  3. Connecting Meter Using DLMS Client.Net
Connecting meter using DLMS Client.Net
By luthfipratamaps , 23 October, 2023
Gurux.Net
Good evening, GuruX.
Hope you are doing well.
I was trying to connect to my meter using client.net.
It seems like i got it connected but somehow received this error: Unacceptable frame
Is there any steps I could follow to resolve this issue?
Thank you in advance!
This is last 25 lines from trace:
Gurux.DLMS.Client.Example.Net.exe -S COM8:19200:8None1 -c 6 -a HighGMAC -C AuthenticationEncryption -T 4B464D09EBC1C5FC -A 53646E7967655365704C4533736F4B37 -B 414253695162566C64526564496B7276 -v 0.0.43.1.0.255 -w 1 -f 128 -t Verbose
Read scalers and units from the device.
TX: 15:03:51 7E A8 89 03 0D 9E 75 89 E6 E6 00 E0 01 00 01 00 00 82 03 F9 DB 08 4B 46 4D 09 EB C1 C5 FC 82 24 61 30 00 00 17 3B 43 C4 5E 89 6E 6E 50 A9 15 6F 4B C9 D0 FC 61 0A 90 72 FB 47 C7 29 50 06 54 98 DE E9 38 73 E1 AC 7C B4 03 5D 37 70 65 52 FF D6 F0 F3 D7 C6 52 0C EE 60 DE 5A F4 C6 D2 1B 72 8E FF 00 BA 82 38 6D 04 6E 5E AC E2 A6 25 0E 4B FE 42 4E 4D 39 F9 2B BD 60 96 53 96 9A 11 18 97 4F 14 C7 93 02 E1 5F 99 0A 6C 17 7E
RX: 15:03:51 7E A0 07 0D 03 11 8D A6 7E
TX: 15:03:51 7E A8 89 03 0D 90 0B 60 41 A1 8B E9 51 94 D3 42 AA CC EC FD 97 7C BA 74 EC A5 88 FD 46 9A 9C AB 62 57 6C 1C 43 50 6D BA 0F 49 E5 26 69 3F 0F 09 05 EE 59 87 48 57 F6 39 DE AB A3 12 CB 32 37 DD 19 A7 C7 82 C4 48 AD 27 A6 41 FC 45 28 96 15 9E 32 54 1A 74 FF 21 A5 CF A2 0F A0 A8 A5 20 04 C5 6E B1 DF CA 7B 54 54 3B D4 A0 EA 47 DB 02 1C E2 F0 75 C5 5A DE 57 81 3C B6 4B C9 B3 E8 D6 BE E3 4B 41 BF 7E 9F 7D B6 4A DE 50 7E
RX: 15:03:51 7E A0 07 0D 03 31 8F 87 7E
TX: 15:03:51 7E A8 89 03 0D 92 19 43 8E DE 07 C0 4C 8D 46 F2 33 EB 33 33 F9 2C 68 40 0E 5B B9 CC A3 83 A8 7B CD 5F D4 DC EF 4C 8B AF 6D 09 C2 5E 3C 0A 26 6C C3 1E 73 48 CE 84 9D 47 26 22 0B 5A AF 91 BC 7A BE C8 17 10 DA 61 86 E3 E2 8E D0 2F 8D C6 05 8D 37 19 03 7A A5 13 CD 6E DB D0 AE 18 65 F1 68 34 85 10 53 51 DA 5F BD D7 33 F8 A1 EE 3D 88 04 BB 22 B4 C4 D1 B4 88 44 CC C8 B1 42 E8 71 4C A7 A4 C1 4C 21 E0 DE 4B AA 9F 71 C2 7E
RX: 15:03:51 7E A0 07 0D 03 51 89 E4 7E
TX: 15:03:51 7E A8 89 03 0D 94 2F 26 D2 25 9A B5 0A E6 70 FE F0 21 5C 1C E1 6C 85 0E A5 5E B0 37 E8 38 18 4C E6 12 2F 39 69 BB 17 B5 22 DE A3 BD BE F1 DC 08 20 5E 36 0D 84 1E 54 36 E1 85 50 F4 D8 BD 03 CB 29 90 4A 9B 74 52 B3 40 A2 AD 60 9A D8 1B 76 85 67 B0 F2 F2 D6 B4 37 A0 48 D7 54 2D 8C FA D3 6F 6B BE B3 90 E8 73 35 90 87 9B 8F BD EA 4F 69 46 5E CB 89 66 35 81 6B D7 84 28 80 07 6D 9B 8E C6 49 95 3B B4 A7 D8 BC FB 40 C1 7E
