  3. Gurux.DLMS.AMI.Agent-Issue
By Sourabh , 9 September, 2023
Gurux.DLMS.AMI
Gurux.DLMS.AMI.Agent is configured in AMI and showing connected but it is not able to connect to actual smart meter ..where i can connect to smart meter directly using GXDLMDirector
fail: Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
2023-09-09 12:53:03 PM Failed to establish the connection. A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
My settings.json file -
{"Id":"b7117686-ea0f-4f00-bc33-6b6df9dcac86","Address":"https://localhost:8001","Token":"86D232BF4A75A46733D8849062C2417D170D88…}
I am trying to connect using TCP ip address and port with interface type WRAPPER
Please help ?
Sourabh
3 years ago
after doing some config …
after doing some config ..now i am geeting below error ..
info: Gurux.DLMS.AMI.Agent.Worker.GXAgentWorker[0]
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 2A 6F 4E 10 42 6C 3E 11 41 14 18 60 35 3F 45 50 BE 23 04 21 21 1F 30 00 00 00 01 34 69 6E 7E 1F 93 97 5A 7D 5E C2 57 45 D1 E5 D7 11 6A 6D DA EF C6 B5 1C 91 EA
00 01 00 01 00 30 00 21 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00
2023-09-09 1:54:08 PM Failed to establish the connection. ServiceError Initiate Error exception. Initiate Other
3 years ago
Hi, Your connection is…
Your connection is ciphered. Check that your block cipher and authentication keys are correct. You can find them from the key management:
https://localhost:44338/config/KeyManagement
