX: 11:30:58 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:30:58 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 09 E8 76 2F 7E
RX: 11:30:58 7E A0 23 21 03 FE 53 E2 E6 E7 00 0C 01 00 09 12 0B 06 06 04 00 0C 04 00 14 83 C0 00 83 40 01 83 40 02 2B BD 7E
Index: 2 Value: 0B 06 06 04 00 0C 04 00 14 83 C0 00 83 40 01 83 40 02
-------- Reading 3 49400 Manufacturer specific
TX: 11:30:58 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 C0 F8 45 22 7E
RX: 11:30:58 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 02 60 F0 09 FF F4 28 7E
Index: 1 Value: 0.2.96.240.9.255
TX: 11:30:58 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 C1 08 12 CC 7E
RX: 11:30:58 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:30:58 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 C1 00 5A 40 7E
RX: 11:30:58 7E A0 24 21 03 54 22 BF E6 E7 00 0C 01 00 09 13 02 CB 00 00 FF 00 00 04 30 00 04 50 00 04 80 01 04 80 02 F1 9F 7E
Index: 2 Value: 02 CB 00 00 FF 00 00 04 30 00 04 50 00 04 80 01 04 80 02
-------- Reading 3 49600 Manufacturer specific
TX: 11:30:58 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 C1 C0 56 86 7E
RX: 11:30:58 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 02 60 F0 08 FF 2C 31 7E
Index: 1 Value: 0.2.96.240.8.255
TX: 11:30:58 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 C1 D0 D7 96 7E
RX: 11:30:58 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:30:58 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 C1 C8 1E 0A 7E
RX: 11:30:58 7E A0 24 21 03 BA 52 B1 E6 E7 00 0C 01 00 09 13 02 CB 00 00 FF 00 00 04 30 00 04 50 00 04 80 01 04 80 02 F1 9F 7E
-------- Reading 3 2992 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 1 (0 is total)
TX: 11:30:58 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 0B B0 0B C2 7E
RX: 11:30:58 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 01 08 01 FF 7A 30 7E
Index: 1 Value: 1.1.1.8.1.255
TX: 11:30:58 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 0B C0 8C B1 7E
RX: 11:30:58 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
Index: 3 Value: 0.1, 30
-------- Reading 3 3160 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 2 (0 is total)
TX: 11:30:58 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 0C 58 45 E4 7E
RX: 11:30:59 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 01 08 02 FF 12 1A 7E
Index: 1 Value: 1.1.1.8.2.255
TX: 11:30:59 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 0C 68 C6 D5 7E
RX: 11:30:59 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 3328 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 3 (0 is total)
TX: 11:30:59 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 0D 00 50 23 7E
RX: 11:30:59 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 01 08 03 FF CA 03 7E
Index: 1 Value: 1.1.1.8.3.255
TX: 11:30:59 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 0D 10 D1 33 7E
RX: 11:30:59 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 3496 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 1 (0 is total)
TX: 11:30:59 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 0D A8 12 0A 7E
RX: 11:30:59 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 02 08 01 FF B7 15 7E
Index: 1 Value: 1.1.2.8.1.255
TX: 11:30:59 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 0D B8 93 1A 7E
RX: 11:30:59 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 3664 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 2 (0 is total)
TX: 11:30:59 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 0E 50 BD 5B 7E
RX: 11:30:59 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 02 08 02 FF DF 3F 7E
Index: 1 Value: 1.1.2.8.2.255
TX: 11:30:59 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 0E 60 3E 6A 7E
RX: 11:30:59 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 3832 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 3 (0 is total)
TX: 11:30:59 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 0E F8 FF 72 7E
RX: 11:30:59 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 02 08 03 FF 07 26 7E
Index: 1 Value: 1.1.2.8.3.255
TX: 11:30:59 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 0F 08 A8 9C 7E
-------- Reading 3 4000 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 1 (0 is total)
TX: 11:30:59 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 0F A0 EA B5 7E
RX: 11:31:00 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 03 08 01 FF 0C 09 7E
Index: 1 Value: 1.1.3.8.1.255
TX: 11:31:00 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 0F B0 6B A5 7E
RX: 11:31:00 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
Index: 3 Value: 0.1, 32
-------- Reading 3 4168 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 2 (0 is total)
TX: 11:31:00 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 10 48 F5 C8 7E
RX: 11:31:00 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 03 08 02 FF 64 23 7E
Index: 1 Value: 1.1.3.8.2.255
TX: 11:31:00 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 10 58 74 D8 7E
RX: 11:31:00 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 4336 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 3 (0 is total)
TX: 11:31:00 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 10 F0 36 F1 7E
RX: 11:31:00 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 03 08 03 FF BC 3A 7E
Index: 1 Value: 1.1.3.8.3.255
TX: 11:31:00 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 11 00 61 1F 7E
RX: 11:31:00 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 4504 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 1 (0 is total)
TX: 11:31:00 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 11 98 A0 07 7E
RX: 11:31:00 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 04 08 01 FF 2D 5E 7E
Index: 1 Value: 1.1.4.8.1.255
TX: 11:31:00 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 11 A8 23 36 7E
RX: 11:31:00 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 4672 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 2 (0 is total)
TX: 11:31:00 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 12 40 0D 77 7E
RX: 11:31:00 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 04 08 02 FF 45 74 7E
Index: 1 Value: 1.1.4.8.2.255
TX: 11:31:00 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 12 50 8C 67 7E
-------- Reading 3 4840 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 3 (0 is total)
TX: 11:31:00 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 12 E8 4F 5E 7E
RX: 11:31:01 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 04 08 03 FF 9D 6D 7E
Index: 1 Value: 1.1.4.8.3.255
TX: 11:31:01 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 12 F8 CE 4E 7E
RX: 11:31:01 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 5008 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 1 (0 is total)
TX: 11:31:01 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 13 90 58 B8 7E
RX: 11:31:01 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 05 08 01 FF 96 42 7E
Index: 1 Value: 1.1.5.8.1.255
TX: 11:31:01 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 13 A0 DB 89 7E
RX: 11:31:01 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 5176 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 2 (0 is total)
TX: 11:31:01 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 14 38 12 DC 7E
RX: 11:31:01 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 05 08 02 FF FE 68 7E
Index: 1 Value: 1.1.5.8.2.255
TX: 11:31:01 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 14 48 95 AF 7E
RX: 11:31:01 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 5344 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 3 (0 is total)
TX: 11:31:01 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 14 E0 D7 86 7E
RX: 11:31:01 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 05 08 03 FF 26 71 7E
Index: 1 Value: 1.1.5.8.3.255
TX: 11:31:01 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 14 F0 56 96 7E
RX: 11:31:01 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 5512 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 1 (0 is total)
TX: 11:31:01 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 15 88 41 70 7E
RX: 11:31:01 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 06 08 01 FF 5B 67 7E
Index: 1 Value: 1.1.6.8.1.255
TX: 11:31:01 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 15 98 C0 60 7E
-------- Reading 3 5680 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 2 (0 is total)
TX: 11:31:01 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 16 30 EA 63 7E
RX: 11:31:02 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 06 08 02 FF 33 4D 7E
Index: 1 Value: 1.1.6.8.2.255
TX: 11:31:02 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 16 40 6D 10 7E
RX: 11:31:02 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 5848 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 3 (0 is total)
TX: 11:31:02 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 16 D8 AC 08 7E
RX: 11:31:02 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 06 08 03 FF EB 54 7E
Index: 1 Value: 1.1.6.8.3.255
TX: 11:31:02 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 16 E8 2F 39 7E
RX: 11:31:02 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 6016 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 1 (0 is total)
TX: 11:31:02 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 17 80 B9 CF 7E
RX: 11:31:02 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 07 08 01 FF E0 7B 7E
Index: 1 Value: 1.1.7.8.1.255
TX: 11:31:02 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 17 90 38 DF 7E
RX: 11:31:02 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 6184 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 2 (0 is total)
TX: 11:31:02 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 18 28 33 65 7E
RX: 11:31:02 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 07 08 02 FF 88 51 7E
Index: 1 Value: 1.1.7.8.2.255
TX: 11:31:02 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 18 38 B2 75 7E
RX: 11:31:02 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 6352 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 3 (0 is total)
TX: 11:31:02 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 18 D0 F4 1E 7E
RX: 11:31:02 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 07 08 03 FF 50 48 7E
Index: 1 Value: 1.1.7.8.3.255
TX: 11:31:02 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 18 E0 77 2F 7E
RX: 11:31:03 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 6520 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 1 (0 is total)
TX: 11:31:03 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 19 78 6E 2E 7E
RX: 11:31:03 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 08 08 01 FF 19 C9 7E
Index: 1 Value: 1.1.8.8.1.255
TX: 11:31:03 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 19 88 E1 D9 7E
RX: 11:31:03 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 6688 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 2 (0 is total)
TX: 11:31:03 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 1A 20 CB DA 7E
RX: 11:31:03 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 08 08 02 FF 71 E3 7E
Index: 1 Value: 1.1.8.8.2.255
TX: 11:31:03 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 1A 30 4A CA 7E
RX: 11:31:03 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 6856 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 3 (0 is total)
TX: 11:31:03 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 1A C8 8D B1 7E
RX: 11:31:03 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 08 08 03 FF A9 FA 7E
Index: 1 Value: 1.1.8.8.3.255
TX: 11:31:03 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 1A D8 0C A1 7E
RX: 11:31:03 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 7024 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 5
TX: 11:31:03 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 1B 70 96 91 7E
RX: 11:31:03 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 01 1D 00 FF 8A 95 7E
Index: 1 Value: 1.1.1.29.0.255
TX: 11:31:03 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 1B 80 19 66 7E
RX: 11:31:03 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 7192 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 5
TX: 11:31:03 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 1C 18 D0 33 7E
RX: 11:31:03 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 02 1D 00 FF 47 B0 7E
Index: 1 Value: 1.1.2.29.0.255
TX: 11:31:03 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 1C 28 53 02 7E
RX: 11:31:04 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 8096 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 5
TX: 11:31:04 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 1F A0 7B 20 7E
RX: 11:31:04 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 03 1D 00 FF FC AC 7E
Index: 1 Value: 1.1.3.29.0.255
TX: 11:31:04 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 1F B0 FA 30 7E
RX: 11:31:04 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 8264 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 5
TX: 11:31:04 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 20 48 57 7E 7E
RX: 11:31:04 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 04 1D 00 FF DD FB 7E
Index: 1 Value: 1.1.4.29.0.255
TX: 11:31:04 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 20 58 D6 6E 7E
RX: 11:31:04 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 8432 Ch. 0 Inactive object
TX: 11:31:04 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 20 F0 94 47 7E
RX: 11:31:04 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
Index: 1 Value: 0.0.127.0.0.0
TX: 11:31:04 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 21 00 C3 A9 7E
RX: 11:31:04 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
Index: 3 Value: 0.1, 255
TX: 11:31:04 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 20 F8 DC CB 7E
RX: 11:31:04 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 2 Access Error : Device reports Read-Write denied.
