  3. How Do I Get Response From The Meter
How do i get response from the meter
By C dV , 20 July, 2021
Gurux.Serial
I've been trying to connect to my smart meter using GXSerial object in java.
Using some sample code I've set up and can open connection. how do i send data in order to get a response (like serial number of meter) .
Also when i reach the GXSerial.receive(); section of the java application the it doesn't go further.
5 years 3 months ago
Serial port component is only used to send data with serial port connection. You need to use DLMS client example to read the data from the meter.
https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.client…
I propose that you download GXDLMSDirector and try to read data with it first. It makes it easier to understand the DLMS.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
