  3. Gurux Serial
Gurux Serial
By Hoon , 4 November, 2022
Gurux.Serial
I was wondering if there is a way to communicate with n meters and 1 comfort unit during Glux serial communication.
3 years 12 months ago
If you are using DLMS and RS-485 then it (daisy chaining) should be possible. You can't read multiple meters with RS-232.
Hoon
I can't understand what a
I can't understand what a daisy chaining
Is it a multi-drop function?
Daisy chaining is the same thing as multi-drop in terms of RS-485.
Hoon
If communication is suddenly
If communication is suddenly stopped while communicating using a thread, a dead lock occurs in the lock in Gurux DLMS. Is there a good way to solve this?
3 years 11 months ago
HI,
HI,
If you want to read concurrently multiple meters using RS-485 you need to create your own client for each thread. There is a frame sequence counter for each connection and this causes you can't share one GXDLMSClient instance for multiple threads.
Hoon
During 1:1 communication,
During 1:1 communication, when DLMS disconnect is transmitted to stop communication with the meter, a dead lock often occurs in the lock of Guux DLMS. Is there any good way to solve this?
There shouldn't be any deadlocks. Can you describe when this occurs or tell more?
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
