  3. Simulator Not Responding After Generating Xml File
Simulator not responding after generating xml file
By ing9 , 15 May, 2023
Gurux.Net
I have a MT880 Meter, I generated the simulator xml file reading the meter with the next command line:
Gurux.DLMS.Simulator.Net.exe -S COM6:9600:8None1 -c 1 -s 185 -a Low -P 12345678 -f 128 -o mt880_v2.xml -t Verbose
However when i try to use the simulator:
Gurux.DLMS.Simulator.Net.exe -p 3000 -c 1 -s 185 -a Low -P 12345678 -f 128 -x mt880_v2.xml -t Verbose -N 2
The respond is:
DLMS HDLC Logical Name simulator start in ports 3000-3001.
Waiting 00:00:09 before next execution.
Server address: 185
Associations:
Client address: 1 Low authentication, password 12345678
Conformance:
GeneralProtection, GeneralBlockTransfer, BlockTransferWithGetOrRead, BlockTransferWithSetOrWrite, BlockTransferWithAction, MultipleReferences, Get, Set, SelectiveAccess, Action
MaxReceivePduSize: 1280 MaxSendPduSize: 1280
Security suite: Suite0
Security policy: None
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Broadcast block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
Waiting 00:00:10 before next execution.
TCP/IP connection established.
TCP/IP connection closed. "
the error in Gurux director is "failed to receive reply from the device in given time".
Note: I added myself the hex pasword in the xml file because it was not added in the first place.
<Secret>31 32 33 34 35 36 37 38</Secret>
I have checked and with the crystal.xml file works just fine.
I appreciate any help
3 years 5 months ago
Hi, I can check this if you…
I can check this if you send the xml file to by email.
