  3. Https://www.gurux.fi Is Not Accisible
https://www.gurux.fi is not accisible
By neut , 30 May, 2021
https://www.gurux.fi is not accessible
"An error occurred during a connection to www.gurux.fi. PR_END_OF_FILE_ERROR"
And as a result the GXDLMSDirector cannot download manufacturer settings.
However Http is working. Is there a way to manually download and install the manufacturer settings?
GXDLMSDirector LastError.txt:
System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a send. ---> System.IO.IOException: Authentication failed because the remote party has closed the transport stream.
at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.ConnectStream.WriteHeaders(Boolean async)
--- End of inner exception stack trace ---
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadData(Uri address)
at Gurux.DLMS.ManufacturerSettings.GXManufacturerCollection.UpdateManufactureSettings()
at GXDLMSDirector.MainForm.updateManufactureSettingsToolStripMenuItem_Click(Object sender, EventArgs e)
neut
5 years 5 months ago
I tried through VPN and it
I tried through VPN and it works now for some reason
I asked from this and there are no updates or anything that might cause this. I can access this with https. Can you please let me know if this problem occurs again? Can you read it now?
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