-------- Reading 3 8600 Ch. 0 Inactive object
TX: 11:31:04 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 21 98 02 B1 7E
RX: 11:31:04 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:04 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 21 A8 81 80 7E
RX: 11:31:04 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:04 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 21 A0 C9 0C 7E
RX: 11:31:05 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 8768 Ch. 0 Inactive object
TX: 11:31:05 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 22 40 AF C1 7E
RX: 11:31:05 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:05 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 22 50 2E D1 7E
RX: 11:31:05 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:05 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 22 48 E7 4D 7E
RX: 11:31:05 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 8936 Ch. 0 Inactive object
TX: 11:31:05 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 22 E8 ED E8 7E
RX: 11:31:05 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:05 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 22 F8 6C F8 7E
RX: 11:31:05 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:05 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 22 F0 24 74 7E
RX: 11:31:05 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 7392 Ch. 1 Sum Li Active power+ (QI+QIV) Time integral 1 Rate 0 (0 is total)
TX: 11:31:05 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 1C E0 17 48 7E
RX: 11:31:05 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 01 08 00 FF A2 29 7E
Index: 1 Value: 1.1.1.8.0.255
TX: 11:31:05 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 1C F0 96 58 7E
RX: 11:31:05 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 7576 Ch. 1 Sum Li Active power- (QII+QIII) Time integral 1 Rate 0 (0 is total)
TX: 11:31:05 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 1D 98 00 AE 7E
RX: 11:31:05 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 02 08 00 FF 6F 0C 7E
Index: 1 Value: 1.1.2.8.0.255
TX: 11:31:05 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 1D A8 83 9F 7E
RX: 11:31:06 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 1E 3F F2 7E
-------- Reading 3 7744 Ch. 1 Sum Li Reactive power+ (QI+QII) Time integral 1 Rate 0 (0 is total)
TX: 11:31:06 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 1E 40 AD DE 7E
RX: 11:31:06 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 03 08 00 FF D4 10 7E
Index: 1 Value: 1.1.3.8.0.255
TX: 11:31:06 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 1E 50 2C CE 7E
RX: 11:31:06 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 7928 Ch. 1 Sum Li Reactive power- (QIII+QIV) Time integral 1 Rate 0 (0 is total)
TX: 11:31:06 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 1E F8 6E E7 7E
RX: 11:31:06 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 04 08 00 FF F5 47 7E
Index: 1 Value: 1.1.4.8.0.255
TX: 11:31:06 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 1F 08 39 09 7E
RX: 11:31:06 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 9104 Ch. 1 Sum Li Reactive power QI Time integral 1 Rate 0 (0 is total)
TX: 11:31:06 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 23 90 FA 0E 7E
RX: 11:31:06 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 05 08 00 FF 4E 5B 7E
Index: 1 Value: 1.1.5.8.0.255
TX: 11:31:06 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 23 A0 79 3F 7E
RX: 11:31:06 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 9272 Ch. 1 Sum Li Reactive power QII Time integral 1 Rate 0 (0 is total)
TX: 11:31:06 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 24 38 B0 6A 7E
RX: 11:31:06 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 06 08 00 FF 83 7E 7E
Index: 1 Value: 1.1.6.8.0.255
TX: 11:31:06 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 24 48 37 19 7E
RX: 11:31:06 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 9440 Ch. 1 Sum Li Reactive power QIII Time integral 1 Rate 0 (0 is total)
TX: 11:31:06 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 24 E0 75 30 7E
RX: 11:31:06 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 07 08 00 FF 38 62 7E
Index: 1 Value: 1.1.7.8.0.255
TX: 11:31:06 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 24 F0 F4 20 7E
RX: 11:31:07 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 9608 Ch. 1 Sum Li Reactive power QIV Time integral 1 Rate 0 (0 is total)
TX: 11:31:07 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 25 88 E3 C6 7E
RX: 11:31:07 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 08 08 00 FF C1 D0 7E
Index: 1 Value: 1.1.8.8.0.255
TX: 11:31:07 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 25 98 62 D6 7E
RX: 11:31:07 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 20 C2 2A 7E
-------- Reading 3 9776 Ch. 0 Inactive object
TX: 11:31:07 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 26 30 48 D5 7E
RX: 11:31:07 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:07 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 26 40 CF A6 7E
RX: 11:31:07 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FC 16 00 A4 E4 7E
Index: 3 Value: 0.0001, 0
TX: 11:31:07 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 26 38 00 59 7E
RX: 11:31:07 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 9944 Ch. 0 Inactive object
TX: 11:31:07 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 26 D8 0E BE 7E
RX: 11:31:07 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:07 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 26 E8 8D 8F 7E
RX: 11:31:07 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FC 16 00 A4 E4 7E
TX: 11:31:07 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 26 E0 C5 03 7E
RX: 11:31:07 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 10112 Ch. 0 Inactive object
TX: 11:31:07 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 27 80 1B 79 7E
RX: 11:31:07 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:07 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 27 90 9A 69 7E
RX: 11:31:08 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:08 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 27 88 53 F5 7E
RX: 11:31:08 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 10280 Ch. 0 Inactive object
TX: 11:31:08 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 28 28 91 D3 7E
RX: 11:31:08 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:08 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 28 38 10 C3 7E
RX: 11:31:08 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:08 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 28 30 58 4F 7E
RX: 11:31:08 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 10448 Ch. 0 Inactive object
TX: 11:31:08 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 28 D0 56 A8 7E
RX: 11:31:08 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:08 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 28 E0 D5 99 7E
RX: 11:31:08 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:08 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 28 D8 1E 24 7E
RX: 11:31:08 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 10616 Ch. 0 Inactive object
TX: 11:31:08 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 29 78 CC 98 7E
RX: 11:31:08 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:08 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 29 88 43 6F 7E
RX: 11:31:08 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:08 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 29 80 0B E3 7E
RX: 11:31:09 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 10784 Ch. 0 Inactive object
TX: 11:31:09 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 2A 20 69 6C 7E
RX: 11:31:09 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:09 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 2A 30 E8 7C 7E
RX: 11:31:09 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:09 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 2A 28 21 E0 7E
RX: 11:31:09 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 10952 Ch. 0 Inactive object
TX: 11:31:09 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 2A C8 2F 07 7E
RX: 11:31:09 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:09 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 2A D8 AE 17 7E
RX: 11:31:09 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:09 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 2A D0 E6 9B 7E
RX: 11:31:09 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 11440 Ch. 0 Inactive object
TX: 11:31:09 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 2C B0 30 AC 7E
RX: 11:31:09 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:09 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 2C C0 B7 DF 7E
RX: 11:31:09 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:09 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 2C B8 78 20 7E
RX: 11:31:09 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 11608 Ch. 0 Inactive object
TX: 11:31:09 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 2D 58 AE DE 7E
RX: 11:31:10 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:10 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 2D 68 2D EF 7E
RX: 11:31:10 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:10 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 2D 60 65 63 7E
RX: 11:31:10 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 11776 Ch. 0 Inactive object
TX: 11:31:10 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 2E 00 0B 2A 7E
RX: 11:31:10 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:10 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 2E 10 8A 3A 7E
RX: 11:31:10 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:10 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 2E 08 43 A6 7E
RX: 11:31:10 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 11944 Ch. 0 Inactive object
TX: 11:31:10 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 2E A8 49 03 7E
RX: 11:31:10 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:10 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 2E B8 C8 13 7E
RX: 11:31:10 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:10 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 2E B0 80 9F 7E
RX: 11:31:10 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 12112 Ch. 0 Inactive object
TX: 11:31:10 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 2F 50 56 61 7E
RX: 11:31:10 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:10 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 2F 60 D5 50 7E
RX: 11:31:11 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:11 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 2F 58 1E ED 7E
RX: 11:31:11 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 12280 Ch. 0 Inactive object
TX: 11:31:11 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 2F F8 14 48 7E
RX: 11:31:11 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:11 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 30 08 C2 A9 7E
RX: 11:31:11 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:11 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 30 00 8A 25 7E
RX: 11:31:11 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 12448 Ch. 0 Inactive object
TX: 11:31:11 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 30 A0 80 80 7E
RX: 11:31:11 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:11 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 30 B0 01 90 7E
RX: 11:31:11 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:11 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 30 A8 C8 0C 7E
RX: 11:31:11 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 12616 Ch. 0 Inactive object
TX: 11:31:11 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 31 48 1E F2 7E
RX: 11:31:11 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:11 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 31 58 9F E2 7E
RX: 11:31:11 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:11 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 31 50 D7 6E 7E
RX: 11:31:12 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 12784 Ch. 0 Inactive object
TX: 11:31:12 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 31 F0 DD CB 7E
RX: 11:31:12 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:12 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 32 00 3A 16 7E
RX: 11:31:12 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:12 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 31 F8 95 47 7E
RX: 11:31:12 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 12952 Ch. 0 Inactive object
TX: 11:31:12 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 32 98 FB 0E 7E
RX: 11:31:12 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:12 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 32 A8 78 3F 7E
RX: 11:31:12 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:12 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 32 A0 30 B3 7E
RX: 11:31:12 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 13120 Ch. 0 Inactive object
TX: 11:31:12 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 33 40 E6 4D 7E
RX: 11:31:12 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:12 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 33 50 67 5D 7E
RX: 11:31:12 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:12 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 33 48 AE C1 7E
RX: 11:31:12 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 5 13288 Ch. 1 Sum Li Active power+ (QI+QIV) Current avg. 1 Rate 0 (0 is total)
TX: 11:31:12 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 33 E8 A4 64 7E
RX: 11:31:13 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 01 04 00 FF 01 8C 7E
Index: 1 Value: 1.1.1.4.0.255
TX: 11:31:13 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 34 00 EA 42 7E
RX: 11:31:13 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
Index: 4 Value: 0.1, 27
TX: 11:31:13 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 33 F0 6D F8 7E
RX: 11:31:13 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:13 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 33 F8 25 74 7E
RX: 11:31:13 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 3 Access Error : Device reports Read-Write denied.
TX: 11:31:13 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 34 08 A2 CE 7E
RX: 11:31:13 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:13 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 34 10 6B 52 7E
RX: 11:31:13 7E A0 1D 21 03 10 93 0E E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
Index: 6 Value: 03/20/2024 11:30:00 PM
TX: 11:31:13 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 34 18 23 DE 7E
RX: 11:31:13 7E A0 1D 21 03 32 83 0C E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
Index: 7 Value: 03/20/2024 11:30:00 PM
TX: 11:31:13 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 34 20 E8 63 7E
RX: 11:31:13 7E A0 14 21 03 54 D0 F3 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:13 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 34 28 A0 EF 7E
RX: 11:31:13 7E A0 12 21 03 76 5A BA E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 13440 Ch. 1 Sum Li Active power- (QII+QIII) Current avg. 1 Rate 0 (0 is total)
TX: 11:31:13 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 34 80 E2 C6 7E
RX: 11:31:13 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 02 04 00 FF CC A9 7E
Index: 1 Value: 1.1.2.4.0.255
TX: 11:31:13 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 34 98 2B 5A 7E
RX: 11:31:14 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:14 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 34 88 AA 4A 7E
RX: 11:31:14 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:14 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 34 90 63 D6 7E
RX: 11:31:14 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:14 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 34 A0 E0 E7 7E
RX: 11:31:14 7E A0 11 21 03 10 A7 99 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:14 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 34 A8 A8 6B 7E
RX: 11:31:14 7E A0 1D 21 03 32 83 0C E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:14 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 34 B0 61 F7 7E
