  3. Wrapper Command Support
Wrapper command support
Profile picture for user tbvk
By tbvk , 14 April, 2023
Not sure if you are aware but Clou meters have two Wrapper commands they implement that the Gurux parsePdu decoder for InterfaceType.WRAPPER currently doesn't support.
These are `LOGIN` and `HEARTBEAT`, will support be added for these?
tbvk
3 years 7 months ago
I have code for decoding…
I have code for decoding them if you need?
Hi, LOGIN and HEARTBEAT are…
LOGIN and HEARTBEAT are not in the DLMS standard. I need to think about this. Can you add those PDUs as a hex so I can check them?
The main problem is that if a new PDU is added to the standard that is using those message IDs it will break everything.
tbvk
The login request is: `00 01…
`00 01 00 01 00 01 00 16 0A 02 10 43 4C 45 31 30 35 34 39 32 32 30 30 37 38 37 34 00 80 FF`
I understand how it may break things, what I would recommend then is if one could make it optional to enable such a mode, that or allowing some sort of filter/handler to be able to be placed in for certain commands or so. Something easily pluggable, but something is required as this meters REQUIRE this. One could specify also, the DLMS spec version such that I can use the specification these meters use and enable a flag for Clou wrapper command (HEARTBEAT AND LOGIN) command support - that would make sense seeing as these meter's by Clou as it stands will not receive a new DLMS spec in their firmware. That is a sane way to go about it I think - for an ever evolving standard.
Here is the code, encode/decode which should help a lot: https://paste.debian.net/hidden/7686d475/
Hi, I have thought the …
I have thought the `LOGIN` and `HEARTBEAT` support. Support for those PDUs is not possible to add because there is no documentation from them.
Can you ask Clou to add them to DLMS standard if they are needed with their meters?
tbvk
I mean I could try, I have…
I mean I could try, I have contact with their engineers so I could ask them.
You are correct in that there is no documentation available for it, if I can get something liek that would that help you?
Also, the way we reverse engineered it was by running their MeterView software in server mode and watching the debug logs as the clou meter connected - you could try that - do you have a Clou meter available?
tbvk
UPDATE: I have emailed them…
UPDATE: I have emailed them the list of commands GuruX doesn't support.
In the meantime all they sent me was the attached photo but it doesn't say much about the CLOU commands, just the WRAPPER format in general
tbvk
So xDLMS APDU is where we…
So xDLMS APDU is where we are having the trouble, I will let you know what they say when they get back to me.
Hi, It is always good if the…
It is always good if the meter manufacturer answers your questions. I know several manufacturers with poor support, even if you have a lots of meters.
This document from the WRAPPER doesn't help. I hope that they will add this PDU to DLMS standard.
tbvk
I should have a reply in a…
I should have a reply in a few hours or a day or two. I made a request.
tbvk
Good morning Hikko, I have…
Good morning Hikko,
I have received a reply from the Clou engineers, may I email you the documents please. The PDF sent describes it all in full.
Hi, Send the pdf to me. I'll…
Send the pdf to me. I'll think if this is doable after I have the documents.
tbvk
What is your email?
What is your email?
tbvk
I have emailed you Mikko.
