  3. Reading Meter Data Through Java Client
Reading meter data through Java client
By aeeccims@tnebnet.org , 17 October, 2021
I am new to DLMS meter reading subject.
I wrote a java program to read the socket and able to read the meter data which pushed in regular intervals in plain text.
However, the other meter data are designed to be fetched from meter after hand shaking with modem as below: And i am able to get the reply from modem as "PMOK". After that I have to send command to meter (modem is made transparent) . Here I struck. I initiated a client java passing the modem ip and port and not getting result.
C:\Apache-Tomcat-8.5.32\webapps>java NewClass
It is now : Sun 2021.10.17 at 10:36:53 PM IST
Accepted Client Address - 10.254.0.207Meter IP:10.254.0.207port52968
Client Says :*STATUS,ONLINE,INST,#
Server Says : *PULLMODE#@01@
Waiting
false
false
Says : +++*STATUS,ONLINE,NOIN,#
Says :*PM@01@OK#*STATUS,OFFLINE,NOIN,#
Says : *PULLMODE#@01@ // From HES to Modem
Waiting
true
Server Says >>>: *PM@01@OK#*STATUS,OFFLINE,NOIN,# // From Modem to HES
true
In other Command prompt run the following:
C:\Apache-Tomcat-8.5.32\webapps>java -jar gurux.dlms.client.example.java.jar -h 10.254.0.207 -a Low -P PRIDE -r sn -t Verbose -p 52968 -c 16 -s 1
Connect using network connection gurux.net.GXNet@19469ea2
Authentication: Low
ClientAddress: 0x10
Connection refused: connect
I thought if the modem sends ":*PM@01@OK#" , I can initiate the client program from the java application to get reading of meters . Is it in right direction?
Guidance is requested to proceed further.
5 years ago
Connection refused: connect means that your TCP/IP port is wrong. You need to check it.
5 years ago
Accepted Client Address - 10.254.0.207 IP:10.254.0.207 port: 52968
The ip >>> Modem ip received that was connected.
port >> Modem IP received that was connected.
Is it correct or something else
5 years ago
The error message is clear:
The client can't establish the connection to the given port number.
What kind of modem you are using? Is it connected to the serial port or are you accessing it by TCP/IP address?
MrSupe
4 years 7 months ago
How to set timeout (in java
How to set timeout (in java package) to kill process in case to last long time?
Peter.
In reply to How to set timeout (in java by MrSupe
Hi Peter,
Hi Peter,
Please, create a new topic if you have a new question. I'll answer your question then.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