RX: 11:31:14 7E A0 1D 21 03 54 B3 0A E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:14 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 34 B8 29 7B 7E
RX: 11:31:14 7E A0 14 21 03 76 C0 F1 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:14 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 34 C0 E6 84 7E
RX: 11:31:14 7E A0 12 21 03 98 2A B4 E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 13592 Ch. 1 Sum Li Reactive power+ (QI+QII) Current avg. 1 Rate 0 (0 is total)
TX: 11:31:14 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 35 18 FB C7 7E
RX: 11:31:14 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 03 04 00 FF 77 B5 7E
Index: 1 Value: 1.1.3.4.0.255
TX: 11:31:14 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 35 30 B1 6A 7E
RX: 11:31:14 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
Index: 4 Value: 0.1, 29
TX: 11:31:14 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 35 20 30 7A 7E
RX: 11:31:15 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:15 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 35 28 78 F6 7E
RX: 11:31:15 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:15 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 35 38 F9 E6 7E
RX: 11:31:15 7E A0 11 21 03 32 B7 9B E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:15 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 35 40 36 19 7E
RX: 11:31:15 7E A0 1D 21 03 54 B3 0A E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:15 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 35 48 7E 95 7E
RX: 11:31:15 7E A0 1D 21 03 76 A3 08 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:15 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 35 50 B7 09 7E
RX: 11:31:15 7E A0 14 21 03 98 B0 FF E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:15 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 35 58 FF 85 7E
RX: 11:31:15 7E A0 12 21 03 BA 3A B6 E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 13744 Ch. 1 Sum Li Reactive power- (QIII+QIV) Current avg. 1 Rate 0 (0 is total)
TX: 11:31:15 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 35 B0 B9 EE 7E
RX: 11:31:15 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 04 04 00 FF 56 E2 7E
Index: 1 Value: 1.1.4.4.0.255
TX: 11:31:15 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 35 C8 76 11 7E
RX: 11:31:15 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:15 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 35 B8 F1 62 7E
TX: 11:31:15 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 35 C0 3E 9D 7E
RX: 11:31:16 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:16 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 35 D0 BF 8D 7E
RX: 11:31:16 7E A0 11 21 03 54 87 9D E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:16 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 35 D8 F7 01 7E
RX: 11:31:16 7E A0 1D 21 03 76 A3 08 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:16 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 35 E0 3C BC 7E
RX: 11:31:16 7E A0 1D 21 03 98 D3 06 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:16 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 35 E8 74 30 7E
RX: 11:31:16 7E A0 14 21 03 BA A0 FD E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:16 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 35 F0 BD AC 7E
RX: 11:31:16 7E A0 12 21 03 DC 0A B0 E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 13896 Ch. 1 Sum Li Reactive power QI Current avg. 1 Rate 0 (0 is total)
TX: 11:31:16 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 36 48 16 BF 7E
RX: 11:31:16 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 05 04 00 FF ED FE 7E
Index: 1 Value: 1.1.5.4.0.255
TX: 11:31:16 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 36 60 5C 12 7E
RX: 11:31:16 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:16 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 36 50 DF 23 7E
TX: 11:31:16 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 36 58 97 AF 7E
RX: 11:31:16 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:16 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 36 68 14 9E 7E
RX: 11:31:17 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:17 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 36 70 DD 02 7E
RX: 11:31:17 7E A0 1D 21 03 98 D3 06 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:17 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 36 78 95 8E 7E
RX: 11:31:17 7E A0 1D 21 03 BA C3 04 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:17 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 36 80 52 F5 7E
RX: 11:31:17 7E A0 14 21 03 DC 90 FB E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:17 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 36 88 1A 79 7E
RX: 11:31:17 7E A0 12 21 03 FE 1A B2 E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 14048 Ch. 1 Sum Li Reactive power QII Current avg. 1 Rate 0 (0 is total)
TX: 11:31:17 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 36 E0 54 96 7E
RX: 11:31:17 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 06 04 00 FF 20 DB 7E
Index: 1 Value: 1.1.6.4.0.255
TX: 11:31:17 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 36 F8 9D 0A 7E
RX: 11:31:17 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:17 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 36 E8 1C 1A 7E
RX: 11:31:17 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:17 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 36 F0 D5 86 7E
RX: 11:31:17 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:17 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 37 00 82 68 7E
RX: 11:31:17 7E A0 11 21 03 98 E7 91 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:17 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 37 08 CA E4 7E
RX: 11:31:18 7E A0 1D 21 03 BA C3 04 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:18 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 37 10 03 78 7E
RX: 11:31:18 7E A0 1D 21 03 DC F3 02 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:18 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 37 18 4B F4 7E
RX: 11:31:18 7E A0 14 21 03 FE 80 F9 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:18 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 37 20 80 49 7E
RX: 11:31:18 7E A0 12 21 03 10 6A BC E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 14456 Ch. 1 Sum Li Reactive power QIII Current avg. 1 Rate 0 (0 is total)
TX: 11:31:18 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 38 78 85 14 7E
RX: 11:31:18 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 07 04 00 FF 9B C7 7E
Index: 1 Value: 1.1.7.4.0.255
TX: 11:31:18 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 38 90 C3 7F 7E
RX: 11:31:18 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:18 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 38 80 42 6F 7E
RX: 11:31:18 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:18 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 38 88 0A E3 7E
RX: 11:31:18 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:18 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 38 98 8B F3 7E
RX: 11:31:18 7E A0 11 21 03 BA F7 93 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:18 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 38 A0 40 4E 7E
TX: 11:31:18 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 38 A8 08 C2 7E
RX: 11:31:19 7E A0 1D 21 03 FE E3 00 E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:19 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 38 B0 C1 5E 7E
RX: 11:31:19 7E A0 14 21 03 10 F0 F7 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:19 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 38 B8 89 D2 7E
RX: 11:31:19 7E A0 12 21 03 32 7A BE E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 14608 Ch. 1 Sum Li Reactive power QIV Current avg. 1 Rate 0 (0 is total)
TX: 11:31:19 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 39 10 13 E2 7E
RX: 11:31:19 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 08 04 00 FF 62 75 7E
Index: 1 Value: 1.1.8.4.0.255
TX: 11:31:19 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 39 28 D8 5F 7E
RX: 11:31:19 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:19 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 39 18 5B 6E 7E
RX: 11:31:19 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:19 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 39 20 90 D3 7E
RX: 11:31:19 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:19 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 39 30 11 C3 7E
RX: 11:31:19 7E A0 11 21 03 DC C7 95 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:19 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 39 38 59 4F 7E
TX: 11:31:19 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 39 40 96 B0 7E
RX: 11:31:19 7E A0 1D 21 03 10 93 0E E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:19 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 39 48 DE 3C 7E
RX: 11:31:20 7E A0 14 21 03 32 E0 F5 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:20 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 39 50 17 A0 7E
RX: 11:31:20 7E A0 12 21 03 54 4A B8 E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 14856 Ch. 0 Inactive object
TX: 11:31:20 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 3A 08 B2 54 7E
RX: 11:31:20 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:20 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 3A 20 F8 F9 7E
RX: 11:31:20 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
Index: 4 Value: 0.1, 255
TX: 11:31:20 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 3A 10 7B C8 7E
RX: 11:31:20 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:20 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 3A 18 33 44 7E
RX: 11:31:20 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:20 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 3A 28 B0 75 7E
RX: 11:31:20 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:20 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 3A 30 79 E9 7E
RX: 11:31:20 7E A0 1D 21 03 10 93 0E E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:20 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 3A 38 31 65 7E
RX: 11:31:20 7E A0 1D 21 03 32 83 0C E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:20 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 3A 40 FE 9A 7E
RX: 11:31:20 7E A0 14 21 03 54 D0 F3 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:20 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 3A 48 B6 16 7E
RX: 11:31:21 7E A0 12 21 03 76 5A BA E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 5 15008 Ch. 0 Inactive object
TX: 11:31:21 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 3A A0 F0 7D 7E
RX: 11:31:21 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:21 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 3A B8 39 E1 7E
RX: 11:31:21 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FF 16 FF B8 04 7E
TX: 11:31:21 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 3A A8 B8 F1 7E
RX: 11:31:21 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:21 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 3A B0 71 6D 7E
RX: 11:31:21 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:21 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 3A C0 F6 1E 7E
RX: 11:31:21 7E A0 11 21 03 10 A7 99 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 5 Value: 0
TX: 11:31:21 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 3A C8 BE 92 7E
RX: 11:31:21 7E A0 1D 21 03 32 83 0C E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:21 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 3A D0 77 0E 7E
RX: 11:31:21 7E A0 1D 21 03 54 B3 0A E6 E7 00 0C 01 00 09 0C 07 E8 03 14 03 0B 1E 00 FF 80 00 00 90 1C 7E
TX: 11:31:21 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 3A D8 3F 82 7E
RX: 11:31:21 7E A0 14 21 03 76 C0 F1 E6 E7 00 0C 01 00 06 00 00 03 84 AE 6B 7E
Index: 8 Value: 900
TX: 11:31:21 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 3A E0 F4 3F 7E
RX: 11:31:21 7E A0 12 21 03 98 2A B4 E6 E7 00 0C 01 00 12 00 01 BF E1 7E
Index: 9 Value: 1
-------- Reading 4 15480 Ch. 1 Sum Li Active power+ (QI+QIV) Max. 1 Rate 1 (0 is total)
TX: 11:31:21 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 3C 78 E5 73 7E
RX: 11:31:22 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 01 06 01 FF 61 20 7E
Index: 1 Value: 1.1.1.6.1.255
TX: 11:31:22 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 3C 88 6A 84 7E
RX: 11:31:22 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
Index: 3 Value: 0.1, 27
Attribute2 is not readable.
TX: 11:31:22 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 3C 90 A3 18 7E
RX: 11:31:22 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:22 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 3C 98 EB 94 7E
RX: 11:31:22 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 5 Access Error : Device reports Read-Write denied.
-------- Reading 4 15616 Ch. 1 Sum Li Active power+ (QI+QIV) Max. 1 Rate 2 (0 is total)
TX: 11:31:22 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 3D 00 F2 95 7E
RX: 11:31:22 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 01 06 02 FF 09 0A 7E
Index: 1 Value: 1.1.1.6.2.255
TX: 11:31:22 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 3D 10 73 85 7E
RX: 11:31:22 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:22 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 3D 18 3B 09 7E
RX: 11:31:22 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:22 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 3D 20 F0 B4 7E
RX: 11:31:22 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 15752 Ch. 1 Sum Li Active power+ (QI+QIV) Max. 1 Rate 3 (0 is total)
TX: 11:31:22 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 3D 88 B2 9D 7E
RX: 11:31:22 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 01 06 03 FF D1 13 7E
Index: 1 Value: 1.1.1.6.3.255
TX: 11:31:22 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 3D 98 33 8D 7E
TX: 11:31:22 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 3D A0 F8 30 7E
RX: 11:31:23 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:23 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 3D A8 B0 BC 7E
RX: 11:31:23 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 15888 Ch. 1 Sum Li Active power- (QII+QIII) Max. 1 Rate 1 (0 is total)
TX: 11:31:23 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 3E 10 1B AF 7E
RX: 11:31:23 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 02 06 01 FF AC 05 7E
Index: 1 Value: 1.1.2.6.1.255
TX: 11:31:23 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 3E 20 98 9E 7E
RX: 11:31:23 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:23 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 3E 28 D0 12 7E
RX: 11:31:23 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:23 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 3E 30 19 8E 7E
RX: 11:31:23 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 16024 Ch. 1 Sum Li Active power- (QII+QIII) Max. 1 Rate 2 (0 is total)
TX: 11:31:23 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 3E 98 5B A7 7E
RX: 11:31:23 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 02 06 02 FF C4 2F 7E
Index: 1 Value: 1.1.2.6.2.255
TX: 11:31:23 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 3E A8 D8 96 7E
RX: 11:31:23 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:23 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 3E B0 11 0A 7E
RX: 11:31:23 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:23 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 3E B8 59 86 7E
-------- Reading 4 16160 Ch. 1 Sum Li Active power- (QII+QIII) Max. 1 Rate 3 (0 is total)
TX: 11:31:23 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 3F 20 40 87 7E
RX: 11:31:24 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 02 06 03 FF 1C 36 7E
Index: 1 Value: 1.1.2.6.3.255
TX: 11:31:24 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 3F 30 C1 97 7E
RX: 11:31:24 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:24 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 3F 38 89 1B 7E
RX: 11:31:24 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:24 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 3F 40 46 E4 7E
