  3. Gurux DLMS Python
Gurux DLMS Python
By kevin jose minj , 11 October, 2022
Kindly please help me out how to run Gurux DLMS python library. I want to pass obis code through command line. Anyone can brief me how this library is running past 1 week I am trying
3 years 9 months ago
Download the client example from here:
When you run the app you get possible arguments.
For example: python main.py -h YOUR_METER_IP_ADDRESS -p YOUR_METER_PORT_NUMBER
kevin jose minj
How will get IP address and
How will get IP address and port number? I am connected the meter with the optical prob
kevin jose minj
I tried this python main.py
I tried this python main.py -S COM5 but it is not returning the voltage ,current values
If you are trying to connect using an optical probe you can try with this:
python main.py -S COM5 -i HdlcWithModeE
kevin jose minj
Thanks for your reply this is
Thanks for your reply this is what i am getting as output, it is not returing any values
gurux_dlms version: 1.0.137
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
ClientAddress: 0x10
Standard: Standard.DLMS
kevin jose minj
In reply to Thanks for your reply this is by kevin jose minj
when i trying this command
python main.py -S COM5 -i HdlcWithModeE -C Authentication -v 0.0.96.3.10.255
output is
ClientAddress: 0x10
Security: Security.AUTHENTICATION
System title: 41 42 43 44 45 46 47 48
Authentication key: D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF
Block cipher key: 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
can you please help me out how to pass specific obis code and get output value
DLMS is not an easy protocol and I believe that one of your settings is different from what the meter expects and the meter doesn't reply because of that. Add -t Verbose to get a trace and see if the meter replying at all.
I propose that you download the GXDLMSDirector and try to connect with that. It will help you get a better idea of DLMS meters.
sankar@gurux
2 years 11 months ago
Hi continue with same topic …
Hi continue with same topic ,
I can able run and read DLMSGURX py library by giving simple command
>>python main.py COM3
and getting follwing as a response
TX: 13:36:22 7E A0 07 03 21 93 0F 01 7E
RX: 13:36:22 7E A0 20 21 03 73 73 98 81 80 14 05 02 03 40 06 02 03 40 07 04 00 00 00 01 08 04 00 00 00 01 B7 29 7E
TX: 13:36:22 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX: 13:36:23 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 03 40 00 07 D1 F0 7E
TX: 13:36:23 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 13:36:23 7E A2 80 21 03 52 4D 1C E6 E7 00 C4 01 C1 00 01 0A 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 02 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 03 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 04 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2B 01 05 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 5E 60 01 FF 02 02 01 02 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 01 00 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 02 03 0F 03 16 01 01 00 02 03 0F 04 16 01 01 00 02 03 0F 05 16 01 01 00 02 03 0F 06 16 01 01 00 02 03 0F 07 16 01 01 00 02 03 0F 08 16 01 01 00 02 03 0F 09 16 01 01 00 01 06 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 02 0F 05 16 00 02 02 0F 06 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 00 FF 02 02 01 09 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 02 03 0F 03 16 01 01 00 02 03 0F 04 16 01 01 00 02 03 0F 05 16 01 01 00 02 03 0F 06 16 01 01 00 02 03 0F 07 16 01 01 00 02 03 0F 08 16 01 01 00 02 03 0F 09 16 01 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 02 04 12 00 0F 11 01 09 06 00 00 28 00 01 FF 02 02 01 09 02 03 0F 01 16 01 01 00 02 03 0F 02 16 01 01 00 02 03 0F 03 16 01 01 00 02 03 0F 04 16 01 01 00 02 03 0F 05 16 01 01 00 02 03 0F 06 16 01 01 00 02 03 0F 07 16 01 01 00 02 03 0F 08 16 01 01 00 02 03 0F 09 16 01 01 00 01 04 02 02 0F 01 16 00 02 02 0F 02 16 00 02 02 0F 03 16 00 02 02 0F 04 16 00 04 E0 7E
-------- Reading 1 0.0.42.0.0.255 Ch. 0 COSEM Logical device name
TX: 13:36:23 7E A0 19 03 21 54 5F DE E6 E6 00 C0 01 C1 00 01 00 00 2A 00 00 FF 01 00 7A AA 7E
RX: 13:36:24 7E A0 18 21 03 74 E6 45 E6 E7 00 C4 01 C1 00 09 06 00 00 2A 00 00 FF C0 57 7E
Index: 1 Value: 0.0.42.0.0.255
But if I want to get particular profile say for example "profile generic" information ,how to get this alone
Can you pls help me to get the same ?
kevin jose minj
2 years 10 months ago
I think you are reading the…
I think you are reading the LLS Association. Try with HLS Association with correct parameters. Try once from Gurux GXDLMSDirector tool and same parameters something like this
python main.py -S COM3 -P xxxx -A xxxxxxxxxxx -D xxxxxxxxxxxx -C 80 -a High
-t Verbose
Hi sankar, Please, create a…
Hi sankar,
You can read only one attribute if you use -g argument.
sankar@gurux
Means if I wants to read…
Means if I wants to read ProfileGeneric can I use below format or ?
python main.py -S COM3 -G 'ProfileGeneric'
sankar@gurux
2 years 8 months ago
is this the correct comment…
is this the correct comment to read the nameplate profile?
python main.py -S COM9 -g 0.0.94.91.10.255
Im getting following as response
C:\Users\fsn3kor\PycharmProjects\DLMS_Python\Gurux.DLMS.Python\Gurux.DLMS.Client.Example.python>python main.py -S COM9 -g 0.0.94.91.10.255
gurux_dlms version: 1.0.146
Invalid Logical name or attribute index.
Hi sankar,
You must add the attribute index after the logical name. Like this:
-g 0.0.94.91.10.255:2
  • CTKNhZElptjSlOrpkXl
  • YCbccqfLGRMnlCWoJhXP
  • Malcolmactig
  • mhliang
  • Kevinmug