RX: 15:03:52 7E A0 07 0D 03 71 8B C5 7E
TX: 15:03:52 7E A8 89 03 0D 96 3D 05 E7 BA B3 B8 44 97 02 06 3E 0D 19 E1 B2 04 53 32 0A 30 4E 98 F2 BE 53 4B B7 47 6D 5B 94 2E B0 74 78 C8 E2 09 BF 21 0F D9 6E 61 28 F6 2E 80 4A 5D F0 6A CA DA 6C 88 E9 34 F5 40 BC F3 C9 FE 43 B9 FC FA 11 3A 62 A1 43 15 D5 4C A4 CF 12 2E 18 96 45 91 03 9F F9 55 ED 1F D1 09 FD 35 E2 FA E0 3C 80 38 F5 CD 26 B2 36 26 6B 48 8F 91 22 FE D5 BE 90 7E 7F F8 74 C3 FE F7 CD AE 6E 94 D8 C4 33 F7 F2 F0 7E
RX: 15:03:52 7E A0 07 0D 03 91 85 22 7E
TX: 15:03:52 7E A8 89 03 0D 98 43 EC 3A 7F 0E AB 19 56 63 D8 65 B1 1F 0A DE 2B DA 59 1C AC ED D0 B2 C2 6A 85 C0 90 42 62 D0 36 12 F7 05 B9 06 22 76 BD CD 78 98 92 AA B2 05 E6 54 44 E5 72 80 D8 BE 2F 4D 0A A0 03 FB 76 B2 07 DF 45 A3 30 45 FA E3 87 8C 65 E6 65 6D 78 36 82 23 0C 82 85 DA 17 9D 2D D5 EB 64 5A F3 61 50 EF DC D3 83 79 57 78 31 F2 FA 04 66 92 8F 68 9F DD E4 90 99 FB AF 93 AA 64 95 E6 D3 E4 1E FA C6 FB 60 4A 9A 72 7E
RX: 15:03:52 7E A0 07 0D 03 B1 87 03 7E
TX: 15:03:52 7E A8 89 03 0D 9A 51 CF DC F9 2D 2C 89 3C 45 38 55 35 DD B7 44 3B B5 77 D5 4F 42 C5 CD DD 0A F7 11 7F DA 8C 93 7F 03 91 E7 1E 91 64 BA 9E 35 78 4D 03 99 14 98 F9 CD 2D 8C B5 AD 9F 82 55 AD A4 C9 5E 3A 31 78 27 76 BD 1E 6C C3 4A A3 35 F1 54 E6 FF EB 17 47 45 7C BE D2 DD 58 7D F7 1E 5E A7 81 40 42 30 2A BB 27 7F 32 BE 40 37 5D 4E 6E 6D 09 12 AC D0 0A B6 C4 63 0E EF 17 90 40 01 E9 08 12 24 E0 13 49 48 B9 F3 27 21 7E
RX: 15:03:52 7E A0 07 0D 03 D1 81 60 7E
TX: 15:03:52 7E A8 89 03 0D 9C 67 AA 41 1E 60 36 21 19 C3 03 42 B9 32 63 48 8F 8F 7B 5F ED D3 8C A9 BA 95 D4 86 01 97 82 51 BB 4A 1A AD 7B E0 76 EB 9A 18 51 31 C3 27 68 4A CA 5A 0E 47 FD 22 1E 0A B7 65 3C 1F 38 70 35 77 7A 14 6C A1 02 DD 99 75 A5 88 BC F8 46 4C 2F A5 D0 E6 A0 C1 EF ED 24 8A 8B 8E FA DA B2 31 A6 0E 2E 7F 43 F0 C8 32 AB 06 75 53 E1 B3 D1 04 9D 9E F3 D1 E6 B2 FF 17 47 79 5F 83 DC 95 F5 48 9D BA 3F F8 87 62 32 7E
RX: 15:03:52 7E A0 07 0D 03 F1 83 41 7E
TX: 15:03:52 7E A0 0E 03 0D 9E 1A A9 FE C8 A8 47 91 14 EB 7E
RX: 15:03:52 7E A0 0C 0D 03 97 A6 87 9E E8 01 C5 60 7E
Disconnecting from the meter.
TX: 15:03:52 7E A0 11 03 0D D4 1C 35 E6 E6 00 62 03 80 01 00 BD 9B 7E
TX: 15:03:52 7E A0 07 03 0D 53 90 4D 7E
RX: 15:03:52 7E A0 07 0D 03 73 99 E6 7E
Unacceptable frame.
2 years 11 months ago
Hi, From the log, it looks…
From the log, it looks like the meter expects protected release. Try to set UseProtectedRelease to true. I believe it will solve your problem.