RX: 11:31:24 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 16296 Ch. 1 Sum Li Reactive power QI Max. 1 Rate 1 (0 is total)
TX: 11:31:24 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 3F A8 00 8F 7E
RX: 11:31:24 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 05 06 01 FF 8D 52 7E
Index: 1 Value: 1.1.5.6.1.255
TX: 11:31:24 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 3F B8 81 9F 7E
RX: 11:31:24 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
Index: 3 Value: 0.1, 29
TX: 11:31:24 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 3F C0 4E 60 7E
RX: 11:31:24 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:24 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 3F C8 06 EC 7E
RX: 11:31:24 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 16432 Ch. 1 Sum Li Reactive power QI Max. 1 Rate 2 (0 is total)
TX: 11:31:24 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 40 30 CD E4 7E
RX: 11:31:24 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 05 06 02 FF E5 78 7E
Index: 1 Value: 1.1.5.6.2.255
TX: 11:31:24 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 40 40 4A 97 7E
RX: 11:31:24 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:24 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 40 48 02 1B 7E
RX: 11:31:25 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:25 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 40 50 CB 87 7E
RX: 11:31:25 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 16568 Ch. 1 Sum Li Reactive power QI Max. 1 Rate 3 (0 is total)
TX: 11:31:25 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 40 B8 8D EC 7E
RX: 11:31:25 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 05 06 03 FF 3D 61 7E
Index: 1 Value: 1.1.5.6.3.255
TX: 11:31:25 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 40 C8 0A 9F 7E
RX: 11:31:25 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:25 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 40 D0 C3 03 7E
RX: 11:31:25 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:25 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 40 D8 8B 8F 7E
RX: 11:31:25 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 16856 Ch. 1 Sum Li Reactive power QII Max. 1 Rate 1 (0 is total)
TX: 11:31:25 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 41 D8 53 96 7E
RX: 11:31:25 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 06 06 01 FF 40 77 7E
Index: 1 Value: 1.1.6.6.1.255
TX: 11:31:25 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 41 E8 D0 A7 7E
RX: 11:31:25 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:25 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 41 F0 19 3B 7E
RX: 11:31:25 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:25 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 41 F8 51 B7 7E
RX: 11:31:26 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 16992 Ch. 1 Sum Li Reactive power QII Max. 1 Rate 2 (0 is total)
TX: 11:31:26 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 42 60 F8 85 7E
RX: 11:31:26 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 06 06 02 FF 28 5D 7E
Index: 1 Value: 1.1.6.6.2.255
TX: 11:31:26 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 42 70 79 95 7E
RX: 11:31:26 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:26 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 42 78 31 19 7E
RX: 11:31:26 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:26 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 42 80 F6 62 7E
RX: 11:31:26 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 17128 Ch. 1 Sum Li Reactive power QII Max. 1 Rate 3 (0 is total)
TX: 11:31:26 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 42 E8 B8 8D 7E
RX: 11:31:26 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 06 06 03 FF F0 44 7E
Index: 1 Value: 1.1.6.6.3.255
TX: 11:31:26 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 42 F8 39 9D 7E
RX: 11:31:26 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:26 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 43 00 26 FF 7E
RX: 11:31:26 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:26 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 43 08 6E 73 7E
-------- Reading 4 17264 Ch. 1 Sum Li Reactive power QIII Max. 1 Rate 1 (0 is total)
TX: 11:31:26 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 43 70 A1 8C 7E
RX: 11:31:26 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 07 06 01 FF FB 6B 7E
Index: 1 Value: 1.1.7.6.1.255
TX: 11:31:26 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 43 80 2E 7B 7E
RX: 11:31:27 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:27 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 43 88 66 F7 7E
RX: 11:31:27 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:27 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 43 90 AF 6B 7E
RX: 11:31:27 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 17400 Ch. 1 Sum Li Reactive power QIII Max. 1 Rate 2 (0 is total)
TX: 11:31:27 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 43 F8 E1 84 7E
RX: 11:31:27 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 07 06 02 FF 93 41 7E
Index: 1 Value: 1.1.7.6.2.255
TX: 11:31:27 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 44 08 66 3E 7E
RX: 11:31:27 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:27 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 44 10 AF A2 7E
RX: 11:31:27 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:27 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 44 18 E7 2E 7E
RX: 11:31:27 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 17536 Ch. 1 Sum Li Reactive power QIII Max. 1 Rate 3 (0 is total)
TX: 11:31:27 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 44 80 26 36 7E
RX: 11:31:27 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 07 06 03 FF 4B 58 7E
Index: 1 Value: 1.1.7.6.3.255
TX: 11:31:27 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 44 90 A7 26 7E
TX: 11:31:27 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 44 98 EF AA 7E
Index: 4 Value: 0
TX: 11:31:27 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 44 A0 24 17 7E
RX: 11:31:28 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 17856 Ch. 1 Sum Li Reactive power QIV Max. 1 Rate 1 (0 is total)
TX: 11:31:28 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 45 C0 FA 6D 7E
RX: 11:31:28 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 08 06 01 FF 02 D9 7E
Index: 1 Value: 1.1.8.6.1.255
TX: 11:31:28 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 45 D0 7B 7D 7E
RX: 11:31:28 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:28 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 45 D8 33 F1 7E
RX: 11:31:28 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:28 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 45 E0 F8 4C 7E
RX: 11:31:28 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 17992 Ch. 1 Sum Li Reactive power QIV Max. 1 Rate 2 (0 is total)
TX: 11:31:28 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 46 48 D2 4F 7E
RX: 11:31:28 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 08 06 02 FF 6A F3 7E
Index: 1 Value: 1.1.8.6.2.255
TX: 11:31:28 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 46 58 53 5F 7E
RX: 11:31:28 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:28 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 46 60 98 E2 7E
RX: 11:31:28 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:28 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 46 68 D0 6E 7E
-------- Reading 4 18128 Ch. 1 Sum Li Reactive power QIV Max. 1 Rate 3 (0 is total)
TX: 11:31:28 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 46 D0 13 57 7E
RX: 11:31:28 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 08 06 03 FF B2 EA 7E
Index: 1 Value: 1.1.8.6.3.255
TX: 11:31:28 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 46 E0 90 66 7E
RX: 11:31:29 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:29 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 46 E8 D8 EA 7E
RX: 11:31:29 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 00 68 64 7E
Index: 4 Value: 0
TX: 11:31:29 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 46 F0 11 76 7E
RX: 11:31:29 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 18264 Ch. 1 Sum Li Active power+ (QI+QIV) Max. 1 Rate 0 (0 is total)
TX: 11:31:29 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 47 58 8B 46 7E
RX: 11:31:29 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 01 06 00 FF B9 39 7E
Index: 1 Value: 1.1.1.6.0.255
TX: 11:31:29 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 47 68 08 77 7E
RX: 11:31:29 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:29 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 47 70 C1 EB 7E
RX: 11:31:29 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:29 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 47 78 89 67 7E
RX: 11:31:29 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 18400 Ch. 1 Sum Li Active power- (QII+QIII) Max. 1 Rate 0 (0 is total)
TX: 11:31:29 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 47 E0 48 7F 7E
RX: 11:31:29 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 02 06 00 FF 74 1C 7E
Index: 1 Value: 1.1.2.6.0.255
TX: 11:31:29 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 47 F0 C9 6F 7E
RX: 11:31:29 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
TX: 11:31:29 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 47 F8 81 E3 7E
RX: 11:31:29 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:29 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 48 00 8E 1B 7E
RX: 11:31:30 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 18816 Ch. 1 Sum Li Reactive power QI Max. 1 Rate 0 (0 is total)
TX: 11:31:30 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 49 80 5E 86 7E
RX: 11:31:30 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 05 06 00 FF 55 4B 7E
Index: 1 Value: 1.1.5.6.0.255
TX: 11:31:30 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 49 90 DF 96 7E
RX: 11:31:30 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:30 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 49 98 97 1A 7E
RX: 11:31:30 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:30 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 49 A0 5C A7 7E
RX: 11:31:30 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 18952 Ch. 1 Sum Li Reactive power QII Max. 1 Rate 0 (0 is total)
TX: 11:31:30 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 4A 08 76 A4 7E
RX: 11:31:30 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 06 06 00 FF 98 6E 7E
Index: 1 Value: 1.1.6.6.0.255
TX: 11:31:30 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 4A 18 F7 B4 7E
RX: 11:31:30 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:30 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 4A 20 3C 09 7E
RX: 11:31:30 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:30 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 4A 28 74 85 7E
-------- Reading 4 19088 Ch. 1 Sum Li Reactive power QIII Max. 1 Rate 0 (0 is total)
TX: 11:31:30 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 4A 90 B7 BC 7E
RX: 11:31:30 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 07 06 00 FF 23 72 7E
Index: 1 Value: 1.1.7.6.0.255
TX: 11:31:30 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 4A A0 34 8D 7E
RX: 11:31:31 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:31 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 4A A8 7C 01 7E
RX: 11:31:31 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:31 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 4A B0 B5 9D 7E
RX: 11:31:31 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 19224 Ch. 1 Sum Li Reactive power QIV Max. 1 Rate 0 (0 is total)
TX: 11:31:31 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 4B 18 2F AD 7E
RX: 11:31:31 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 08 06 00 FF DA C0 7E
Index: 1 Value: 1.1.8.6.0.255
TX: 11:31:31 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 4B 28 AC 9C 7E
RX: 11:31:31 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
TX: 11:31:31 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 4B 30 65 00 7E
RX: 11:31:31 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 01 E1 75 7E
Index: 4 Value: 1
TX: 11:31:31 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 4B 38 2D 8C 7E
RX: 11:31:31 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 19360 Ch. 1 Sum Li Active power+ (QI+QIV) Cum. max. 1 Rate 1 (0 is total)
TX: 11:31:31 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 4B A0 EC 94 7E
RX: 11:31:31 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 01 02 01 FF 00 43 7E
Index: 1 Value: 1.1.1.2.1.255
TX: 11:31:31 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 4B B0 6D 84 7E
RX: 11:31:31 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 19464 Ch. 1 Sum Li Active power+ (QI+QIV) Cum. max. 1 Rate 2 (0 is total)
TX: 11:31:31 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 4C 08 A6 F0 7E
RX: 11:31:31 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 01 02 02 FF 68 69 7E
Index: 1 Value: 1.1.1.2.2.255
TX: 11:31:31 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 4C 18 27 E0 7E
RX: 11:31:32 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 19568 Ch. 1 Sum Li Active power+ (QI+QIV) Cum. max. 1 Rate 3 (0 is total)
TX: 11:31:32 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 4C 70 69 0F 7E
RX: 11:31:32 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 01 02 03 FF B0 70 7E
Index: 1 Value: 1.1.1.2.3.255
TX: 11:31:32 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 4C 80 E6 F8 7E
RX: 11:31:32 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 19672 Ch. 1 Sum Li Active power- (QII+QIII) Cum. max. 1 Rate 1 (0 is total)
TX: 11:31:32 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 4C D8 2B 26 7E
RX: 11:31:32 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 02 02 01 FF CD 66 7E
Index: 1 Value: 1.1.2.2.1.255
TX: 11:31:32 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 4C E8 A8 17 7E
RX: 11:31:32 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 19776 Ch. 1 Sum Li Active power- (QII+QIII) Cum. max. 1 Rate 2 (0 is total)
TX: 11:31:32 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 4D 40 32 27 7E
RX: 11:31:32 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 02 02 02 FF A5 4C 7E
Index: 1 Value: 1.1.2.2.2.255
TX: 11:31:32 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 4D 50 B3 37 7E
RX: 11:31:32 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 19880 Ch. 1 Sum Li Active power- (QII+QIII) Cum. max. 1 Rate 3 (0 is total)
TX: 11:31:32 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 4D A8 74 4C 7E
RX: 11:31:32 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 02 02 03 FF 7D 55 7E
Index: 1 Value: 1.1.2.2.3.255
TX: 11:31:32 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 4D B8 F5 5C 7E
-------- Reading 3 21072 Ch. 1 Sum Li Reactive power QI Cum. max. 1 Rate 1 (0 is total)
TX: 11:31:32 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 52 50 EA 21 7E
RX: 11:31:32 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 05 02 01 FF EC 31 7E
Index: 1 Value: 1.1.5.2.1.255
TX: 11:31:32 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 52 60 69 10 7E
RX: 11:31:33 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21176 Ch. 1 Sum Li Reactive power QI Cum. max. 1 Rate 2 (0 is total)
TX: 11:31:33 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 52 B8 AC 4A 7E
RX: 11:31:33 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 05 02 02 FF 84 1B 7E
Index: 1 Value: 1.1.5.2.2.255
TX: 11:31:33 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 52 C8 2B 39 7E
RX: 11:31:33 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21280 Ch. 1 Sum Li Reactive power QI Cum. max. 1 Rate 3 (0 is total)
TX: 11:31:33 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 53 20 B5 4B 7E
RX: 11:31:33 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 05 02 03 FF 5C 02 7E
Index: 1 Value: 1.1.5.2.3.255
TX: 11:31:33 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 53 30 34 5B 7E
RX: 11:31:33 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21384 Ch. 1 Sum Li Reactive power QII Cum. max. 1 Rate 1 (0 is total)
TX: 11:31:33 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 53 88 F7 62 7E
