  3. D2 FrameType Not Parsed Correctly [HDLC, LN=0]
D2 FrameType not parsed correctly [HDLC, LN=0]
By lukasm , 21 February, 2022
I am facing the issue with incorrect translation of register's scaller & unit values during profile read process.
We have two identical example meters which only differ by content of profile.
I will mark them as meter A and meter B.
Both of them are read through HDLC interface with Logical Name Referencing = 0.
Meter A has a profile programmed with 9 registers, meter B has 17 registers.
I have observed that, when the amount of registers is higher than some value, then the Meter sends data in different frame type.
Transmission logs:
meter A:
TX: 7E A0 2C 00 02 68 47 41 FA D4 CB E6 E6 00 05 09 02 48 B0 02 25 E8 02 1D A8 02 1E 50 02 1F 08 02 24 88 02 25 38 02 2E D0 02 2E 20 64 4C 7E
RX: 7E A0 50 41 00 02 68 47 [DE] 30 44 E6 E7 00 0C 09 00 02 02 0F 00 16 FF 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 24 CF 7E
frameType: DE
Meter B:
TX: 7E A0 44 00 02 80 51 41 3A AF 75 E6 E6 00 05 11 02 48 B0 02 25 E8 02 1D A8 02 1E 50 02 1F 08 02 24 88 02 25 38 02 9A F8 02 9B 88 02 9C 18 02 9C A8 02 9D 38 02 9D C8 02 2C C0 02 2D 70 02 A8 78 02 AA B8 08 68 7E
RX: 7E A8 50 41 00 02 80 51 [D2] C2 AD E6 E7 00 0C 11 00 02 02 0F 00 16 FF 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 20 00 02 02 0F FE 16 23 00 02 02 0F FE 16 23 72 A9 7E
TX: 7E A0 0A 00 02 80 51 41 51 5D E9 7E
RX: 7E A0 44 41 00 02 80 51 [D4] F7 3F 00 02 02 0F FE 16 23 00 02 02 0F FD 16 21 00 02 02 0F FD 16 21 00 02 02 0F FD 16 21 00 02 02 0F FE 16 1E 00 02 02 0F FE 16 1E 00 02 02 0F FD 16 FF 00 02 02 0F FD 16 FF C8 E4 7E
frameType: D2/D4
Translated with GuruxDLMSTranslator:
meter A:
<HDLC len="43" >
<TargetAddress Value="23075" />
<SourceAddress Value="32" />
<!--I frame.-->
<FrameType Value="FA" />
<PDU>
<ReadRequest Qty="9" >
<VariableName Value="18608" />
<VariableName Value="9704" />
<VariableName Value="7592" />
<VariableName Value="7760" />
<VariableName Value="7944" />
<VariableName Value="9352" />
<VariableName Value="9528" />
<VariableName Value="11984" />
<VariableName Value="11808" />
</ReadRequest>
</PDU>
</HDLC>
<HDLC len="79" >
<TargetAddress Value="32" />
<SourceAddress Value="23075" />
<!--I frame.-->
<FrameType Value="DE" />
<PDU>
<ReadResponse Qty="9" >
<Data>
<Structure Qty="2" >
<Int8 Value="0" />
<Enum Value="255" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="30" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="30" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="32" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="32" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="32" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="32" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="30" />
</Structure>
</Data>
<Data>
<Int8 Value="-2" />
<Enum Value="30" />
</Structure>
</Data>
</ReadResponse>
</PDU>
</HDLC>
Meter B:
<HDLC len="67" >
<TargetAddress Value="24616" />
<!--I frame.-->
<FrameType Value="3A" />
<PDU>
<ReadRequest Qty="17" >
<VariableName Value="39672" />
<VariableName Value="39816" />
<VariableName Value="39960" />
<VariableName Value="40104" />
<VariableName Value="40248" />
<VariableName Value="40392" />
<VariableName Value="11456" />
<VariableName Value="11632" />
<VariableName Value="43128" />
<VariableName Value="43704" />
</ReadRequest>
</PDU>
</HDLC>
<HDLC len="79" >
<SourceAddress Value="24616" />
<!--I frame.-->
<FrameType Value="D2" />
<NextFrame Value="0C110002020F0016FF0002020FFE161E0002020FFE161E0002020FFE16200002020FFE16200002020FFE16200002020FFE16200002020FFE16230002020FFE1623" />
</HDLC>
<HDLC len="12" >
<!--S frame.-->
<FrameType Value="51" />
<Command Value="NextFrame" />
</HDLC>
<HDLC len="67" >
<!--I frame.-->
<FrameType Value="D4" />
<NextFrame Value="0002020FFE16230002020FFD16210002020FFD16210002020FFD16210002020FFE161E0002020FFE161E0002020FFD16FF0002020FFD16FF" />
</HDLC>
Could You verify if there is any issue with translation done by GX library?
Frames recevied from both meters look very similar but the outcome from the library is totally different and I'm not able to parse it correctly.
Lukasm
Mariusz Jędrzejewski
4 years 9 months ago
Please treat this request as
Please treat this request as duplicate of http://www.gurux.fi/node/19716 - it's the same case (my colleague wrote this independently :)
