  3. How To Parse DLMS Ciphered Push Data (Compact Format) Which Is Sent From Meter To Remote UDP Server.
How to parse DLMS ciphered push data (Compact Format) which is sent from meter to remote UDP server.
By osman.demirci , 19 June, 2021
Hi all;
I have developed a server which listen 6001/UDP port then i set that the listened host and port to DLMS meter device using DLMS director. I set a scheduler to meter. The defined expression is "*/*/3000 12:00:00".
One day later; when i checked the server console, i saw a message like below.
Message Content (HEX)
000100010001006edb08ef0c00520000100363300000011d184945793224d9ae958d07314e5a2b3261626a94847331204ef7ed6a89b1b3352a0243355de3d7b740f26f76ba725ad08eefa2e71a160b35bac8db0f2098f18c8e38f8fc8109d28ccbcdff02384d9521eaebe3b0e2a6ce9d934d230a41d1
The message above translated with DLMS director has been as follows.
<WRAPPER len="118" >
<TargetAddress Value="1" />
<SourceAddress Value="1" />
<PDU>
<!-- Decrypt data: 0F 00 00 00 08 00 02 01 09 48 30 60 CC 5F 15 5F 47 01 01 00 BC 00 49 6C 00 00 00 00 76 00 00 00 00 03 60 CC 1A 42 4C 00 00 00 00 76 00 00 00 00 60 C9 77 41 4C 20 00 00 00 6C 00 00 00 00 60 CA C8 C1 4C 00 00 00 00 76 00 00 00 00 00 00 00 00 00 00
<data-notification>
<long-invoke-id-and-priority>8</long-invoke-id-and-priority>
<date-time></date-time>
<notification-body>
<data-value>
<structure>
<octet-string>3060CC5F155F47010100BC00496C0000000076000000000360CC1A424C00000000760000000060C977414C200000006C0000000060CAC8C14C000000007600000000000000000000</octet-string>
</structure>
</data-value>
</notification-body>
</data-notification>
<general-glo-ciphering>
<system-title>EF0C005200001003</system-title>
<ciphered-content>300000011D184945793224D9AE958D07314E5A2B3261626A94847331204EF7ED6A89B1B3352A0243355DE3D7B740F26F76BA725AD08EEFA2E71A160B35BAC8DB0F2098F18C8E38F8FC8109D28CCBCDFF02384D9521EAEBE3B0E2A6CE9D934D230A41D1</ciphered-content>
</general-glo-ciphering>
</PDU>
</WRAPPER>
I have two questions for related above section.
1 - Is there a way or method convert the XML content that especiasly is demostrated in comment tags to java object definition in GuruxDLMS java.
2- How to get meter identity information data such as meter serial number, meter flag code etc from the message.
Thanks a lot.
5 years 4 months ago
1. You can use GXDLMSTranslator messageToXml or dataToXml -methods.
You should check the listener example. It will do what you want to do.
https://github.com/Gurux/gurux.dlms.java/tree/master/gurux.dlms.push.li…
2. DLMS standard doesn't define what kind of data meter must send and in what order. So content of the data depends on the meter.
  • Eric@li
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