RX: 11:31:33 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 06 02 01 FF 21 14 7E
Index: 1 Value: 1.1.6.2.1.255
TX: 11:31:33 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 53 98 76 72 7E
RX: 11:31:33 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21488 Ch. 1 Sum Li Reactive power QII Cum. max. 1 Rate 2 (0 is total)
TX: 11:31:33 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 53 F0 38 9D 7E
RX: 11:31:33 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 06 02 02 FF 49 3E 7E
Index: 1 Value: 1.1.6.2.2.255
TX: 11:31:33 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 54 00 BF 27 7E
-------- Reading 3 21592 Ch. 1 Sum Li Reactive power QII Cum. max. 1 Rate 3 (0 is total)
TX: 11:31:33 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 54 58 72 F9 7E
RX: 11:31:33 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 06 02 03 FF 91 27 7E
Index: 1 Value: 1.1.6.2.3.255
TX: 11:31:33 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 54 68 F1 C8 7E
RX: 11:31:34 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21696 Ch. 1 Sum Li Reactive power QIII Cum. max. 1 Rate 1 (0 is total)
TX: 11:31:34 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 54 C0 B3 E1 7E
RX: 11:31:34 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 07 02 01 FF 9A 08 7E
Index: 1 Value: 1.1.7.2.1.255
TX: 11:31:34 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 54 D0 32 F1 7E
RX: 11:31:34 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21800 Ch. 1 Sum Li Reactive power QIII Cum. max. 1 Rate 2 (0 is total)
TX: 11:31:34 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 55 28 2D 93 7E
RX: 11:31:34 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 07 02 02 FF F2 22 7E
Index: 1 Value: 1.1.7.2.2.255
TX: 11:31:34 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 55 38 AC 83 7E
RX: 11:31:34 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 21904 Ch. 1 Sum Li Reactive power QIII Cum. max. 1 Rate 3 (0 is total)
TX: 11:31:34 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 55 90 EE AA 7E
RX: 11:31:34 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 07 02 03 FF 2A 3B 7E
Index: 1 Value: 1.1.7.2.3.255
TX: 11:31:34 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 55 A0 6D 9B 7E
RX: 11:31:34 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 22008 Ch. 1 Sum Li Reactive power QIV Cum. max. 1 Rate 1 (0 is total)
TX: 11:31:34 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 55 F8 A0 45 7E
RX: 11:31:34 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 08 02 01 FF 63 BA 7E
Index: 1 Value: 1.1.8.2.1.255
TX: 11:31:34 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 56 08 47 98 7E
-------- Reading 3 22112 Ch. 1 Sum Li Reactive power QIV Cum. max. 1 Rate 2 (0 is total)
TX: 11:31:34 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 56 60 09 77 7E
RX: 11:31:34 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 08 02 02 FF 0B 90 7E
Index: 1 Value: 1.1.8.2.2.255
TX: 11:31:34 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 56 70 88 67 7E
RX: 11:31:35 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 22216 Ch. 1 Sum Li Reactive power QIV Cum. max. 1 Rate 3 (0 is total)
TX: 11:31:35 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 56 C8 4B 5E 7E
RX: 11:31:35 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 08 02 03 FF D3 89 7E
Index: 1 Value: 1.1.8.2.3.255
TX: 11:31:35 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 56 D8 CA 4E 7E
RX: 11:31:35 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 22320 Ch. 1 Sum Li Active power+ (QI+QIV) Cum. max. 1 Rate 0 (0 is total)
TX: 11:31:35 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 57 30 54 3C 7E
RX: 11:31:35 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 01 02 00 FF D8 5A 7E
Index: 1 Value: 1.1.1.2.0.255
TX: 11:31:35 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 57 40 D3 4F 7E
RX: 11:31:35 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 22424 Ch. 1 Sum Li Active power- (QII+QIII) Cum. max. 1 Rate 0 (0 is total)
TX: 11:31:35 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 57 98 16 15 7E
RX: 11:31:35 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 02 02 00 FF 15 7F 7E
Index: 1 Value: 1.1.2.2.0.255
TX: 11:31:35 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 57 A8 95 24 7E
RX: 11:31:35 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 1B 92 A5 7E
-------- Reading 3 22528 Ch. 1 Sum Li Reactive power QI Cum. max. 1 Rate 0 (0 is total)
TX: 11:31:35 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 58 00 1F 8E 7E
RX: 11:31:35 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 05 02 00 FF 34 28 7E
Index: 1 Value: 1.1.5.2.0.255
TX: 11:31:35 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 58 10 9E 9E 7E
-------- Reading 3 22632 Ch. 1 Sum Li Reactive power QII Cum. max. 1 Rate 0 (0 is total)
TX: 11:31:35 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 58 68 51 61 7E
RX: 11:31:35 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 06 02 00 FF F9 0D 7E
Index: 1 Value: 1.1.6.2.0.255
TX: 11:31:35 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 58 78 D0 71 7E
RX: 11:31:36 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 22736 Ch. 1 Sum Li Reactive power QIII Cum. max. 1 Rate 0 (0 is total)
TX: 11:31:36 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 58 D0 92 58 7E
RX: 11:31:36 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 07 02 00 FF 42 11 7E
Index: 1 Value: 1.1.7.2.0.255
TX: 11:31:36 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 58 E0 11 69 7E
RX: 11:31:36 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 3 22840 Ch. 1 Sum Li Reactive power QIV Cum. max. 1 Rate 0 (0 is total)
TX: 11:31:36 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 59 38 0C 2A 7E
RX: 11:31:36 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 08 02 00 FF BB A3 7E
Index: 1 Value: 1.1.8.2.0.255
TX: 11:31:36 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 59 48 8B 59 7E
RX: 11:31:36 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FF 16 1D A4 C0 7E
-------- Reading 1 22944 Ch. 0 Electricity ID #1
TX: 11:31:36 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 59 A0 CD 32 7E
RX: 11:31:36 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 00 00 00 00 FF 9F F8 7E
Index: 1 Value: 1.0.0.0.0.255
-------- Reading 1 23000 Ch. 0 Electricity ID #2
TX: 11:31:36 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 59 D8 02 CD 7E
RX: 11:31:36 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 00 00 00 01 FF 47 E1 7E
Index: 1 Value: 1.0.0.0.1.255
-------- Reading 1 23056 Ch. 0 Electricity ID #3
TX: 11:31:36 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 5A 10 2E AD 7E
RX: 11:31:36 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 00 00 00 02 FF 2F CB 7E
Index: 1 Value: 1.0.0.0.2.255
-------- Reading 1 23112 Ch. 0 Electricity ID #4
TX: 11:31:36 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 5A 48 E3 73 7E
RX: 11:31:36 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 00 00 00 03 FF F7 D2 7E
Index: 1 Value: 1.0.0.0.3.255
-------- Reading 1 23168 Ch. 0 Device ID 1, manufacturing number
TX: 11:31:36 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 5A 80 A7 39 7E
RX: 11:31:36 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 60 01 00 FF 8C 3F 7E
Index: 1 Value: 0.0.96.1.0.255
-------- Reading 1 23224 Ch. 0 Device ID #2
TX: 11:31:36 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 5A B8 6C 84 7E
RX: 11:31:37 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 60 01 01 FF 54 26 7E
Index: 1 Value: 0.0.96.1.1.255
-------- Reading 3 23280 Ch. 0 Date of last configuration program change
TX: 11:31:37 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 5A F0 20 4A 7E
RX: 11:31:37 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 60 02 01 FF 30 C9 7E
Index: 1 Value: 0.0.96.2.1.255
TX: 11:31:37 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 5B 00 77 A4 7E
RX: 11:31:37 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
Index: 3 Value: 1.0, 255
-------- Reading 3 23384 Ch. 1 Date of last calibration
TX: 11:31:37 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 5B 58 BA 7A 7E
RX: 11:31:37 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 01 60 02 05 FF 14 A5 7E
Index: 1 Value: 0.1.96.2.5.255
TX: 11:31:37 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 5B 68 39 4B 7E
RX: 11:31:37 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 3 23488 Ch. 0 Date of last time switch program change
TX: 11:31:37 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 5B C0 7B 62 7E
RX: 11:31:37 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 60 02 02 FF 58 E3 7E
Index: 1 Value: 0.0.96.2.2.255
TX: 11:31:37 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 5B D0 FA 72 7E
RX: 11:31:37 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 1 23592 Manufacturer specific
TX: 11:31:37 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 5C 28 35 44 7E
RX: 11:31:37 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 60 F0 00 FF 64 E9 7E
Index: 1 Value: 0.0.96.240.0.255
TX: 11:31:37 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 5C 30 FC D8 7E
RX: 11:31:37 7E A0 1F 21 03 54 C5 33 E6 E7 00 0C 01 00 0A 0E 42 33 32 2E 47 20 31 32 2E 30 39 2E 30 34 00 CA 7E
Index: 2 Value: B32.G 12.09.04
-------- Reading 1 65280 Ch. 0 Active firmware identifier
TX: 11:31:37 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 FF 00 E8 6C 7E
RX: 11:31:37 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 00 00 02 00 FF 27 4D 7E
Index: 1 Value: 1.0.0.2.0.255
-------- Reading 1 14800 Ch. 0 Parameter record number
TX: 11:31:37 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 39 D0 1F 24 7E
RX: 11:31:38 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 00 00 02 01 FF FF 54 7E
Index: 1 Value: 1.0.0.2.1.255
-------- Reading 1 14400 Ch. 0 Man. spec. abstract object
TX: 11:31:38 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 38 40 4E A9 7E
RX: 11:31:38 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 60 5A FF FF 09 6A 7E
Index: 1 Value: 0.0.96.90.255.255
TX: 11:31:38 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 38 48 06 25 7E
RX: 11:31:38 7E A0 36 21 03 DC B5 4D E6 E7 00 0C 01 00 0A 25 42 2E 4D 34 48 43 50 54 53 43 6D 44 6F 2E 30 34 35 39 2E 4C 54 30 53 54 76 47 73 61 72 68 73 50 70 6E 61 67 6C 90 62 7E
Index: 2 Value: B.M4HCPTSCmDo.0459.LT0STvGsarhsPpnagl
-------- Reading 1 64768 Ch. 0 COSEM Logical device name
TX: 11:31:38 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 FD 00 58 5F 7E
RX: 11:31:38 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 2A 00 00 FF 49 AF 7E
Index: 1 Value: 0.0.42.0.0.255
-------- Reading 1 23704 Ch. 0 Man. spec. abstract object
TX: 11:31:38 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 5C 98 BE F1 7E
RX: 11:31:38 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 60 63 08 FF B9 41 7E
Index: 1 Value: 0.0.96.99.8.255
TX: 11:31:38 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 5C A0 75 4C 7E
RX: 11:31:38 7E A0 11 21 03 32 B7 9B E6 E7 00 0C 01 00 0A 00 51 15 7E
Index: 2 Value:
-------- Reading 1 23760 Ch. 0 Meter connection diagram ID
TX: 11:31:38 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 5C D0 F2 3F 7E
RX: 11:31:38 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 00 00 02 04 FF 47 2A 7E
Index: 1 Value: 1.0.0.2.4.255
-------- Reading 1 23816 Ch. 0 Man. spec. abstract object
TX: 11:31:38 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 5D 08 EF 7C 7E
RX: 11:31:38 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 60 5A 01 FF 11 8C 7E
Index: 1 Value: 0.0.96.90.1.255
TX: 11:31:38 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 5D 10 26 E0 7E
RX: 11:31:38 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
Error! Index: 2 Access Error : Device reports Read-Write denied.
-------- Reading 1 23872 Ch. 0 Time stamp of the most recent billing period closed (1)
TX: 11:31:38 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 5D 40 A3 B2 7E
RX: 11:31:38 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 00 00 01 02 FF F3 91 7E
Index: 1 Value: 1.0.0.1.2.255
-------- Reading 3 23928 Ch. 1 Meter constant Active energy, metrological LED
TX: 11:31:38 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 5D 78 68 0F 7E
RX: 11:31:39 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 00 03 00 FF BF 1C 7E
Index: 1 Value: 1.1.0.3.0.255
TX: 11:31:39 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 5D 88 E7 F8 7E
RX: 11:31:39 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FD 16 2D 9F 44 7E
Index: 3 Value: 0.001, 45
-------- Reading 3 24032 Ch. 1 Meter constant Reactive energy, metrological LED
TX: 11:31:39 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 5D E0 A9 17 7E
RX: 11:31:39 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 00 03 01 FF 67 05 7E
Index: 1 Value: 1.1.0.3.1.255
TX: 11:31:39 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 5D F0 28 07 7E
RX: 11:31:39 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FD 16 2E 04 76 7E
Index: 3 Value: 0.001, 46
-------- Reading 3 24136 Ch. 1 Reading factor for power
TX: 11:31:39 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 5E 48 83 14 7E
RX: 11:31:39 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 00 04 00 FF BA 90 7E
Index: 1 Value: 1.1.0.4.0.255
TX: 11:31:39 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 5E 58 02 04 7E
RX: 11:31:39 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 3 24240 Ch. 1 Reading factor for energy
TX: 11:31:39 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 5E B0 44 6F 7E
RX: 11:31:39 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 00 04 01 FF 62 89 7E
Index: 1 Value: 1.1.0.4.1.255
TX: 11:31:39 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 5E C0 C3 1C 7E
RX: 11:31:39 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 3 24344 Ch. 1 Transformer ratio - current (numerator)
TX: 11:31:39 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 5F 18 DE 5F 7E
RX: 11:31:39 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 00 04 02 FF 0A A3 7E
Index: 1 Value: 1.1.0.4.2.255
TX: 11:31:39 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 5F 28 5D 6E 7E
RX: 11:31:39 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 3 24448 Ch. 1 Transformer ratio - voltage (numerator)
TX: 11:31:39 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 5F 80 1F 47 7E
RX: 11:31:40 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 00 04 03 FF D2 BA 7E
Index: 1 Value: 1.1.0.4.3.255
TX: 11:31:40 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 5F 90 9E 57 7E
RX: 11:31:40 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
-------- Reading 3 24552 Ch. 0 Meter constant Volt-squared hours, metrological LED
TX: 11:31:40 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 5F E8 51 A8 7E
RX: 11:31:40 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 00 00 03 06 FF 2B 43 7E
Index: 1 Value: 1.0.0.3.6.255
TX: 11:31:40 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 5F F8 D0 B8 7E
RX: 11:31:40 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FD 16 2D 9F 44 7E
-------- Reading 3 24656 Ch. 0 Meter constant Ampere-squared hours, metrological LED
TX: 11:31:40 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 60 50 F8 A4 7E
RX: 11:31:40 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 00 00 03 07 FF F3 5A 7E
Index: 1 Value: 1.0.0.3.7.255
TX: 11:31:40 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 60 60 7B 95 7E
RX: 11:31:40 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FD 16 2D 9F 44 7E
-------- Reading 3 26544 Ch. 1 L3 Voltage Last avg. 1 Rate 0 (0 is total)
TX: 11:31:40 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 67 B0 FE 0E 7E
RX: 11:31:40 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 48 05 00 FF 09 39 7E
Index: 1 Value: 1.1.72.5.0.255
TX: 11:31:40 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 67 C0 79 7D 7E
RX: 11:31:40 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
Index: 3 Value: 0.01, 35
-------- Reading 3 26648 Ch. 1 L2 Voltage Last avg. 1 Rate 0 (0 is total)
TX: 11:31:40 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 68 18 74 A4 7E
RX: 11:31:40 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 34 05 00 FF 78 F4 7E
Index: 1 Value: 1.1.52.5.0.255
TX: 11:31:40 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 68 28 F7 95 7E
