  3. HLS WITH GMAC
HLS WITH GMAC
By aoudumbarpawar , 15 June, 2021
Hii Mikko,
I want to implement GMAC authentication.
Below are my some queries:
1. Is it compulsory to exchange client-servers system title in AARQ and AARE before pass 3 and 4
2. if suppose i am not included server systems title in AARE then what will happen.
3. How to authenticate the GMAC at server side which is received from the client
4. Which IC (invocation counter) must be used at server side during calculating GMAC
Also can share the frame log along with pass 1 ,2 ,3 ,4 (HDLC)
AP
5 years 3 months ago
1. Yes it's mandatory.
2. Certificate tests will fail.
3. I believe that you need to get a copy of Green Book. It answers all your questions.
4. IC is sent as part of the message.
aoudumbarpawar
Hii Mikko,
Hii Mikko,
Thanks!!!
I have implemented the GMAC but not getting info how to set GuruxDirector setting for HLS with GMAC.
AP
aoudumbarpawar
Hii,
Hii,
Not able to get authenticated using HighGMAC in non suite.
Following is the log:
09:34:24 Send SNRM request.
TX: 7E A0 23 00 02 BA 69 61 93 FA DD 81 80 14 05 02 02 4D 06 02 02 4A 07 04 00 00 00 01 08 04 00 00 00 01 C3 59 7E
09:34:24
RX: 7E A0 23 61 00 02 BA 69 73 09 85 81 80 14 05 02 01 FC 06 02 01 FC 07 04 00 00 00 01 08 04 00 00 00 01 DD A1 7E
09:34:24 Send AARQ request.
TX: 7E A0 5B 00 02 BA 69 61 10 C9 A4 E6 E6 00 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 1E 62 04 25 51 61 09 61 72 41 56 10 2B 38 63 67 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 12 56 7E
09:34:24
RX: 7E A0 67 61 00 02 BA 69 30 E6 5D E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 33 44 4C 07 02 20 00 59 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 00 00 18 4D BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 02 00 00 07 B7 46 7E
09:34:24 Authenticating.
TX: 7E A0 2E 00 02 BA 69 61 32 36 47 E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 10 A1 56 37 25 94 94 70 87 DC E0 34 B1 28 39 EB 22 FA D4 7E
09:34:29 Failed to receive reply from the device in given time.
from log it seems that GuruxSending request of high authentication instead of high GMAC
GMAC frame may be like below:
7E A0 2F 00 02 BA 69 61 32 E3 D8 E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 11 10 00 00 01 FF 47 C5 1C 9D 3E 2D 64 F0 17 BC 01 22 74 EE 7E
AP
Your block cipher key and authentication key must be the same as the meter. If they are, the meter doesn't reply.
The reason why High authentication is used is that your meter returns that High authentication is used and not HighGMAC. The client starts to use it automatically.
https://www.gurux.fi/GuruxDLMSTranslator?translate=7EA05B0002BA696110C9…
aoudumbarpawar
Hii Mikko,
Hii Mikko,
Thanks a lot!!!
I corrected the mistack in AARE but now when getting response from meter gurux shows error "Access error:Long set Or write aborted"
following is the log:
15:04:54 Send SNRM request.
15:04:54
15:04:54 Send AARQ request.
TX: 7E A0 5B 00 02 BA 69 61 10 C9 A4 E6 E6 00 60 4A A1 09 06 07 60 85 74 05 08 01 01 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 69 48 41 26 57 16 26 1E 5D 67 45 31 5A 62 00 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 90 83 7E
15:04:54
RX: 7E A0 67 61 00 02 BA 69 30 E6 5D E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 33 44 4C 07 02 20 00 59 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 00 00 18 4F BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1D 02 00 00 07 AF 94 7E
15:04:54 Authenticating.
TX: 7E A0 2F 00 02 BA 69 61 32 E3 D8 E6 E6 00 C3 01 C1 00 0F 00 00 28 00 00 FF 01 01 09 11 10 00 00 00 00 99 F2 68 BC 19 78 4C FD 17 79 5B D8 29 2D 7E
15:04:55
RX: 7E A0 27 61 00 02 BA 69 52 F4 DA E6 E7 00 C7 01 C1 00 01 09 11 10 00 00 00 00 D5 62 05 41 EB DB 69 04 D9 61 09 E3 0E BF 7E
AP
aoudumbarpawar
Hii Mikko,
Hii Mikko,
Thanks!!! Issue is resolved and get authenticated successfully :)
AP
I'm glad that you solved it. Happy programming.
