  3. Unknown Tag Error Occured
Unknown tag error occured
By wooreeinfo , 9 February, 2023
I'm trying to connect our meter (based on gurux.dlms.java library) via our contractee's client program (based on Gurux.DLMS.Net library).
This client only support secured connections with ECDSA certificate, and it works well with other meters.
But when I try to connect our meter using this program, it always shows 'Unknown tag' error like below and connection failed.
RX: 7E A0 21 24 FF 27 93 FD EF 81 80 14 05 02 04 00 06 02 04 00 07 04 00 00 00 01 08 04 00 00 00 01 72 E3 7E
TX: 7E A0 1F 27 24 FF 73 05 AF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
RX: 7E A8 8A 24 FF 27 10 1E D5 E6 E6 00 60 82 02 3E A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 41 42 43 44 45 46 47 48 A7 82 01 E0 04 82 01 DC 30 82 01 D8 30 82 01 7C A0 03 02 01 02 02 04 1D D1 2D 5E 30 0C 06 08 2A 86 48 CE 3D 04 03 02 05 00 30 30 31 0B 30 09 06 03 55 04 06 13 02 6B 72 31 0E 30 0C 06 03 55 04 0A 0C 05 6B 65 70 63 6F 31 11 30 0F 06 03 55 04 03 0C 08 41 4D 49 43 41 30 30 31 30 20 17 0D 32 31 31 19 BB 7E
TX: 7E A0 08 27 24 FF 31 8F 4A 7E
RX: 7E A8 8A 24 FF 27 12 0C F6 30 30 36 32 32 30 30 30 30 5A 18 0F 39 39 39 39 31 32 33 31 31 34 35 39 35 39 5A 30 43 31 0B 30 09 06 03 55 04 06 13 02 6B 72 31 0E 30 0C 06 03 55 04 0A 0C 05 6B 65 70 63 6F 31 0C 30 0A 06 03 55 04 0B 0C 03 41 4D 49 31 16 30 14 06 03 55 04 03 0C 0D 4E 4A 43 31 33 32 31 30 30 30 35 35 30 30 59 30 13 06 07 2A 86 48 CE 3D 02 01 06 08 2A 86 48 CE 3D 03 01 07 03 42 00 04 8F 3B E1 F4 E6 AF 0C 7E
TX: 7E A0 08 27 24 FF 51 89 29 7E
RX: 7E A8 8A 24 FF 27 14 3A 93 6A 58 59 A7 74 67 FB CA DB FB 05 E4 CB C9 7C CE AE D2 45 7B E8 5E 99 7B BD BE 0F D0 B5 35 18 98 F5 75 86 92 9A CA F5 5A 36 0A 09 40 5A 17 B1 AF 14 7E 17 FF F0 31 97 28 6F A7 8E A3 6D 30 6B 30 59 06 03 55 1D 23 04 52 30 50 80 14 2F 3B D6 ED F8 C2 CE 39 CD C1 E4 F3 79 EA BC FD 49 3E 7F 78 A1 34 A4 32 30 30 31 0B 30 09 06 03 55 04 06 13 02 6B 72 31 0E 30 0C 06 03 55 04 0A 0C 05 6B 65 8E 1E 7E
TX: 7E A0 08 27 24 FF 71 8B 08 7E
RX: 7E A8 8A 24 FF 27 16 28 B0 70 63 6F 31 11 30 0F 06 03 55 04 03 0C 08 52 4F 4F 54 43 41 30 31 82 02 00 85 30 0E 06 03 55 1D 0F 01 01 FF 04 04 03 02 06 C0 30 0C 06 08 2A 86 48 CE 3D 04 03 02 05 00 03 48 00 30 45 02 21 00 DE C4 2E 17 16 57 8E 5B C6 1B AB 27 F3 6D 93 96 25 A6 2E E8 91 FF FC 65 78 95 3E B4 E6 1B 73 9E 02 20 69 34 FA 68 13 C6 6E 78 2D EF 9A 06 12 9D D8 15 5A C3 47 8A 97 4C 78 3F 79 43 9F 27 25 0C A1 B5 7E
TX: 7E A0 08 27 24 FF 91 85 EF 7E
RX: 7E A0 4F 24 FF 27 18 2D 15 E8 11 8A 02 07 80 8B 07 60 85 74 05 08 02 07 AC 22 80 20 F5 D3 52 03 68 9E D4 B0 E5 EA B0 B5 EC FC C5 60 7F C7 09 18 96 23 C9 D3 2B 2F A3 8D FE 08 98 AC BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 18 1F 04 00 D1 A5 7E
2월 09, 2023 11:29:41 오전 gurux.dlms.GXAPDU parsePDU2
WARNING: Unknown tag: 130.
WARNING: Unknown tag: 48.
WARNING: Unknown tag: 49.
WARNING: Unknown tag: 3.
Would you please let me know why this error occured?
Thanks and regards.
3 years 5 months ago
Hi, Your messages are…
Your messages are encrypted. Can you share the block cipher and authentication keys so I can check this?
wooreeinfo
In reply to Hi, Your messages are… by Kurumi
When I asked contract…
When I asked contract company, they said it use an ephemeral key using ecdsa certificate and private key.
I think I need to check this and ask again later with a new post.
Thanks and regards.
  • liha_2019
  • FiqJXzPfbTtORWoZ
  • Georgegeowl
  • brsRKNujhfnXWm…