RX: 11:31:40 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
-------- Reading 3 26752 Ch. 1 L1 Voltage Last avg. 1 Rate 0 (0 is total)
TX: 11:31:40 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 68 80 B5 BC 7E
RX: 11:31:41 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 20 05 00 FF 35 45 7E
Index: 1 Value: 1.1.32.5.0.255
TX: 11:31:41 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 68 90 34 AC 7E
RX: 11:31:41 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
-------- Reading 21 26856 Ch. 1 L1 Voltage Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:41 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 68 E8 FB 53 7E
RX: 11:31:41 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 20 23 00 FF D7 90 7E
Index: 1 Value: 1.1.32.35.0.255
TX: 11:31:41 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 68 F0 32 CF 7E
RX: 11:31:41 7E A0 16 21 03 BA D6 C4 E6 E7 00 0C 01 00 01 01 05 00 00 1B 30 E0 08 7E
Index: 2 Value: 6960
TX: 11:31:41 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 68 F8 7A 43 7E
RX: 11:31:41 7E A0 1E 21 03 DC 3E 27 E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 20 07 00 FF 0F 02 A7 37 7E
Index: 3 Value: 3 1.1.32.7.0.255 2
TX: 11:31:41 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 69 00 65 21 7E
RX: 11:31:41 7E A0 2D 21 03 FE 11 4C E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1ad750>
-------- Reading 21 26984 Ch. 1 L2 Voltage Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:41 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 69 68 2B CE 7E
RX: 11:31:41 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 34 23 00 FF 9A 21 7E
Index: 1 Value: 1.1.52.35.0.255
TX: 11:31:41 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 69 70 E2 52 7E
RX: 11:31:41 7E A0 16 21 03 32 96 CC E6 E7 00 0C 01 00 01 01 05 00 00 1B 30 E0 08 7E
TX: 11:31:41 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 69 78 AA DE 7E
RX: 11:31:41 7E A0 1E 21 03 54 7E 2F E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 34 07 00 FF 0F 02 BB 65 7E
Index: 3 Value: 3 1.1.52.7.0.255 2
TX: 11:31:41 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 69 80 6D A5 7E
RX: 11:31:41 7E A0 2D 21 03 76 51 44 E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1ad990>
-------- Reading 21 27112 Ch. 1 L3 Voltage Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:41 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 69 E8 23 4A 7E
RX: 11:31:42 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 48 23 00 FF EB EC 7E
Index: 1 Value: 1.1.72.35.0.255
TX: 11:31:42 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 69 F0 EA D6 7E
RX: 11:31:42 7E A0 16 21 03 BA D6 C4 E6 E7 00 0C 01 00 01 01 05 00 00 1B 30 E0 08 7E
TX: 11:31:42 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 69 F8 A2 5A 7E
RX: 11:31:42 7E A0 1E 21 03 DC 3E 27 E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 48 07 00 FF 0F 02 4E 91 7E
Index: 3 Value: 3 1.1.72.7.0.255 2
TX: 11:31:42 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 6A 00 0D 0B 7E
RX: 11:31:42 7E A0 2D 21 03 FE 11 4C E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1adbd0>
-------- Reading 21 27240 Ch. 1 L1 Voltage Inst. value, under limit threshold Harmonic / Distortion factor 0
TX: 11:31:42 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 6A 68 43 E4 7E
RX: 11:31:42 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 20 1F 00 FF DA B3 7E
Index: 1 Value: 1.1.32.31.0.255
TX: 11:31:42 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 6A 70 8A 78 7E
RX: 11:31:42 7E A0 16 21 03 32 96 CC E6 E7 00 0C 01 00 01 01 05 00 00 13 42 B5 96 7E
Index: 2 Value: 4930
TX: 11:31:42 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 6A 78 C2 F4 7E
RX: 11:31:42 7E A0 1E 21 03 54 7E 2F E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 20 07 00 FF 0F 02 A7 37 7E
TX: 11:31:42 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 6A 80 05 8F 7E
RX: 11:31:42 7E A0 2D 21 03 76 51 44 E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1ade10>
-------- Reading 21 27368 Ch. 1 L2 Voltage Inst. value, under limit threshold Harmonic / Distortion factor 0
TX: 11:31:42 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 6A E8 4B 60 7E
RX: 11:31:42 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 34 1F 00 FF 97 02 7E
Index: 1 Value: 1.1.52.31.0.255
TX: 11:31:42 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 6A F0 82 FC 7E
RX: 11:31:42 7E A0 16 21 03 BA D6 C4 E6 E7 00 0C 01 00 01 01 05 00 00 13 42 B5 96 7E
TX: 11:31:42 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 6A F8 CA 70 7E
RX: 11:31:43 7E A0 1E 21 03 DC 3E 27 E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 34 07 00 FF 0F 02 BB 65 7E
TX: 11:31:43 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 6B 00 D5 12 7E
RX: 11:31:43 7E A0 2D 21 03 FE 11 4C E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1ae050>
-------- Reading 21 27496 Ch. 1 L3 Voltage Inst. value, under limit threshold Harmonic / Distortion factor 0
TX: 11:31:43 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 6B 68 9B FD 7E
RX: 11:31:43 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 48 1F 00 FF E6 CF 7E
Index: 1 Value: 1.1.72.31.0.255
TX: 11:31:43 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 6B 70 52 61 7E
RX: 11:31:43 7E A0 16 21 03 32 96 CC E6 E7 00 0C 01 00 01 01 05 00 00 13 42 B5 96 7E
TX: 11:31:43 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 6B 78 1A ED 7E
RX: 11:31:43 7E A0 1E 21 03 54 7E 2F E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 48 07 00 FF 0F 02 4E 91 7E
TX: 11:31:43 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 6B 80 DD 96 7E
RX: 11:31:43 7E A0 2D 21 03 76 51 44 E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f194f50>
-------- Reading 21 27624 Ch. 1 L1 Current Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:43 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 6B E8 93 79 7E
RX: 11:31:43 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 1F 23 00 FF DC 6E 7E
Index: 1 Value: 1.1.31.35.0.255
TX: 11:31:43 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 6B F0 5A E5 7E
RX: 11:31:43 7E A0 16 21 03 BA D6 C4 E6 E7 00 0C 01 00 01 01 05 00 00 02 58 27 A5 7E
Index: 2 Value: 600
TX: 11:31:43 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 6B F8 12 69 7E
RX: 11:31:43 7E A0 1E 21 03 DC 3E 27 E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 1F 07 00 FF 0F 02 FE CD 7E
Index: 3 Value: 3 1.1.31.7.0.255 2
TX: 11:31:43 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 6C 00 DD 5F 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1ae4d0>
-------- Reading 21 27752 Ch. 1 L2 Current Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:43 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 6C 68 93 B0 7E
RX: 11:31:44 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 33 23 00 FF BB 76 7E
Index: 1 Value: 1.1.51.35.0.255
TX: 11:31:44 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 6C 70 5A 2C 7E
RX: 11:31:44 7E A0 16 21 03 32 96 CC E6 E7 00 0C 01 00 01 01 05 00 00 02 58 27 A5 7E
Index: 2 Value: 600
TX: 11:31:44 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 6C 78 12 A0 7E
RX: 11:31:44 7E A0 1E 21 03 54 7E 2F E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 33 07 00 FF 0F 02 6A 79 7E
Index: 3 Value: 3 1.1.51.7.0.255 2
TX: 11:31:44 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 6C 80 D5 DB 7E
RX: 11:31:44 7E A0 2D 21 03 76 51 44 E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461e807b50>
-------- Reading 21 27880 Ch. 1 L3 Current Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:44 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 6C E8 9B 34 7E
RX: 11:31:44 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 47 23 00 FF 12 5E 7E
Index: 1 Value: 1.1.71.35.0.255
TX: 11:31:44 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 6C F0 52 A8 7E
RX: 11:31:44 7E A0 16 21 03 BA D6 C4 E6 E7 00 0C 01 00 01 01 05 00 00 02 58 27 A5 7E
Index: 2 Value: 600
TX: 11:31:44 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 6C F8 1A 24 7E
RX: 11:31:44 7E A0 1E 21 03 DC 3E 27 E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 47 07 00 FF 0F 02 C7 AC 7E
Index: 3 Value: 3 1.1.71.7.0.255 2
TX: 11:31:44 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 6D 00 05 46 7E
RX: 11:31:44 7E A0 2D 21 03 FE 11 4C E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1aea90>
-------- Reading 21 28008 Ch. 1 Lo Current (neutral) Inst. value, over limit threshold Harmonic / Distortion factor 0
TX: 11:31:44 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 6D 68 4B A9 7E
RX: 11:31:44 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 5B 23 00 FF 87 0A 7E
Index: 1 Value: 1.1.91.35.0.255
TX: 11:31:44 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 6D 70 82 35 7E
RX: 11:31:44 7E A0 16 21 03 32 96 CC E6 E7 00 0C 01 00 01 01 05 00 00 00 14 FF 1E 7E
Index: 2 Value: 20
TX: 11:31:44 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 6D 78 CA B9 7E
RX: 11:31:45 7E A0 1E 21 03 54 7E 2F E6 E7 00 0C 01 00 02 03 12 00 03 09 06 01 01 5B 07 00 FF 0F 02 83 DF 7E
Index: 3 Value: 3 1.1.91.7.0.255 2
TX: 11:31:45 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 6D 80 0D C2 7E
RX: 11:31:45 7E A0 2D 21 03 76 51 44 E6 E7 00 0C 01 00 01 01 02 02 02 02 09 06 00 00 0A 01 01 FF 12 00 01 02 02 09 06 00 00 0A 01 01 FF 12 00 02 E3 AB 7E
Index: 4 Value: <gurux_dlms.objects.GXDLMSActionSet.GXDLMSActionSet object at 0x7f461f1ae950>
-------- Reading 4 32232 Ch. 0 Inactive object
TX: 11:31:45 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 7D E8 D2 B8 7E
RX: 11:31:45 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
Index: 1 Value: 0.0.127.0.0.0
TX: 11:31:45 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 7D F8 53 A8 7E
RX: 11:31:45 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:45 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 7D F0 1B 24 7E
RX: 11:31:45 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:45 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 7E 00 FC F9 7E
RX: 11:31:45 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 A0 62 C1 7E
Index: 4 Value: 160
TX: 11:31:45 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 7E 08 B4 75 7E
RX: 11:31:45 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 32376 Ch. 0 Inactive object
TX: 11:31:45 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 7E 78 33 06 7E
RX: 11:31:45 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:45 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 7E 88 BC F1 7E
RX: 11:31:45 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:45 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 7E 80 F4 7D 7E
RX: 11:31:45 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:45 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 7E 90 75 6D 7E
RX: 11:31:46 7E A0 11 21 03 98 E7 91 E6 E7 00 0C 01 00 11 A0 62 C1 7E
Index: 4 Value: 160
TX: 11:31:46 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 7E 98 3D E1 7E
RX: 11:31:46 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 32520 Ch. 0 Inactive object
TX: 11:31:46 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 7F 08 6C 6C 7E
RX: 11:31:46 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:46 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 7F 18 ED 7C 7E
RX: 11:31:46 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:46 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 7F 10 A5 F0 7E
RX: 11:31:46 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:46 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 7F 20 26 C1 7E
RX: 11:31:46 7E A0 11 21 03 32 B7 9B E6 E7 00 0C 01 00 11 A0 62 C1 7E
Index: 4 Value: 160
TX: 11:31:46 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 7F 28 6E 4D 7E
RX: 11:31:46 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 32664 Ch. 0 Inactive object
TX: 11:31:46 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 7F 98 E5 F8 7E
RX: 11:31:46 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:46 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 7F A8 66 C9 7E
RX: 11:31:46 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:46 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 7F A0 2E 45 7E
TX: 11:31:46 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 7F B0 AF 55 7E
RX: 11:31:47 7E A0 11 21 03 DC C7 95 E6 E7 00 0C 01 00 11 B0 E3 D1 7E
Index: 4 Value: 176
TX: 11:31:47 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 7F B8 E7 D9 7E
RX: 11:31:47 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 32808 Ch. 0 Inactive object
TX: 11:31:47 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 80 28 AE B2 7E
RX: 11:31:47 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:47 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 80 38 2F A2 7E
RX: 11:31:47 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:47 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 80 30 67 2E 7E
RX: 11:31:47 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:47 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 80 40 E0 5D 7E
RX: 11:31:47 7E A0 11 21 03 76 97 9F E6 E7 00 0C 01 00 11 B0 E3 D1 7E
Index: 4 Value: 176
TX: 11:31:47 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 80 48 A8 D1 7E
RX: 11:31:47 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 32952 Ch. 0 Inactive object
TX: 11:31:47 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 80 B8 27 26 7E
RX: 11:31:47 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:47 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 80 C8 A0 55 7E
RX: 11:31:47 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:47 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 80 C0 E8 D9 7E
RX: 11:31:48 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:48 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 80 D0 69 C9 7E
RX: 11:31:48 7E A0 11 21 03 10 A7 99 E6 E7 00 0C 01 00 11 B0 E3 D1 7E
Index: 4 Value: 176
TX: 11:31:48 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 80 D8 21 45 7E
RX: 11:31:48 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 33096 Ch. 0 Inactive object
TX: 11:31:48 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 81 48 70 C8 7E
RX: 11:31:48 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:48 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 81 58 F1 D8 7E
RX: 11:31:48 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:48 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 81 50 B9 54 7E
RX: 11:31:48 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:48 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 81 60 3A 65 7E
RX: 11:31:48 7E A0 11 21 03 BA F7 93 E6 E7 00 0C 01 00 11 A0 62 C1 7E
Index: 4 Value: 160
TX: 11:31:48 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 81 68 72 E9 7E
RX: 11:31:48 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 33240 Ch. 0 Inactive object
TX: 11:31:48 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 81 D8 F9 5C 7E
RX: 11:31:48 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:48 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 81 E8 7A 6D 7E
RX: 11:31:48 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:48 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 81 E0 32 E1 7E
RX: 11:31:49 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:49 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 81 F0 B3 F1 7E
RX: 11:31:49 7E A0 11 21 03 54 87 9D E6 E7 00 0C 01 00 11 A0 62 C1 7E
Index: 4 Value: 160
TX: 11:31:49 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 81 F8 FB 7D 7E
RX: 11:31:49 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 33384 Ch. 0 Inactive object
TX: 11:31:49 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 82 68 1A C3 7E
RX: 11:31:49 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:49 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 82 78 9B D3 7E
RX: 11:31:49 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:49 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 82 70 D3 5F 7E
RX: 11:31:49 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:49 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 82 80 5C A8 7E
RX: 11:31:49 7E A0 11 21 03 FE D7 97 E6 E7 00 0C 01 00 11 A0 62 C1 7E
Index: 4 Value: 160
TX: 11:31:49 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 82 88 14 24 7E
RX: 11:31:49 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 33528 Ch. 0 Inactive object
