  3. Dlms Net - Gateway
Dlms Net - gateway
By s4_dlms , 4 April, 2022
Gurux.Net
Dear Gurux manager
4 years 7 months ago
This action message looks correct. Can you connect without a gateway using ciphering (GMAC)?
Have you read and updated the invocation counter before you try to establish the ciphered connection?
s4_dlms
Hi, thanks for your response
Everything looks correct. There are so many parameters in DLMS. If one of them is invalid the meter returns error. The main problem is that amount or error codes are limited and returned error doesn't give an exact reason for what parameter is wrong.
It's not possible to say if the reason is in the gateway or your settings because I don't know what GW you are using.
s4_dlms
thank you , if the gateway
thank you
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
  • TOPINDO LUCKY SPORT | WA 083148835648
