  3. Problem In Ctt Test
Problem In Ctt Test
By mah_1402 , 30 September, 2023
Known problems
This Is the trasnlated trace .
CCt test.
After Sedn Snrm and Arrq with Cipering. call Send ActionRequest (Reply to HLS authentication) .where is the problem of This trace.??
This tested with Ctt 3.0
BlockCipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Authentication Key:D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
1: 7E A0 14 03 03 93 E0 F7 81 80 08 05 02 02 00 06 02 02 00 43 B0 7E
<HDLC len="13" >
<TargetAddress Value="1" />
<SourceAddress Value="1" />
<!-- SNRM frame. -->
<FrameType Value="93" />
<PDU>
<Snrm>
<MaxInfoTX Value="512" />
<MaxInfoRX Value="512" />
</Snrm>
</PDU>
</HDLC>
2: 7E A0 20 03 03 73 F0 2E 81 80 14 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 6F EF 7E
<HDLC len="1F" >
<!-- UA frame. -->
<FrameType Value="73" />
<PDU>
<Ua>
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Ua>
</PDU>
</HDLC>
3: 7E A0 73 03 03 10 B6 8F E6 E6 00 60 65 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 43 54 54 30 30 30 30 30 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 1A 80 18 CD E8 49 3C E3 7E 7B 7E 7D C6 9A C0 6E 6A A5 06 8B F8 18 1F 9B FD B4 8C BE 23 04 21 21 1F 30 75 67 F2 85 1A 80 12 53 82 EE CD FB 3A 40 6B EA 80 42 CF E9 B3 F1 24 0C E0 8B 22 9F 50 86 6A 6B 7E
<HDLC len="72" >
<!-- AARQ frame. -->
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="4354543030303030" />
<MechanismName Value="HighGMAC" />
<CallingAuthentication Value="CDE8493CE37E7B7E7DC69AC06E6AA5068BF8181F9BFDB48C" />
<!-- Decrypted data:
Invocation Counter: 1969746565
<InitiateRequest>
<ProposedConformance>
<ConformanceBit Name="Attribute0SupportedWithSet" />
<ConformanceBit Name="PriorityMgmtSupported" />
<ConformanceBit Name="Attribute0SupportedWithGet" />
<ConformanceBit Name="DataNotification" />
<ConformanceBit Name="Get" />
<ConformanceBit Name="Set" />
<ConformanceBit Name="EventNotification" />
</ProposedConformance>
</InitiateRequest>
<glo_InitiateRequest Value="307567F2851A80125382EECDFB3A406BEA8042CFE9B3F1240CE08B229F5086" />
</AssociationRequest>
</PDU>
</HDLC>
4: 7E A0 77 03 03 30 58 DC E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4D 41 48 1E 00 1E BD 5F 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 91 C8 E4 72 39 1C 8E 47 A3 D1 E8 74 BA DD 6E 37 BE 23 04 21 28 1F 30 00 00 00 00 04 44 78 A9 65 66 97 02 7F 1C 57 8C 82 55 51 43 CA 2E CD 22 50 3C 33 45 39 FA 70 D4 7E
<HDLC len="76" >
<!-- AARE frame. -->
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<AssociationResult Value="00" />
<ResultSourceDiagnostic>
<!-- AuthenticationRequired -->
<ACSEServiceUser Value="0E" />
</ResultSourceDiagnostic>
<!-- DLMS system title:
Manufacturer Code: MAH
Serial number: 2014559
<RespondingAPTitle Value="4D41481E001EBD5F" />
<RespondingAuthentication Value="91C8E472391C8E47A3D1E874BADD6E37" />
Invocation Counter: 0
<InitiateResponse>
<NegotiatedConformance>
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="03F2" />
<VaaName Value="0007" />
</InitiateResponse>
<glo_InitiateResponse Value="3000000000044478A9656697027F1C578C82555143CA2ECD22503C334539FA" />
</AssociationResponse>
</PDU>
</HDLC>
5: 7E A0 48 03 03 32 41 01 E6 E6 00 DB 08 43 54 54 30 30 30 30 30 31 30 75 67 F2 90 62 7E E8 D7 1A FB 8B BE 15 5C 32 DF 2F 02 D6 E5 E2 81 33 CE 35 59 FD E6 13 FA 82 B9 FA BC 1E B8 4A 90 6A 92 13 3C 2F 88 D4 42 E6 AC 6A 8C 7E
<HDLC len="47" >
<FrameType Value="32" />
<PDU>
Manufacturer Code: CTT
Serial number: 3158064
<!-- Invocation Counter: 1969746576 -->
<!-- Decrypt data: C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 11 10 75 67 F2 8F 50 9A AF 51 C4 6A 5E F9 EF 26 DF A8
<ActionRequest>
<ActionRequestNormal>
# Priority: High, ServiceClass: Confirmed, Invoke ID: 1
<MethodDescriptor>
# AssociationLogicalName
<ClassId Value="000F" />
# 0.0.40.0.0.255
<InstanceId Value="0000280000FF" />
# Reply to HLS authentication
<MethodId Value="01" />
</MethodDescriptor>
<MethodInvocationParameters>
<OctetString Value="107567F28F509AAF51C46A5EF9EF26DFA8" />
</MethodInvocationParameters>
</ActionRequestNormal>
</ActionRequest>
<GeneralGloCiphering>
<SystemTitle Value="4354543030303030" />
<CipheredService Value="307567F290627EE8D71AFB8BBE155C32DF2F02D6E5E28133CE3559FDE613FA82B9FABC1EB84A906A92133C2F88D442E6AC" />
</GeneralGloCiphering>
</PDU>
</HDLC>
6: 7E A0 10 03 03 52 89 52 E6 E7 00 0E 06 00 06 DD 48 7E
<HDLC len="F" >
<FrameType Value="52" />
<PDU>
<ConfirmedServiceError>
<Service Value="06" />
<ServiceError>
<ApplicationReference Value="DecipheringError" />
</ServiceError>
</ConfirmedServiceError>
</PDU>
</HDLC>
7: 7E A0 07 03 03 53 80 D7 7E
<HDLC len="9" >
<!-- Disconnect Request frame. -->
<FrameType Value="53" />
<DisconnectRequest>
</DisconnectRequest>
</HDLC>
8: 7E A0 20 03 03 73 F0 2E 81 80 00 05 02 02 00 06 02 02 00 07 04 00 00 00 01 08 04 00 00 00 01 2C 5C 7E
<HDLC len="1F" >
<!-- UA frame. -->
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
3 years ago
Hi, Can you tell what is a…
Can you tell what is a failed CTT test case and what sub-test?
