  3. Different Bytes In The Request
Different bytes in the request
By DenisMalakhov , 31 January, 2023
Hello, I am using .NET library. The ReadRowsByRange method generates different bytes depending on where the code is executed. On my local work computer, one result is obtained, and in the docker container on linux (Ubuntu) there are other bytes.
public void ReadValuesByDateRange(DateTime start, DateTime end)
var profileGeneric = new GXDLMSProfileGeneric(LogicalName);
_spodesClient.Read(profileGeneric, 3);
var reply = new GXReplyData();
var dataToSend = _spodesClient.SecureClient.ReadRowsByRange(profileGeneric, start, end);
on windows:
126 160 79 0 2 102 113 97 248 43 57 230 230 0 192 1 193 0 7 1 0 98 2 0 255 2 1 1 2 4 2 4 18 0 8 9 6 0 0 1 0 0 255 15 2 18 0 0 9 12 7 231 1 25 255 0 0 0 255 0 0 0 9 12 7 231 1 25 255 23 59 59 255 0 0 0 1 0 126 8 126
docker container running on linux:
126 160 79 0 2 102 113 97 248 43 57 230 230 0 192 1 193 0 7 1 0 98 2 0 255 2 1 1 2 4 2 4 18 0 8 9 6 0 0 1 0 0 255 15 2 18 0 0 9 12 7 231 1 25 255 0 0 0 255 255 76 0 9 12 7 231 1 25 255 23 59 59 255 255 76 0 1 0 221 100 126
Input arguments were the same. Please can you tell what i can do with that? Or why is this happening?
Administrator
3 years 9 months ago
Hi, There are several…
There are several parameters that affect communication. There is also a sequence counter that is increased with every read, but in your case the start and end dates are different.
Windows is using UTC:
<!-- 25.1.2023 0.00.00Z -->
Docker is using the current time zone (UTC+3:00)
<!-- 25.1.2023 0.00.00+03:00 -->
tiger
https://t.me/pump_upp - best…
https://t.me/pump_upp - best crypto pumps on telegram
Make 1000% and more within 1 day, join channel @pump_upp !
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