There are still older meters that can't handle protected release and for that reason, it's false as a default.
luthfipratamaps
2 years 10 months ago
Good morning, Mr. Mikko…
Good morning, Mr. Mikko.
Thank you for your fast response.
Sorry if I do it wrong, but is it correct to set UseProtectedRelease like this in GXDLMSReader.cs (image1)?
The solution built with 0 warning or error.
I tried to connect using this modified client.net, the error still persists.
Did I do it wrong? I'd be grateful for your help.
For reference, I tried to connect using director both with and without [use protected release] option in Advance tab. everything works fine.
Last 25 lines from trace using modified client.net is like this:
TX: 10:24:20 7E A8 89 03 0D 9E 75 89 E6 E6 00 E0 01 00 01 00 00 82 03 F9 DB 08 4B 46 4D 09 EB C1 C5 FC 82 24 61 30 00 00 17 C3 79 1E A5 CF A1 84 E9 3E 86 BC 38 77 63 5F 0B 87 2E 00 B4 A1 BF 36 94 15 70 CC 2B 44 A1 25 A2 9C 06 78 B1 91 7D 41 05 2A 47 FC B4 A0 CA F1 BC 72 49 EC E8 BA EF 0B 06 D6 9B 1B 7A 1C 98 93 3F 69 AC 63 F5 C4 59 8B DE 17 14 80 FD 71 B7 E8 34 A6 A6 E5 E2 CD 5B 31 4D 7E 74 4F 70 CF E4 CF E8 69 9C F0 96 4A 7E
RX: 10:24:21 7E A0 07 0D 03 11 8D A6 7E
TX: 10:24:21 7E A8 89 03 0D 90 0B 60 56 F0 D7 E8 DC A4 2C 09 4E CE 06 A7 A0 6F A4 20 67 25 F7 76 E4 65 DE 06 25 80 C5 50 F5 2A F0 E4 25 82 7B 26 D6 08 FD 38 F1 0E F4 17 EA 3A 58 86 AB 42 72 17 9E 8E 7D CA 2C C6 80 50 15 FE E9 E7 9C AA 6A E1 E7 01 A0 CD D9 B9 FB 87 B0 01 A6 3C AC 32 91 76 A2 4B 29 DB 3A 65 66 7B 7E 83 66 5D 1F B7 0E E1 E2 74 93 F0 5C 47 54 66 3B 93 47 F5 39 0A 6D DE D8 D0 69 85 59 EB BA 14 FB 81 65 A0 64 EC 7E
RX: 10:24:21 7E A0 07 0D 03 31 8F 87 7E
TX: 10:24:21 7E A8 89 03 0D 92 19 43 12 6C C6 BE 3E F2 FC 75 73 09 A1 86 BE 55 A6 04 EA 32 DB B0 18 DB 2C 93 7D 0C 0F 70 A9 25 29 48 43 24 D4 97 28 77 C1 BA 65 11 37 AC 03 F6 E0 38 21 15 0E D0 DD 04 61 9D AD B6 D4 C6 83 82 D6 3B 82 B2 EC 41 6A B7 2B 85 BD A7 6E 6C 45 77 1B 95 13 B7 4A 48 46 AE 2D 2B 1B 87 31 2B A3 11 07 C6 7E 3D 13 80 F3 3D E3 DA BF 66 31 BD 3F CC 11 94 C3 F9 34 E1 9E 9B 38 1F E1 CE 8B 74 9E E0 F0 22 CB 25 7E
RX: 10:24:21 7E A0 07 0D 03 51 89 E4 7E
TX: 10:24:21 7E A8 89 03 0D 94 2F 26 37 DE 8B 3B B1 5C 8F 0E 4C 4A 9D 3F D2 E8 B6 96 51 1A C0 AB 08 B2 2A BD A2 6F 6D CF F2 2E 78 CC C5 45 3E 45 1C 78 25 6C 87 EA 61 B3 60 C0 B4 F9 89 80 11 BD 68 44 E5 A7 28 CB C6 86 E2 E9 C9 C6 28 01 DC 32 09 F0 E3 82 21 BB 52 7F 25 9D 89 A2 F3 C4 70 AE FB EB E6 83 98 E7 F2 12 7A 63 28 8B 69 7F A8 19 A0 0D 39 B7 C1 44 DB EE 66 86 55 00 61 E7 B5 09 F4 37 1D 3A D6 59 BF 10 CC 2A A1 2D E7 7B 7E
