  3. The Client Example
The client example
By Lukáš Cu , 3 December, 2021
I am fairly fresh in java in general.
I imported DLMS from github to eclipse and i dont get connection in the default state.
The client responds with
showhelp() function and thats it
The Readme file on github says that i need to set device parameters and alter the code further. But I have no clue where do i put those pieces of code for it to work.
The whole repository is already imported. But a step by step guide on how to actually get a DLSM connection from that point would be very very useful.
Any help would be appreciated. Thank you.
4 years 11 months ago
Hi Lukáš,
Hi Lukáš,
If one of DLMS parameters is wrong the meter doesn't reply. Unfortunately, parameters depend on the meter and manufacturer.
Try to set TCP/P port or serial port as a parameter and let's hope that meter is using the default parameters.
You can give TCP parameters like:
-h YOUR_METER_IP_ADDRESS - p METER_PORT
and serial port like:
-P COM1
Lukáš Cu
I have already solved the
I have already solved the issue. But thank you very much. The repository is a great one.
Thank you for letting me know. I'm sorry about the slow reply but yesterday was Finland's Independence Day and it was a public holiday.
Sandeep Shaw
4 years 8 months ago
Using the below code to write
Using the below code to write time into the Meter
val item: GXDLMSAutoAnswer =
settings.client.objects.findByLN(ObjectType.AUTO_ANSWER,"0.0.1.0.0.255" )
item.listeningWindow.add(
AbstractMap.SimpleEntry<GXDateTime, GXDateTime>(
GXDateTime(-1, -1, -1, 6, -1, -1, -1),
GXDateTime(-1, -1, -1, 8, -1, -1, -1)
val mData = settings.client.write(item, 2)
for(i in 0 until mData.size){
reader?.readDLMSPacket(mData.get(i), GXReplyData())
I am unable to cast GXDLMSObject to GXDLMSAutoAnswer getting the below error even though I am connected to the meter
java.lang.NullPointerException: null cannot be cast to non-null type
Please help
Thanks in Advance
In reply to Using the below code to write by Sandeep Shaw
Dear Sandeep Shaw,
Dear Sandeep Shaw,
Create a new topic if you have a new question.
http://gurux.fi/ForumRules
Create a new topic and I'll answer your question there.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