TX: 11:31:49 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 82 F8 93 57 7E
RX: 11:31:49 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:49 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 83 08 C4 B9 7E
RX: 11:31:49 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:49 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 83 00 8C 35 7E
RX: 11:31:50 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:50 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 83 10 0D 25 7E
RX: 11:31:50 7E A0 11 21 03 98 E7 91 E6 E7 00 0C 01 00 11 B0 E3 D1 7E
Index: 4 Value: 176
TX: 11:31:50 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 83 18 45 A9 7E
RX: 11:31:50 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 33672 Ch. 0 Inactive object
TX: 11:31:50 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 83 88 CC 3D 7E
RX: 11:31:50 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:50 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 83 98 4D 2D 7E
RX: 11:31:50 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:50 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 83 90 05 A1 7E
RX: 11:31:50 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:50 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 83 A0 86 90 7E
RX: 11:31:50 7E A0 11 21 03 32 B7 9B E6 E7 00 0C 01 00 11 B0 E3 D1 7E
Index: 4 Value: 176
TX: 11:31:50 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 83 A8 CE 1C 7E
RX: 11:31:50 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 4 33816 Ch. 0 Inactive object
TX: 11:31:50 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 84 18 4D E4 7E
RX: 11:31:50 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:50 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 84 28 CE D5 7E
RX: 11:31:50 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
TX: 11:31:50 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 84 20 86 59 7E
RX: 11:31:51 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:31:51 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 84 30 07 49 7E
RX: 11:31:51 7E A0 11 21 03 DC C7 95 E6 E7 00 0C 01 00 11 B0 E3 D1 7E
Index: 4 Value: 176
TX: 11:31:51 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 84 38 4F C5 7E
RX: 11:31:51 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 33960 Ch. 0 Time of operation Rate 1
TX: 11:31:51 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 84 A8 C6 51 7E
RX: 11:31:51 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 60 08 01 FF 4A BA 7E
Index: 1 Value: 0.0.96.8.1.255
TX: 11:31:51 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 84 B8 47 41 7E
RX: 11:31:51 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
Index: 3 Value: 1.0, 6
TX: 11:31:51 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 84 B0 0F CD 7E
RX: 11:31:51 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34064 Ch. 0 Time of operation Rate 2
TX: 11:31:51 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 85 10 DD 71 7E
RX: 11:31:51 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 60 08 02 FF 22 90 7E
Index: 1 Value: 0.0.96.8.2.255
TX: 11:31:51 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 85 20 5E 40 7E
RX: 11:31:51 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:51 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 85 18 95 FD 7E
-------- Reading 3 34168 Ch. 0 Time of operation Rate 3
TX: 11:31:51 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 85 78 93 9E 7E
RX: 11:31:51 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 60 08 03 FF FA 89 7E
Index: 1 Value: 0.0.96.8.3.255
TX: 11:31:51 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 85 88 1C 69 7E
RX: 11:31:52 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:52 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 85 80 54 E5 7E
RX: 11:31:52 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34272 Ch. 0 Inactive object
TX: 11:31:52 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 85 E0 52 86 7E
RX: 11:31:52 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:52 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 85 F0 D3 96 7E
RX: 11:31:52 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:52 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 85 E8 1A 0A 7E
RX: 11:31:52 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34376 Ch. 0 Inactive object
TX: 11:31:52 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 86 48 78 85 7E
RX: 11:31:52 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:52 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 86 58 F9 95 7E
RX: 11:31:52 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:52 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 86 50 B1 19 7E
RX: 11:31:52 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34480 Ch. 0 Inactive object
TX: 11:31:52 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 86 B0 BF FE 7E
RX: 11:31:52 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:52 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 86 C0 38 8D 7E
RX: 11:31:52 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:52 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 86 B8 F7 72 7E
RX: 11:31:53 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34584 Ch. 0 Inactive object
TX: 11:31:53 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 87 18 25 CE 7E
RX: 11:31:53 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:53 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 87 28 A6 FF 7E
RX: 11:31:53 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:53 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 87 20 EE 73 7E
RX: 11:31:53 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34688 Ch. 0 Inactive object
TX: 11:31:53 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 87 80 E4 D6 7E
RX: 11:31:53 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:31:53 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 87 90 65 C6 7E
RX: 11:31:53 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:53 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 87 88 AC 5A 7E
RX: 11:31:53 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 34792 Ch. 0 Time of operation, total
TX: 11:31:53 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 87 E8 AA 39 7E
RX: 11:31:53 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 60 08 00 FF 92 A3 7E
Index: 1 Value: 0.0.96.8.0.255
TX: 11:31:53 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 87 F8 2B 29 7E
RX: 11:31:53 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:53 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 87 F0 63 A5 7E
RX: 11:31:53 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 65024 Ch. 0 No. of configuration program changes
TX: 11:31:53 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 FE 00 30 75 7E
RX: 11:31:54 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 60 02 00 FF E8 D0 7E
Index: 1 Value: 0.0.96.2.0.255
TX: 11:31:54 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 FE 10 B1 65 7E
RX: 11:31:54 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:54 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 FE 08 78 F9 7E
RX: 11:31:54 7E A0 10 21 03 BA 4C 8F E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 35000 Ch. 0 Billing period counter (1) #255
TX: 11:31:54 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 88 B8 E7 E8 7E
RX: 11:31:54 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 00 00 01 00 FF 43 A2 7E
Index: 1 Value: 1.0.0.1.0.255
TX: 11:31:54 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 88 C8 60 9B 7E
RX: 11:31:54 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:54 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 88 C0 28 17 7E
RX: 11:31:54 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 35312 Ch. 0 No. of power failures in phase L1
TX: 11:31:54 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 89 F0 73 3F 7E
RX: 11:31:54 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 60 07 01 FF 8D F0 7E
Index: 1 Value: 0.0.96.7.1.255
TX: 11:31:54 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 8A 00 94 E2 7E
RX: 11:31:54 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:54 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 89 F8 3B B3 7E
RX: 11:31:54 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 35416 Ch. 0 No. of power failures in phase L2
TX: 11:31:54 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 8A 58 59 3C 7E
RX: 11:31:54 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 60 07 02 FF E5 DA 7E
Index: 1 Value: 0.0.96.7.2.255
TX: 11:31:54 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 8A 68 DA 0D 7E
RX: 11:31:55 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:55 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 8A 60 92 81 7E
RX: 11:31:55 7E A0 10 21 03 DC 7C 89 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 35520 Ch. 0 No. of power failures in phase L3
TX: 11:31:55 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 8A C0 98 24 7E
RX: 11:31:55 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 60 07 03 FF 3D C3 7E
Index: 1 Value: 0.0.96.7.3.255
TX: 11:31:55 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 8A D0 19 34 7E
RX: 11:31:55 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:55 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 8A C8 D0 A8 7E
RX: 11:31:55 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 35624 Ch. 0 No. of power failures in all three phases
TX: 11:31:55 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 8B 28 06 56 7E
RX: 11:31:55 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 60 07 00 FF 55 E9 7E
Index: 1 Value: 0.0.96.7.0.255
TX: 11:31:55 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 8B 38 87 46 7E
RX: 11:31:55 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:55 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 8B 30 CF CA 7E
RX: 11:31:55 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 35728 Ch. 0 Battery use time counter
TX: 11:31:55 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 8B 90 C5 6F 7E
RX: 11:31:55 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 60 06 00 FF 89 B3 7E
Index: 1 Value: 0.0.96.6.0.255
TX: 11:31:55 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 8B A0 46 5E 7E
RX: 11:31:55 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F 00 16 06 05 A8 7E
TX: 11:31:55 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 8B 98 8D E3 7E
RX: 11:31:56 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 36736 Ch. 0 State of the internal control signals, global
TX: 11:31:56 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 8F 80 24 18 7E
RX: 11:31:56 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 60 04 00 FF 31 06 7E
Index: 1 Value: 0.0.96.4.0.255
TX: 11:31:56 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 8F 90 A5 08 7E
RX: 11:31:56 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:56 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 8F 88 6C 94 7E
RX: 11:31:56 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 09 04 60 00 00 00 D2 31 7E
Index: 2 Value: 60 00 00 00
-------- Reading 3 36840 Ch. 0 Internal operating status, global
TX: 11:31:56 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 8F E8 6A F7 7E
RX: 11:31:56 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 60 05 00 FF ED 5C 7E
Index: 1 Value: 0.0.96.5.0.255
TX: 11:31:56 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 8F F8 EB E7 7E
RX: 11:31:56 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
TX: 11:31:56 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 8F F0 A3 6B 7E
RX: 11:31:56 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 09 04 00 20 00 90 84 3F 7E
Index: 2 Value: 00 20 00 90
-------- Reading 3 37968 Ch. 1 L1 Voltage Inst. value
TX: 11:31:56 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 94 50 90 BF 7E
RX: 11:31:56 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 20 07 00 FF 8D F0 7E
Index: 1 Value: 1.1.32.7.0.255
TX: 11:31:56 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 94 60 13 8E 7E
RX: 11:31:56 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
Attribute2 is not readable.
-------- Reading 3 38120 Ch. 1 L2 Voltage Inst. value
TX: 11:31:56 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 94 E8 53 86 7E
RX: 11:31:56 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 34 07 00 FF C0 41 7E
Index: 1 Value: 1.1.52.7.0.255
TX: 11:31:56 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 94 F8 D2 96 7E
RX: 11:31:57 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
-------- Reading 3 38272 Ch. 1 L3 Voltage Inst. value
TX: 11:31:57 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 95 80 C5 70 7E
RX: 11:31:57 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 48 07 00 FF B1 8C 7E
Index: 1 Value: 1.1.72.7.0.255
TX: 11:31:57 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 95 90 44 60 7E
RX: 11:31:57 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FE 16 23 85 42 7E
-------- Reading 3 38424 Ch. 1 L1 Current Inst. value
TX: 11:31:57 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 96 18 6C 42 7E
RX: 11:31:57 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 1F 07 00 FF 86 0E 7E
Index: 1 Value: 1.1.31.7.0.255
TX: 11:31:57 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 96 28 EF 73 7E
RX: 11:31:57 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FE 16 21 97 61 7E
Index: 3 Value: 0.01, 33
-------- Reading 3 38576 Ch. 1 L2 Current Inst. value
TX: 11:31:57 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 96 B0 2E 6B 7E
RX: 11:31:57 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 33 07 00 FF E1 16 7E
Index: 1 Value: 1.1.51.7.0.255
TX: 11:31:57 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 96 C0 A9 18 7E
RX: 11:31:57 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FE 16 21 97 61 7E
-------- Reading 3 38728 Ch. 1 L3 Current Inst. value
TX: 11:31:57 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 97 48 31 09 7E
RX: 11:31:57 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 47 07 00 FF 48 3E 7E
Index: 1 Value: 1.1.71.7.0.255
TX: 11:31:57 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 97 58 B0 19 7E
RX: 11:31:57 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FE 16 21 97 61 7E
-------- Reading 3 38880 Ch. 1 Lo Current (neutral) Inst. value
TX: 11:31:57 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 97 E0 73 20 7E
RX: 11:31:57 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 5B 07 00 FF DD 6A 7E
Index: 1 Value: 1.1.91.7.0.255
TX: 11:31:57 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 97 F0 F2 30 7E
RX: 11:31:58 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FE 16 21 97 61 7E
-------- Reading 3 39032 Ch. 1 Supply frequency Inst. value
TX: 11:31:58 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 98 78 7A BB 7E
RX: 11:31:58 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 0E 07 00 FF 9C D1 7E
Index: 1 Value: 1.1.14.7.0.255
TX: 11:31:58 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 98 88 F5 4C 7E
RX: 11:31:58 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FE 16 2C 72 BA 7E
Index: 3 Value: 0.01, 44
-------- Reading 3 39184 Ch. 1 Sum Li Active power (abs(QI+QIV)-abs(QII+QIII)) Inst. value
TX: 11:31:58 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 99 10 EC 4D 7E
RX: 11:31:58 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 10 07 00 FF 7F BC 7E
Index: 1 Value: 1.1.16.7.0.255
TX: 11:31:58 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 99 20 6F 7C 7E
RX: 11:31:58 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F 00 16 1B 61 63 7E
Index: 3 Value: 1.0, 27
-------- Reading 3 39336 Man. specific
TX: 11:31:58 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 99 A8 2F 74 7E
RX: 11:31:58 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 83 07 00 FF 7D 77 7E
Index: 1 Value: 1.1.131.7.0.255
TX: 11:31:58 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 99 B8 AE 64 7E
RX: 11:31:58 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 1D 57 06 7E
Index: 3 Value: 1.0, 29
TX: 11:31:58 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 99 B0 E6 E8 7E
RX: 11:31:58 7E A0 10 21 03 54 3C 81 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 3 39488 Ch. 1 Angle of U(L1) - U(L1)
TX: 11:31:58 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 9A 40 01 35 7E
