  3. GetPorts Issue In Android Serial
getPorts issue in Android Serial
By moacir , 14 July, 2023
Gurux.Serial
I'm having an issue with gurux serial for Android. The getPorts method is not returning any port when I disconnect and connect an usb serial cable on the phone.
The first time I connect the cable it works fine, the problem only happens after disconnect and connect the cable again.
To make it work again I need to close and open the demo app.
3 years ago
Hi, Are you using java …
Are you using java (Android Studio) or the C# version?
Let me know this and I'll check this.
moacir
3 years ago
Hi, I'm using Java with…
I'm using Java with Android Studio.
Best Regards,
Moacir
