  3. Firmware Upgrade In Smart Meter Over GPRS
Firmware Upgrade in Smart meter over GPRS
By sachinar007 , 2 August, 2022
Gurux.Net
I am trying to upload firmware in HPL and JPM meter with "WRAPPER" as interface type. While updating Fw from GuruxDir it works. I have change wait time to 00:00:30.
can you please let me know how to set this parameter in .net sample example. Since after a time is give error.
also same is happening in case of if the meter ping fail .net sample gives error where as GuruxDir does not.
Please suggest.
4 years 3 months ago
I believe that image verify (step 5) is on progress when you try to read something from the meter and meter returns an error. Add delay after you have called ImageVerify. I believe it will fix this.
Try something like this:
ReadDataBlock(target.ImageVerify(Client), reply);
while(true)
try
Thread.Sleep(10000);
//Get list to images to activate.
ReadDataBlock(Client.Read(target, 7), reply);
catch(Exception)
//Ir's OK if this fails. Wait and try to read again.
sachinar007
4 years 2 months ago
Thanks Mikko,
Thanks Mikko,
I have find out the issue. Since this is smart meter we need to use Invocation counter. By mistake I was using US ie 0.0.43.1.3.255.
so changing it to FW 0.0.43.1.5.255 it works.
Sachin
Thank you for letting me know about this. There are so many parameters that might cause the issue and the amount of error codes is so limited.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