RX: 11:31:58 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 51 07 00 FF 73 B6 7E
Index: 1 Value: 1.1.81.7.0.255
TX: 11:31:58 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 9A 50 80 25 7E
RX: 11:31:58 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FE 16 08 54 DD 7E
Index: 3 Value: 0.01, 8
-------- Reading 3 39640 Ch. 1 Angle of U(L2) - U(L1)
TX: 11:31:58 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 9A D8 C0 2D 7E
RX: 11:31:59 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 51 07 01 FF AB AF 7E
Index: 1 Value: 1.1.81.7.1.255
TX: 11:31:59 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 9A E8 43 1C 7E
RX: 11:31:59 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FE 16 08 54 DD 7E
-------- Reading 3 39792 Ch. 1 Angle of U(L3) - U(L1)
TX: 11:31:59 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 9B 70 5A 1D 7E
RX: 11:31:59 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 51 07 02 FF C3 85 7E
Index: 1 Value: 1.1.81.7.2.255
TX: 11:31:59 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 9B 80 D5 EA 7E
RX: 11:31:59 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FE 16 08 54 DD 7E
-------- Reading 3 39944 Ch. 1 Angle of I(L1) - U(L1)
TX: 11:31:59 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 9C 08 9D AF 7E
RX: 11:31:59 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 51 07 04 FF 13 D1 7E
Index: 1 Value: 1.1.81.7.4.255
TX: 11:31:59 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 9C 18 1C BF 7E
RX: 11:31:59 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FE 16 08 54 DD 7E
-------- Reading 3 40096 Ch. 1 Angle of I(L2) - U(L2)
TX: 11:31:59 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 9C A0 DF 86 7E
RX: 11:31:59 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 51 07 0F FF BB 35 7E
Index: 1 Value: 1.1.81.7.15.255
TX: 11:31:59 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 9C B0 5E 96 7E
RX: 11:31:59 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FE 16 08 54 DD 7E
-------- Reading 3 40248 Ch. 1 Angle of I(L3) - U(L3)
TX: 11:31:59 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 9D 38 C6 87 7E
RX: 11:31:59 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 51 07 1A FF 92 DE 7E
Index: 1 Value: 1.1.81.7.26.255
TX: 11:31:59 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 9D 48 41 F4 7E
-------- Reading 3 40400 Ch. 1 Sum Li Power factor Inst. value
TX: 11:31:59 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 9D D0 80 EC 7E
RX: 11:32:00 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 01 01 0D 07 00 FF 51 F4 7E
Index: 1 Value: 1.1.13.7.0.255
TX: 11:32:00 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 9D E0 03 DD 7E
RX: 11:32:00 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FE 16 FF 64 5E 7E
Index: 3 Value: 0.01, 255
-------- Reading 3 40552 Ch. 1 L1 Power factor Inst. value
TX: 11:32:00 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 9E 68 2B FF 7E
RX: 11:32:00 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 01 01 21 07 00 FF 36 EC 7E
Index: 1 Value: 1.1.33.7.0.255
TX: 11:32:00 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 9E 78 AA EF 7E
RX: 11:32:00 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FE 16 FF 64 5E 7E
-------- Reading 3 40704 Ch. 1 L2 Power factor Inst. value
TX: 11:32:00 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 9F 00 BD 09 7E
RX: 11:32:00 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 35 07 00 FF 7B 5D 7E
Index: 1 Value: 1.1.53.7.0.255
TX: 11:32:00 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 9F 10 3C 19 7E
RX: 11:32:00 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FE 16 FF 64 5E 7E
-------- Reading 3 40856 Ch. 1 L3 Power factor Inst. value
TX: 11:32:00 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 9F 98 7C 11 7E
RX: 11:32:00 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 01 01 49 07 00 FF 0A 90 7E
Index: 1 Value: 1.1.73.7.0.255
TX: 11:32:00 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 9F A8 FF 20 7E
RX: 11:32:00 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FE 16 FF 64 5E 7E
-------- Reading 3 41008 Ch. 0 Inactive object
TX: 11:32:00 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 A0 30 54 0D 7E
RX: 11:32:00 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:00 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 A0 40 D3 7E 7E
RX: 11:32:00 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FD 16 FF 00 B1 7E
Index: 3 Value: 0.001, 255
TX: 11:32:00 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 A0 38 1C 81 7E
RX: 11:32:01 7E A0 14 21 03 32 E0 F5 E6 E7 00 0C 01 00 05 00 00 00 00 26 9E 7E
Index: 2 Value: 0.0
-------- Reading 3 41160 Ch. 0 Inactive object
TX: 11:32:01 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 A0 C8 93 76 7E
RX: 11:32:01 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:01 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 A0 D8 12 66 7E
RX: 11:32:01 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F FD 16 23 E1 AD 7E
Index: 3 Value: 0.001, 35
TX: 11:32:01 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 A0 D0 5A EA 7E
RX: 11:32:01 7E A0 14 21 03 98 B0 FF E6 E7 00 0C 01 00 05 00 00 12 20 05 19 7E
Index: 2 Value: 4.64
-------- Reading 3 41312 Ch. 0 Inactive object
TX: 11:32:01 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 A1 60 09 46 7E
RX: 11:32:01 7E A0 17 21 03 BA 6D D8 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:01 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 A1 70 88 56 7E
RX: 11:32:01 7E A0 15 21 03 DC 2B E7 E6 E7 00 0C 01 00 02 02 0F FD 16 23 E1 AD 7E
TX: 11:32:01 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 A1 68 41 CA 7E
RX: 11:32:01 7E A0 14 21 03 FE 80 F9 E6 E7 00 0C 01 00 05 00 00 03 F7 7E 37 7E
Index: 2 Value: 1.0150000000000001
-------- Reading 3 41464 Ch. 0 Inactive object
TX: 11:32:01 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 A1 F8 C8 5E 7E
RX: 11:32:01 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:01 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 A2 08 2F 83 7E
RX: 11:32:01 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F FD 16 23 E1 AD 7E
TX: 11:32:01 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 A2 00 67 0F 7E
RX: 11:32:01 7E A0 14 21 03 54 D0 F3 E6 E7 00 0C 01 00 05 00 00 03 F8 89 CF 7E
Index: 2 Value: 1.016
-------- Reading 3 41616 Ch. 0 Inactive object
TX: 11:32:01 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 A2 90 EE 9B 7E
RX: 11:32:02 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:02 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 A2 A0 6D AA 7E
RX: 11:32:02 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F FD 16 FF 00 B1 7E
TX: 11:32:02 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 A2 98 A6 17 7E
RX: 11:32:02 7E A0 14 21 03 BA A0 FD E6 E7 00 0C 01 00 05 00 00 0F 11 E6 1C 7E
Index: 2 Value: 3.857
-------- Reading 3 41768 Ch. 0 Inactive object
TX: 11:32:02 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 A3 28 F5 BB 7E
RX: 11:32:02 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:02 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 A3 38 74 AB 7E
RX: 11:32:02 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F FD 16 21 F3 8E 7E
Index: 3 Value: 0.001, 33
TX: 11:32:02 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 A3 30 3C 27 7E
RX: 11:32:02 7E A0 14 21 03 10 F0 F7 E6 E7 00 0C 01 00 05 00 00 00 02 34 BD 7E
Index: 2 Value: 0.002
-------- Reading 3 41920 Ch. 0 Inactive object
TX: 11:32:02 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 A3 C0 B3 D0 7E
RX: 11:32:02 7E A0 17 21 03 32 2D D0 E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:02 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 A3 D0 32 C0 7E
RX: 11:32:02 7E A0 15 21 03 54 6B EF E6 E7 00 0C 01 00 02 02 0F FD 16 21 F3 8E 7E
TX: 11:32:02 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 A3 C8 FB 5C 7E
RX: 11:32:02 7E A0 14 21 03 76 C0 F1 E6 E7 00 0C 01 00 05 00 00 00 02 34 BD 7E
-------- Reading 3 42072 Ch. 0 Inactive object
TX: 11:32:02 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 A4 58 7A 85 7E
RX: 11:32:02 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:02 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 A4 68 F9 B4 7E
RX: 11:32:03 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F FD 16 21 F3 8E 7E
TX: 11:32:03 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 A4 60 B1 38 7E
RX: 11:32:03 7E A0 14 21 03 DC 90 FB E6 E7 00 0C 01 00 05 00 00 00 01 AF 8F 7E
Index: 2 Value: 0.001
-------- Reading 3 42224 Ch. 0 Inactive object
TX: 11:32:03 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 A4 F0 38 AC 7E
RX: 11:32:03 7E A0 17 21 03 FE 4D DC E6 E7 00 0C 01 00 09 06 00 00 7F 00 00 00 70 1B 7E
TX: 11:32:03 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 A5 00 6F 42 7E
RX: 11:32:03 7E A0 15 21 03 10 4B EB E6 E7 00 0C 01 00 02 02 0F FD 16 FF 00 B1 7E
TX: 11:32:03 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 A4 F8 70 20 7E
RX: 11:32:03 7E A0 14 21 03 32 E0 F5 E6 E7 00 0C 01 00 05 00 00 00 A6 1A 5E 7E
Index: 2 Value: 0.166
-------- Reading 3 46480 Ch. 1 L1 Active power (abs(QI+QIV)-abs(QII+QIII)) Inst. value
TX: 11:32:03 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 B5 90 77 43 7E
RX: 11:32:03 7E A0 17 21 03 54 1D D6 E6 E7 00 0C 01 00 09 06 01 01 24 07 00 FF 61 82 7E
Index: 1 Value: 1.1.36.7.0.255
TX: 11:32:03 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 B5 A0 F4 72 7E
RX: 11:32:03 7E A0 15 21 03 76 7B ED E6 E7 00 0C 01 00 02 02 0F 00 16 1B 61 63 7E
-------- Reading 3 46632 Ch. 1 L2 Active power (abs(QI+QIV)-abs(QI+QIII)) Inst. value
TX: 11:32:03 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 B6 28 DC 50 7E
RX: 11:32:03 7E A0 17 21 03 98 7D DA E6 E7 00 0C 01 00 09 06 01 01 38 07 00 FF F4 D6 7E
Index: 1 Value: 1.1.56.7.0.255
TX: 11:32:03 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 B6 38 5D 40 7E
RX: 11:32:03 7E A0 15 21 03 BA 1B E1 E6 E7 00 0C 01 00 02 02 0F 00 16 1B 61 63 7E
-------- Reading 3 46784 Ch. 1 L3 Active power (abs(QI+QIV)-abs(QI+QIII)) Inst. value
TX: 11:32:03 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 B6 C0 9A 3B 7E
RX: 11:32:03 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 4C 07 00 FF 5D FE 7E
Index: 1 Value: 1.1.76.7.0.255
TX: 11:32:03 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 B6 D0 1B 2B 7E
RX: 11:32:04 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F 00 16 1B 61 63 7E
-------- Reading 3 46936 Man. specific
TX: 11:32:04 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 B7 58 83 3A 7E
RX: 11:32:04 7E A0 17 21 03 10 3D D2 E6 E7 00 0C 01 00 09 06 01 01 97 07 00 FF 30 C6 7E
Index: 1 Value: 1.1.151.7.0.255
TX: 11:32:04 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 B7 68 00 0B 7E
RX: 11:32:04 7E A0 15 21 03 32 5B E9 E6 E7 00 0C 01 00 02 02 0F 00 16 1D 57 06 7E
TX: 11:32:04 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 B7 60 48 87 7E
RX: 11:32:04 7E A0 14 21 03 54 D0 F3 E6 E7 00 0C 01 00 05 00 00 00 00 26 9E 7E
Index: 2 Value: 0
-------- Reading 3 47088 Man. specific
TX: 11:32:04 7E A0 11 03 21 74 85 1A E6 E6 00 05 01 02 B7 F0 C1 13 7E
RX: 11:32:04 7E A0 17 21 03 76 0D D4 E6 E7 00 0C 01 00 09 06 01 01 AB 07 00 FF F6 1D 7E
Index: 1 Value: 1.1.171.7.0.255
TX: 11:32:04 7E A0 11 03 21 96 99 DE E6 E6 00 05 01 02 B8 00 86 67 7E
RX: 11:32:04 7E A0 15 21 03 98 0B E3 E6 E7 00 0C 01 00 02 02 0F 00 16 1D 57 06 7E
TX: 11:32:04 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 B7 F8 89 9F 7E
RX: 11:32:04 7E A0 14 21 03 BA A0 FD E6 E7 00 0C 01 00 05 00 00 00 00 26 9E 7E
Index: 2 Value: 0
-------- Reading 3 47240 Man. specific
TX: 11:32:04 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 B8 88 C6 6F 7E
RX: 11:32:04 7E A0 17 21 03 DC 5D DE E6 E7 00 0C 01 00 09 06 01 01 BF 07 00 FF BB AC 7E
Index: 1 Value: 1.1.191.7.0.255
TX: 11:32:04 7E A0 11 03 21 FC C5 12 E6 E6 00 05 01 02 B8 98 47 7F 7E
RX: 11:32:04 7E A0 15 21 03 FE 3B E5 E6 E7 00 0C 01 00 02 02 0F 00 16 1D 57 06 7E
TX: 11:32:04 7E A0 11 03 21 1E D9 D6 E6 E6 00 05 01 02 B8 90 0F F3 7E
RX: 11:32:04 7E A0 14 21 03 10 F0 F7 E6 E7 00 0C 01 00 05 00 00 00 00 26 9E 7E
Index: 2 Value: 0
-------- Reading 7 24800 Ch. 0 Event log #1
TX: 11:32:04 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 61 10 24 FF 7E
RX: 11:32:05 7E A0 14 21 03 32 E0 F5 E6 E7 00 0C 01 00 06 00 00 00 22 FA 81 7E
TX: 11:32:05 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 61 18 6C 73 7E
RX: 11:32:05 7E A0 14 21 03 54 D0 F3 E6 E7 00 0C 01 00 06 00 00 00 22 FA 81 7E
Entries: 34/34
TX: 11:32:05 7E A0 24 03 21 74 20 38 E6 E6 00 05 01 04 60 E8 02 02 04 06 00 00 00 01 06 00 00 00 01 12 00 01 12 00 00 21 B1 7E
RX: 11:32:05 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
Error! Failed to read first row: Access Error : Device reports Read-Write denied.
TX: 11:32:05 7E A0 44 03 21 96 D8 65 E6 E6 00 05 01 04 60 E8 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 03 14 03 00 00 00 00 FF 88 00 09 0C 07 E8 03 14 03 0B 00 00 00 FF 88 00 01 00 CB 31 7E
RX: 11:32:05 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
Error! Failed to read last day: Access Error : Device reports Read-Write denied.
-------- Reading 7 25200 Ch. 0 Load profile with recording period 1 #1
TX: 11:32:05 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 62 A0 C7 60 7E
RX: 11:32:05 7E A0 14 21 03 BA A0 FD E6 E7 00 0C 01 00 06 00 00 09 AB 2B 4F 7E
TX: 11:32:05 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 62 A8 8F EC 7E
RX: 11:32:05 7E A0 14 21 03 DC 90 FB E6 E7 00 0C 01 00 06 00 00 22 7B 3D 5E 7E
Entries: 2475/8827
TX: 11:32:05 7E A0 24 03 21 FC 60 30 E6 E6 00 05 01 04 62 78 02 02 04 06 00 00 00 01 06 00 00 00 01 12 00 01 12 00 00 E8 8F 7E
RX: 11:32:05 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:32:05 7E A0 44 03 21 1E 98 6D E6 E6 00 05 01 04 62 78 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 03 14 03 00 00 00 00 FF 88 00 09 0C 07 E8 03 14 03 0B 00 00 00 FF 88 00 01 00 95 75 7E
RX: 11:32:05 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 7 25600 Ch. 0 Data of billing period Scheme 1 #1 Unspecified number of most recent billing periods
TX: 11:32:05 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 64 30 9E A0 7E
RX: 11:32:05 7E A0 14 21 03 32 E0 F5 E6 E7 00 0C 01 00 06 00 00 00 16 5D F6 7E
TX: 11:32:05 7E A0 11 03 21 52 B1 5E E6 E6 00 05 01 02 64 38 D6 2C 7E
RX: 11:32:06 7E A0 14 21 03 54 D0 F3 E6 E7 00 0C 01 00 06 00 00 00 16 5D F6 7E
Entries: 22/22
TX: 11:32:06 7E A0 24 03 21 74 20 38 E6 E6 00 05 01 04 64 08 02 02 04 06 00 00 00 01 06 00 00 00 01 12 00 01 12 00 00 80 F4 7E
RX: 11:32:06 7E A0 10 21 03 76 2C 83 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:32:06 7E A0 44 03 21 96 D8 65 E6 E6 00 05 01 04 64 08 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 03 14 03 00 00 00 00 FF 88 00 09 0C 07 E8 03 14 03 0B 00 00 00 FF 88 00 01 00 7A BF 7E
RX: 11:32:06 7E A0 10 21 03 98 5C 8D E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 7 2728 Ch. 0 Load profile with recording period 2 #1
TX: 11:32:06 7E A0 11 03 21 B8 E5 16 E6 E6 00 05 01 02 0A D8 9D 34 7E
RX: 11:32:06 7E A0 14 21 03 BA A0 FD E6 E7 00 0C 01 00 06 00 00 43 8C 80 A1 7E
TX: 11:32:06 7E A0 11 03 21 DA F1 56 E6 E6 00 05 01 02 0A E0 56 89 7E
RX: 11:32:06 7E A0 14 21 03 DC 90 FB E6 E7 00 0C 01 00 06 00 00 43 8C 80 A1 7E
Entries: 17292/17292
TX: 11:32:06 7E A0 24 03 21 FC 60 30 E6 E6 00 05 01 04 0A B0 02 02 04 06 00 00 00 01 06 00 00 00 01 12 00 01 12 00 00 0E 33 7E
RX: 11:32:06 7E A0 10 21 03 FE 6C 8B E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:32:06 7E A0 44 03 21 1E 98 6D E6 E6 00 05 01 04 0A B0 01 02 04 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00 09 0C 07 E8 03 14 03 00 00 00 00 FF 88 00 09 0C 07 E8 03 14 03 0B 00 00 00 FF 88 00 01 00 71 54 7E
RX: 11:32:06 7E A0 10 21 03 10 1C 85 E6 E7 00 0C 01 01 03 DB B3 7E
-------- Reading 7 51288 Ch. 0 Inactive object
TX: 11:32:06 7E A0 11 03 21 30 A5 1E E6 E6 00 05 01 02 C8 88 02 9F 7E
RX: 11:32:06 7E A0 10 21 03 32 0C 87 E6 E7 00 0C 01 01 03 DB B3 7E
TX: 11:32:06 7E A0 07 03 21 53 03 C7 7E
RX: 11:32:06 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
2 years 7 months ago
Hi, Can you read L+G E650…
Can you read L+G E650 using C# or Java client? Let me know what happened.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Client.E…
https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.client…
