  3. Load Limiter
Load limiter
By kevin jose minj , 16 December, 2022
Is there any feature to enable/disable the load through dlms director?
3 years 7 months ago
You can handle a load limiter using the limiter object.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSLimiter
kevin jose minj
3 years 5 months ago
Actually I need to enable…
Actually I need to enable/disable the limiter I didn't saw a obis code for that in gurux.Only threshold normal is I am able write to meter.
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
