  3. Value Cannot Be Null. (Parameter 'Array Is Empty.')
Value cannot be null. (Parameter 'Array is empty.')
By arashahmadi , 14 April, 2023
Gurux.DLMS.AMI
Hello ,
I'm receiving below message while trying to add New Device Template:
"Value cannot be null. (Parameter 'Array is empty.')"
No idea why this is happening.
Thank you
Arash
3 years 7 months ago
Hi Arash, Get the latest…
Hi Arash,
Get the latest version and remove your user from the database. Then create a new user and add the new device template everything is working without problems now.
This was a bug that was created two versions ago and it shows up for you like this.
https://www.gurux.fi/issue/guruxdlmsami4/20732
arashahmadi
Great thanks , working now…
Great thanks , working now.
But I'm facing an issue with Agent now. I have downloaded the agen and ran it.
But it's not asking me for token. Here is the output:
starting Gurux.DLMS.Agent version 4.0.2304.1301
Welcome to use Gurux.DLMS.AMI.
Gurux.DLMS.AMI address: [https://localhost:8001]
Hi, Press enter to access…
Press enter to access Gurux.DLMS.AMI address. Token is asked next.
