  2. Losing Smartmeter Connection Frequently
Losing Smartmeter connection frequently
By midhun1212 , 15 February, 2024
i am using java for smartmeter connection. Meter connection is lost for about 20 minutes...i cant reconnect to meter or i have to restart meter..Is there any way to connect immediatlly If i lost the connection from meter in java
2 years 3 months ago
Hi, You didn't say if are…
You didn't say if are you using a serial port or TCP/IP connection. There is an inactivity timeout. This means that the meter will close the connection after this time if the client doesn't communicate with the meter.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSIecHdlcSetup
You can try to decrease this value. If you don't call Disconnect the connection might get up and you have to wait until inactivity time has elapsed.
