  3. Read Data For Incoming Connections
Read Data For incoming connections
By ajaywazir , 26 May, 2021
Gurux.DLMS.AMI
In Gurux AMI, is it going to be possible read object values for meters connected via 4G, using DHCP and incoming connections.
Presently, apparently, I cannot read object values on demand for incoming connections
Ajay
5 years 6 months ago
Hi Ajay,
Hi Ajay,
Yes, it's possible. Open appsettings.xml and set correct Listener settings. Meters are behaving differently with this and with some meters server address might be different, so you need to set correct address to ServerAddress.
  • Raja Golf - Kantor Pusat | WA 083148835648
  • AB Golf | WA 083148835648
  • TOPGOLF Performance Bellezza | WA 083148835648
