  3. Using GuruX For Multiple Seperate TCP Connections Individually
Using GuruX for multiple seperate TCP connections individually
Profile picture for user tbvk
By tbvk , 6 February, 2023
Gurux.Net
What would be the best way to go about writing a TCP-based server that accepts incoming connections from multiple meters and handles each seperately.
I see that GXNet has the ability to do so 9I looked at its implementation), but I was wondering if there was perhaps a way to somehow spawn a seperate IGXMedia per each connection such that I can handle each as their own meter.
Currently the listeners one can add don't provide all too much in terms of the abolity to handle seperate clients in a meaningful way.
Is there any plan to add functionality in the future where a seperate cGXClient-sort of thing could be spawned per connection or atleast providing an adapter that can take in an activate Socket and perform the parsing and reading of bytes containing DLMS data within?
3 years 9 months ago
Hi, Check Gurux.DLMS.Meter…
Check Gurux.DLMS.Meter.Listener.Net. It listens given port and then reads the DLMS meter when the meter has established the connection.
https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Meter.Li…
  • Raja Golf - Kantor Pusat | WA 083148835648
  • AB Golf | WA 083148835648
