  3. DLMS Director Cannot Read Register From Server Example
DLMS Director cannot Read register from server example
By Lukáš Cu , 21 May, 2022
I have setup the Java server example in Maven on my Raspberry Pi. When i connect and associate in DLMS Director, i cannot see the example register value in it (picture included). When I add the dependency in my POM file i cannot compile it at all.
How do i show the value?
Thanks for the answer.
Best regards,
Lukáš Cu
Lukáš Cu
4 years 6 months ago
Ihave solved the issue.
Ihave solved the issue. Needed higher authentication setting for the values to show. Sorry for the inconvenience.
Hi Lukáš,
Hi Lukáš,
Thanks for letting me know that you solved this.
