  3. Add Array of Structures To Value of GXDLMSData.
Add array of structures to Value of GXDLMSData.
By Yuriy , 19 April, 2021
Gurux.Net
Good day!
I make my practice in Gurux.DLMS.Server.Example.Net project. I need to add specific array to Value of GXDLMSData. Array ought to be an array of structures. I didn't find example of such code in project.
For example there is adding of symple UInt32 dataType:
void AddInvocationCounter()
GXDLMSData d = new GXDLMSData("0.0.43.1.0.255");
d.Value = 0;
d.SetDataType(2, DataType.UInt32);
//Set initial value for invocation counter.
d.Value = (UInt32)100;
Items.Add(d);
And how can I add array of structures?
struct Example
meter_id //octet-string
addr //unsigned
void AddArrayOfStructures()
GXDLMSData d = new GXDLMSData("0.0.49.1.0.255");
d.Value = 0;
d.SetDataType(2, DataType.Array);
Items.Add(d);
I hope for your help...
5 years 7 months ago
You can add it like this:
GXArray arr = new GXArray();
GXStructure struc = new GXStructure();
struc.Add((UInt16) 1);
struc.Add((UInt32) 1);
d.Value = arr;
arr.Add(struc);
Make sure that your data types are correct or the meter is returning an exception.
Yuriy
Thank you for quick response.
Thank you for quick response. I'll try.
Yuriy
Works correct. Thank you!
