  3. Unable To Use Authentication With Simulator
unable to use authentication with simulator
By pavith , 6 January, 2023
hi,
i have given all the parameters to enable authentication. but simulators not using those( it is starting without authentication)
\gurux.dlms.java\gurux.dlms.simulator.java>java -jar target/gurux.dlms.simulator.java-0.0.1-SNAPSHOT.jar -a high -h 192.168.26.2 -p 4059 -T 4954503030373931 -B 32323232323232323232323232323232 -P 1A2B3C4D5E6F7G8H -A 32323232323232323232323232323232 -t Verbose -x crystal.xml
DLMS HDLC Logical Name simulator start in ports 4059-4059.
Server address: 1
Associations:
Client address: 16 Without authentication.
Conformance:
[GET]
MaxReceivePduSize: 832 MaxSendPduSize: 65535
3 years 9 months ago
There is only one association in your XML and it's not using authentication. You need to add a new association where authentication is used.
That is the easiest if you read the meter with a simulator using authentication.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
