  3. Removing of GENERAL_PROTECTION After Invocation Read
Removing of GENERAL_PROTECTION after invocation read
By Remith , 28 September, 2021
Hi.
I have seen that while reading invocation count, adding the GENERAL_PROTECTION as below.
dlms.getProposedConformance().add(Conformance.GENERAL_PROTECTION);
Due to this I was not able to read one meter manufactuer data(Getting invalid command) and to fix that I removed it in final block of invocation read.
finally {
dlms.getProposedConformance().remove(Conformance.GENERAL_PROTECTION);
Now Iam abl to read the data. But my doubt is will it affect other meters or this issue was related to the meter ?
And what is this GENERAL_PROTECTION ?
5 years 1 month ago
There is an issue with the meter. If the client asks conformance that the meter can't offer the meter should remove that conformance so the client is not using this.
https://www.gurux.fi/Gurux.DLMS.Conformance#GeneralProtection
Remith
5 years 1 month ago
Thank you very much for the
Thank you very much for the information.
I will inform the details to the meter manufacturer.
