  3. How We Can Write On The Registers
How we can Write on the registers
Profile picture for user HEMANT KUMAR
By HEMANT KUMAR , 25 February, 2022
Gurux.Serial
Can we write value on the Registers.
For SECURE METER PREMIER 300.
I want to know how we can write. Kindly Please suggest me.
Thanks & Regards
Hemant Kumar
4 years 6 months ago
Hi Hemant Kumar,
Hi Hemant Kumar,
Because I don't know what programming language you are using I spoke at a general level.
Update value to the register component and then write it. Make sure that you have enough access rights. I believe that the best way to start is to write the register value with GXDLMSDirector.
The data type must be correct or the meter returns a write error.
