  3. How Do I Define Params For Server.example?
How do I define params for server.example?
By zshajarkar , 28 May, 2023
I'm new to using Gurux and I'm trying to understand how to properly use the parameters . Specifically, I'm wondering what values I need to add for the parameters and how to ensure that the values I'm using are valid.
For example, how would I interpret the value of -t INFO or -S Com1 or -R ln? I'm not sure what each one represents and how to properly use them.
Thanks in advance
3 years 3 months ago
Hi, DLMS is quite a…
DLMS is quite a complicated protocol. If one of the parameters is wrong, the meter doesn't reply. I propose that you download GXDLMSDirector and play it with that to get a better understanding from the DLMS.
-t is trace level. It defines that traces are shown.
-s is a serial port. It defines the used serial port.
-r defines is the logical or short name used.
