  3. RX Packet Loss
RX packet loss
By teddy Jim , 21 March, 2021
Hello!
There was a problem while I was using Gurux.java.
When running in a Linux environment, the following RX packet loss.
1)Data send failed. Try to resend 1/3
RX: 17:09:44.175 A0 21 23 02 6B 73 5F C3 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
java.lang.Exception: Failed to receive reply from the device in given time.
2)Data send failed. Try to resend 1/3
RX: 16:18:03.305 7E 21 23 02 6B 73 5F C3 81 80 14 05 02 00 80 06 02 00 80 07 04 00 00 00 01 08 04 00 00 00 01 CE 6A 7E
Once there's no 7E flag, once there's an A0 or A8 flag does not exist.
In a window environment, there was no problem, and when I read packets with a spy program, there was no problem with packets coming from the meter.
What additional settings should I add to my Linux environment? Or is there another solution?
5 years 8 months ago
What Linux distro you are using? Are you reading meters using TCP/IP or serial port connection?