RX: 10:24:21 7E A0 07 0D 03 71 8B C5 7E
TX: 10:24:21 7E A8 89 03 0D 96 3D 05 F2 CF E0 A3 04 4B 6A 2A C0 6B F2 F2 2D CD E6 98 D5 77 F7 E6 34 67 37 57 C0 BB 13 D1 CC 77 2C 9A A2 C1 14 05 78 76 E2 00 BA 83 36 3B 08 BB EB A6 52 65 18 A6 9F E9 2B 50 FD C9 57 BD CA 06 98 C4 0B 6D 47 0D B1 70 5D 98 FD 89 33 91 33 92 07 74 42 30 BF 39 33 06 F2 EF 71 D8 9D 4A 89 54 7A BF 00 B8 97 4D 00 B8 30 93 79 FC AF 25 6C 1A CB 4E 3B B9 12 01 4D 57 8C BC 90 B5 32 5E BD 3C EB 93 07 4A 7E
RX: 10:24:21 7E A0 07 0D 03 91 85 22 7E
TX: 10:24:21 7E A8 89 03 0D 98 43 EC B2 5F AD 69 4A E5 93 27 7F 01 DF E7 F8 1A 5B 20 E7 7E 16 51 01 2E BC A4 9D AD CF 5B 1E FF 4E 2A A9 D0 16 D3 7F 12 A6 45 59 D3 EE 61 63 01 7F EB C6 A0 9E 95 20 0C CC DD 45 55 9B 04 1E A2 3F 60 96 B4 DF 74 45 20 35 B8 ED C0 38 AD 4D 51 CF FF B6 AC 0E 34 FF 06 E2 E2 53 79 A1 03 68 78 D7 09 E5 5D D9 06 21 76 74 0E 8A 6B A3 7E 5C 74 88 88 89 0E 45 F3 62 96 8B F4 BC 96 1F D7 5B 78 1C EE 2F D9 7E
RX: 10:24:21 7E A0 07 0D 03 B1 87 03 7E
TX: 10:24:21 7E A8 89 03 0D 9A 51 CF A3 0A D6 44 06 2F F1 54 0C 3D B4 F7 A2 36 86 C9 70 85 82 BA E7 C4 D6 65 9B FF 80 8F A3 6B B3 EE AE B9 8B 2A E5 67 75 67 EA AE C4 0B 97 51 CE 75 06 7C D4 E7 36 BA 43 90 72 BD 2A 6E 86 A9 3A 97 13 0E 07 EA 32 29 EA 9B C4 C0 1F 54 11 9B 7F 86 31 4A BB 84 2C A6 7E 75 B7 C0 0E C9 1E 5F 3E F6 2D 2F 31 01 ED F2 74 CB 57 46 8B 04 1C C0 65 FE 77 61 3F 72 94 16 FC C7 70 A3 6B C6 60 DC A5 45 A4 04 7E
RX: 10:24:21 7E A0 07 0D 03 D1 81 60 7E
TX: 10:24:21 7E A8 89 03 0D 9C 67 AA 10 C1 E0 37 F9 33 EE 63 1B E3 70 8A 85 F4 95 4C AB F9 E0 36 2A 4C 1D 50 AA C4 30 26 6E 27 F0 FB 3C F3 50 76 C4 71 38 F3 2A 50 DA 74 42 9C 54 61 E7 95 EE BC 86 3D 21 E9 ED 95 36 FB 75 E7 09 0D A3 24 92 8B 11 87 8A 84 38 54 D1 3D 25 9D 32 15 CE A5 1A A2 6C F5 95 4C E9 E1 22 26 1B F1 6B 8B C9 0A BC E5 E1 F8 B8 B6 EE 35 F3 A3 EA E8 04 D9 6C 0B 48 B9 59 D1 F0 74 14 81 8B 7D 84 AA ED 23 B8 61 7E
RX: 10:24:21 7E A0 07 0D 03 F1 83 41 7E
TX: 10:24:21 7E A0 0E 03 0D 9E 1A A9 67 C0 6D C9 80 4E 45 7E
RX: 10:24:21 7E A0 0C 0D 03 97 A6 87 9E E8 01 C5 60 7E
TX: 10:24:21 7E A0 11 03 0D D4 1C 35 E6 E6 00 62 03 80 01 00 BD 9B 7E
TX: 10:24:21 7E A0 07 03 0D 53 90 4D 7E
RX: 10:24:21 7E A0 07 0D 03 73 99 E6 7E
Unacceptable frame.
Hi, You can set it like this…
You can set it like this in the constructor of GXDLMSReader.
Client.UseProtectedRelease = true;
luthfipratamaps
Hi, Mr. Mikko. Thank you! It…
Hi, Mr. Mikko.
Thank you! It works now. But I need to add -g <object>. Without it, I still get the error.
Luthfi
