  3. Arduino Wrapper In Server Mode
Arduino Wrapper in server Mode
By maham_elelc , 9 November, 2021
Hello. I am using You Source Code to create a meter.
all thinks is Ok In HDLC mode and I can Read Or Write Any Object From O To My meter With GXDLMS Director.
But When I change Hdlc To Wrapper Mode in my Code.Waooo!!!!
handleRequest failed:260
This Is For HDLC:
Server.init(true, DLMS_INTERFACE_TYPE_HDLC, HDLC_BUFFER_SIZE, PDU_BUFFER_SIZE, frameBuff, sizeof(frameBuff), pduBuff, sizeof(pduBuff));
And This Is For Wrapper:
Server.init(true, DLMS_INTERFACE_TYPE_WRAPPER, WRAPPER_BUFFER_SIZE, PDU_BUFFER_SIZE, frameBuff, sizeof(frameBuff), pduBuff, sizeof(pduBuff));
This Is Debug out Put:
:svr_isTarget.
:Connecting using High authentication.
:svr_validateAuthentication
:findObject15 0.0.40.0.0.255
:svr_preAction: 15 0.0.40.0.4.255
:svr_postAction: 15 0.0.40.0.4.255
:svr_connected DLMS level.
:svr_preRead: 15 0.0.40.0.4.255
:svr_postRead: 15 0.0.40.0.4.255
:handleRequest failed: 260
And Thi sis GXDLMS Director Log File:
GXDLMSDirector 8.1.2104.0801
Log created 10:12:53 AM
10:13:03 Initializing Network connection.
10:13:03 10:13:03.379 Info Opening
10:13:03 10:13:03.380 Info Client Settings: Protocol Tcp Host: 127.0.0.1 Port: 4060
10:13:03 10:13:03.380 Info Open
10:13:03 AM Send AARQ request.
00 01 00 01 11 68 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 5A 69 10 4B 05 48 2E 46 63 17 66 4E 1B 68 25 27 BE 23 04 21 21 1F 30 00 00 00 00 1F 58 4B 30 32 AF 28 57 07 70 C6 0D 7E 8F 63 E4 67 43 15 0D AF AA D4 23 33 0F
10:13:03 10:13:03.880 Sent 00 01 00 01 11 68 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 5A 69 10 4B 05 48 2E 46 63 17 66 4E 1B 68 25 27 BE 23 04 21 21 1F 30 00 00 00 00 1F 58 4B 30 32 AF 28 57 07 70 C6 0D 7E 8F 63 E4 67 43 15 0D AF AA D4 23 33 0F
10:13:04 10:13:04.241 Received 00 01
10:13:04 10:13:04.243 Received 11 68 00 01 00
10:13:04 10:13:04.246 Received 6B 61 69 A1 09 06
10:13:04 10:13:04.248 Received 07 60 85 74 05
10:13:04 10:13:04.285 Received 08 01
10:13:04 10:13:04.291 Received 03 A2 03 02
10:13:04 10:13:04.297 Received 01 00 A3 05 A1
10:13:04 10:13:04.304 Received 03 02 01 0E A4
10:13:04 10:13:04.311 Received 0A 04 08 41 42
10:13:04 10:13:04.316 Received 43 44 45 46 47 48
10:13:04 10:13:04.319 Received 88 02 07
10:13:04 10:13:04.321 Received 80 89 07 60 85
10:13:04 10:13:04.323 Received 74 05 08 02
10:13:04 10:13:04.325 Received 05 AA 12 80
10:13:04 10:13:04.328 Received 10 1B 0D 86
10:13:04 10:13:04.330 Received 43
10:13:04 10:13:04.346 Received 21
10:13:04 10:13:04.348 Received 10 88 C4 E2
10:13:04 10:13:04.351 Received 71 B8 DC EE 77
10:13:04 10:13:04.353 Received 3B 9D BE 23
10:13:04 10:13:04.355 Received 04 21 28 1F
10:13:04 10:13:04.358 Received 30 00 00 00
10:13:04 10:13:04.360 Received 09 37 0B BF 2D 93
10:13:04 10:13:04.362 Received 3C C0 A4 80
10:13:04 10:13:04.365 Received 79 54 DF 20
10:13:04 10:13:04.367 Received EE 44 97 7E FD
10:13:04 10:13:04.369 Received 50 40 89 91
10:13:04 10:13:04.371 Received 8E 16 55
10:13:04 10:13:04.421 Received BB
10:13:04 AM
00 01 11 68 00 01 00 6B 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 41 42 43 44 45 46 47 48 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 1B 0D 86 43 21 10 88 C4 E2 71 B8 DC EE 77 3B 9D BE 23 04 21 28 1F 30 00 00 00 09 37 0B BF 2D 93 3C C0 A4 80 79 54 DF 20 EE 44 97 7E FD 50 40 89 91 8E 16 55 BB
10:13:04 Parsing AARE reply succeeded.
10:13:04 AM Authenticating.
00 01 00 01 11 68 00 33 CB 31 30 00 00 00 01 37 5E 30 E4 B5 90 1D C3 80 9F EE 74 9D 6D 91 CC D1 D2 4D BD 27 F2 24 A6 5D 99 9B 45 19 6B 0F 3A 6E 67 93 14 83 E4 AA FF 91 85 43 41
10:13:04 10:13:04.423 Sent 00 01 00 01 11 68 00 33 CB 31 30 00 00 00 01 37 5E 30 E4 B5 90 1D C3 80 9F EE 74 9D 6D 91 CC D1 D2 4D BD 27 F2 24 A6 5D 99 9B 45 19 6B 0F 3A 6E 67 93 14 83 E4 AA FF 91 85 43 41
10:13:05 10:13:05.012 Received 00 01 11 68 00 01 00 2E CF 2C 30 00 00 00 09 F8 0A 78 72 8D 38 C9 B5 8E 64 56 DF 29 FF C8 C6 20 17 C3 69 74 72 B5 56 C0 11 F5 3E BB 84 84 14 58 F9 1A 97 FE EE BD
10:13:05 AM
10:13:05 --- Collecting objects. ---
10:13:05 AM Collecting objects
00 01 00 01 11 68 00 20 C8 1E 30 00 00 00 02 E2 7E 21 A9 F3 6D 32 F0 9B 4D 40 BC F4 1D 73 27 EC 36 F1 D7 D2 68 DB 98 11
10:13:05 10:13:05.802 Sent 00 01 00 01 11 68 00 20 C8 1E 30 00 00 00 02 E2 7E 21 A9 F3 6D 32 F0 9B 4D 40 BC F4 1D 73 27 EC 36 F1 D7 D2 68 DB 98 11
10:13:09 10:13:09.412 Received 00 01 11 68 00 40 00 22 DB 08 41 42 43 44 45 46 47 48 17 30 00 00 00 0B FF FF EE 46 68 19 10 EA 3A 11 EB 61 F6 00 5A B1 75 AB
How i can solve This Problem?
4 years 10 months ago
Can you share the block cipher and authentication keys so I can check the bytes?
maham_elelc
Block chiper key
Block chiper key:000102030405060708090A0B0C0D0E0F
Authentication Key:D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF
