  3. Example To Get Specific OBIS Code With Python
Example to get specific OBIS code with Python
By Eduardo Chana , 7 October, 2022
I want to obtain meter specific code with Python. How can I do it from the command terminal?
3 years 11 months ago
Hi Eduardo,
Hi Eduardo,
You try to read the clock object and it's not in the association view. Read all objects and search logical name from the association view. It might help if you add -o argument. It will save values to the file and it's easier to find the wanted object from there. If the object is not in the association view, you need to change the authentication level and read the association view again.
Eduardo Chana
Thank you very much for your
Thank you very much for your guidance, I have passed the code shown in the image and it worked. I have another question and I will create a new one.
